Aller au contenu principal
Nikon D3200 LCD Screen Replacement
Irene Huang
Irene Huang et 7 autres contributeurs
Dernière mise à jour le May 7, 2024
15 - 30 minutes
Modérée
This guide helps you replace the LCD screen. Please note that the LCD screen and the glass screen are two separate parts.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Nikon D3200 LCD Screen Replacement, Battery: étape 1, image 1 de 1
    • Locate the battery compartment on the bottom of the camera directly below the mode dial.
  2. Nikon D3200 LCD Screen Replacement: étape 2, image 1 de 1
    • Find the marked arrow on the battery compartment door and firmly push following the arrow's direction to release the latch.
  3. Nikon D3200 LCD Screen Replacement: étape 3, image 1 de 2 Nikon D3200 LCD Screen Replacement: étape 3, image 2 de 2
    • Release the latch and allow it to completely open.
    • Insert the battery by following the diagram on the inside of the compartment door.
    • Close the compartment door and firmly press on the latch until you hear a clicking sound.
  4. Nikon D3200 LCD Screen Replacement, LCD Screen: étape 4, image 1 de 1
    • Turn the camera so the bottom faces you.
    • Locate and remove the 6 screws using a Phillips #00 screwdriver.
  5. Nikon D3200 LCD Screen Replacement: étape 5, image 1 de 3 Nikon D3200 LCD Screen Replacement: étape 5, image 2 de 3 Nikon D3200 LCD Screen Replacement: étape 5, image 3 de 3
    • Locate the rubber grip directly below the shutter-release button.
    • Lift the rubber grip using a plastic opening tool to locate and remove the two screws underneath using a Phillips screwdriver #00.
  6. Nikon D3200 LCD Screen Replacement: étape 6, image 1 de 2 Nikon D3200 LCD Screen Replacement: étape 6, image 2 de 2
    • Locate and remove the 4 screws above the LCD screen, around the eyepiece. Use a razor to carefully peel the sticker off the +/- wheel to reveal the screw beneath.
  7. Nikon D3200 LCD Screen Replacement: étape 7, image 1 de 2 Nikon D3200 LCD Screen Replacement: étape 7, image 2 de 2
    • Locate the connector cover left of the LCD screen.
    • Unlatch the connector cover to reveal two screws.
    • Remove screws.
  8. Nikon D3200 LCD Screen Replacement: étape 8, image 1 de 2 Nikon D3200 LCD Screen Replacement: étape 8, image 2 de 2
    • Remove the rubber connector cover.
    • Gently pull the back portion of the camera, one hand gripping the body and the other gripping the LCD screen.
  9. Nikon D3200 LCD Screen Replacement: étape 9, image 1 de 1
    • Lay the back cover, LCD side down.
    • Locate and remove the 9 screws around the silver protector plate.
  10. Nikon D3200 LCD Screen Replacement: étape 10, image 1 de 2 Nikon D3200 LCD Screen Replacement: étape 10, image 2 de 2
    Outil utilisé dans cette étape :
    • Using a pair of tweezers, gently lift and remove the silver protector cover.
  11. Nikon D3200 LCD Screen Replacement: étape 11, image 1 de 3 Nikon D3200 LCD Screen Replacement: étape 11, image 2 de 3 Nikon D3200 LCD Screen Replacement: étape 11, image 3 de 3
    • Lift the yellow connector.
    • Flip the white clasp using a plastic opening tool, and pull out the tab.
  12. Nikon D3200 LCD Screen Replacement: étape 12, image 1 de 3 Nikon D3200 LCD Screen Replacement: étape 12, image 2 de 3 Nikon D3200 LCD Screen Replacement: étape 12, image 3 de 3
    • Lift the yellow sheet to reveal the LCD screen.
  13. Nikon D3200 LCD Screen Replacement: étape 13, image 1 de 3 Nikon D3200 LCD Screen Replacement: étape 13, image 2 de 3 Nikon D3200 LCD Screen Replacement: étape 13, image 3 de 3
    • Remove LCD screen.
19 autres ont terminé cette réparation.
Irene Huang
Membre depuis le 09/08/14
696 Réputation
3 tutoriels rédigés
Équipe
CSU Fullerton, Team 1-3, Bruce Fall 2014 Membre de l'équipe CSU Fullerton, Team 1-3, Bruce Fall 2014
CSUF-BRUCE-F14S1G3
6 membres
4 tutoriels rédigés
7 commentaires de tutoriel
Now do it without breaking the camera
Seriously. Dont do a how to if you broke the item you were trying to fix and didn't say anything.
He missed two screws. One is behind the rubber triangle on the back and one is behind sticker on the dial by the view finder.
Leroy Brown - Réponse
Agree with guy above....misses out two vital screws...the one behind the triangle and the one behind the sticker...good effort...now another tip. If you are using a 00 screwdriver there is a danger of stripping the head. So apply pressure through the screwdriver to the head of the screw and turn the camera..... not the screwdriver. You can apply more torque through rotating the camera than through rotating the screwdriver handle whilst maintaining load. BUT BE GENTLE AND SENSIBLE. Next do not over tighten when you put it back together....
drdr - Réponse
i find when backing the screws out, it is important to make the point of the screwdriver perfectly aligned vertically to the screw. as that will keep all the driver ribs fully in contact with the screw slots. and once the screw is a half turn out i turn it back in a touch to release the plastic that has wound itself onto the screw threads (during initial assembly at factory). once that is done they seem to unscrew much easier. the wrong size driver is the reason most screw heads get stripped (its not the threads that strip!) the screw is metal and the body is a plastic and carbon fiber composite material. some screws are driven too hard into the material and seem to "fuse" as if there was some Locktite or other thread sealant applied. any harsh attempt to pry, twist or lever these cameras apart is due to 'hidden screws' that are concealed behind, under and out of plain view. even those in plain sight may be concealed under wires, flex connectors or simple kapton tape strips.
Happy Fixer - Réponse
My D3200 has two chips at the corners, but camera works fine, after looking at this I am wondering if I should just leave well alone…. I just bought another Nikon camera, and I just ordered the screen protector after learning my lesson to not let my grandson takes it down.
E Fiedtkou - Réponse
Any suggestion anyone?
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 18
30 derniers jours : 103
Total : 24,392
