Aller au contenu principal
Nokia 2115i keypad replacement
Shane
Shane et 4 autres contributeurs
Dernière mise à jour le February 19, 2016
10 - 20 minutes
Modérée
A besoin de meilleures images
To replace the keypad, only a small amount of disassembly is required.
Ce dont vous avez besoin
Outils
  • Spudger
    Spudger
  1. Nokia 2115i keypad replacement, Nokia 2115i Battery: étape 1, image 1 de 3 Nokia 2115i keypad replacement, Nokia 2115i Battery: étape 1, image 2 de 3 Nokia 2115i keypad replacement, Nokia 2115i Battery: étape 1, image 3 de 3
    • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
    • Press down on the small gray button located on the back of the phone.
    • Slide the back plate down and off.
  2. Nokia 2115i keypad replacement: étape 2, image 1 de 2 Nokia 2115i keypad replacement: étape 2, image 2 de 2
    • To remove the battery, begin by holding the phone sideways.
    • Then, insert your thumb in the groove below the battery and push the battery up and out.
  3. Nokia 2115i keypad replacement, Faceplate: étape 3, image 1 de 3 Nokia 2115i keypad replacement, Faceplate: étape 3, image 2 de 3 Nokia 2115i keypad replacement, Faceplate: étape 3, image 3 de 3
    • Locate the spudger. A photo of the correct spudger is provided to the left.
    • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
    • Insert the spudger into each square hole and push up to detach the face plate.
  4. Nokia 2115i keypad replacement, Removing the Keypad: étape 4, image 1 de 2 Nokia 2115i keypad replacement, Removing the Keypad: étape 4, image 2 de 2
    • Note: The keypad will be loose and may fall off during this step.
    • Pull the face plate up and off of the phone.
    • To remove the keypad, simply lift it off the phone.
Shane
Membre depuis le 09/30/10
80 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 14-38, Forte Fall 2010 Membre de l'équipe Cal Poly, Team 14-38, Forte Fall 2010
CPSU-FORTE-F10S14G38
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 1,048
