Nokia 2115i Faceplate Replacement
Introduction
Passez à l'étape 1Replacing the faceplate is very quick and simple to do.
Ce dont vous avez besoin
Press down on the small gray button located on the back of the phone.
Slide the back plate down and off.
Locate the spudger. A photo of the correct spudger is provided to the left.
Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
Insert the spudger into each square hole and push up to detach the face plate.
