Nokia 3300B SD Card Replacement
Introduction
Passez à l'étape 1This guide describes how to replace the SD card of the Nokia 3300B.
Flip the Nokia 3300B over with the back-side facing towards you.
Gently press the button on the back of the battery cover to release the cover and slide up.
Outil utilisé dans cette étape :Tweezers$4.99
Using your finger, or a pair of tweezers, press down on the tab below the SD card.
The card will pop out of its case. Remove the card.
3 autres ont terminé cette réparation.
