Aller au contenu principal
Nokia 3100b Screen Replacement
Sterling Fuentes
Sterling Fuentes et 4 autres contributeurs
Dernière mise à jour le February 27, 2020
10 minutes
Modérée
Photos d’action
Étudiant en action
The screen of the Nokia 3100b is prone to cracking. This guide shows you how to access the screen and remove it.
Ce dont vous avez besoin
Outils
  1. Nokia 3100b Screen Replacement, Battery: étape 1, image 1 de 1
    • Make sure your phone is turned off.
  2. Nokia 3100b Screen Replacement: étape 2, image 1 de 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Nokia 3100b Screen Replacement, SIM Card: étape 3, image 1 de 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Nokia 3100b Screen Replacement: étape 4, image 1 de 1
    • Retrieve your SIM card.
  5. Nokia 3100b Screen Replacement, Screen: étape 5, image 1 de 1
    • Separate the front cover from the main body of the phone.
  6. Nokia 3100b Screen Replacement: étape 6, image 1 de 1
    • Remove the six screws along the edges of the phone.
  7. Nokia 3100b Screen Replacement: étape 7, image 1 de 1
    • Pull the screen assembly from the base of the phone.
  8. Nokia 3100b Screen Replacement: étape 8, image 1 de 1
    • Carefully lift the keypad portion of the screen assembly from the circuit board.
  9. Nokia 3100b Screen Replacement: étape 9, image 1 de 1
    • Separate the screen from the circuit board.
    • Reconnect the ports during reassembly or the screen will not function properly.
    • Remember to reconnect the screen to the circuit board when reassembling!
  10. Nokia 3100b Screen Replacement: étape 10, image 1 de 1
    • Gently push down on the screen to pop it off of the assembly.
  11. Nokia 3100b Screen Replacement: étape 11, image 1 de 1
    • When the screen falls out the assembly, two white tabs will fall out with it.
    • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
Sterling Fuentes
Membre depuis le 04/09/10
130 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 29-64, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 1,825
