Aller au contenu principal
Nokia 6061 Button Pad Replacement
rosin7
rosin7 et 14 autres contributeurs
Dernière mise à jour le January 3, 2023
10 - 15 minutes
Facile
A besoin de meilleures images
This guide will demonstrate how to repair or replace the keypad on your Nokia 6061.
The button pad for the Nokia 6061 may break, making it difficult to use the pad, or the numbers may fade away as a result of using the pad for an extended period of time. The most common issue that this repair may resolve is a broken button in the Nokia 6061 keypad, which makes it difficult to press the button. Another issue is a malfunctioning button. This can happen if the phone is accidentally dropped to the ground.
There are specific tools to assist you in completing the repair that do not require any special skills. Keep in mind that following this manual necessitates paying close attention to detail and exercising caution when performing duties in order to avoid minor injuries. Make sure to power off your phone completely and disconnect from any external power source prior to beginning this guide.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Nokia 6061 Button Pad Replacement, Button Pad: étape 1, image 1 de 1
    • Open the phone to expose the keyboard.
    • Use the opening tool to remove the call, send, end buttons, and the plastic keypad covering (use moderate force).
  2. Nokia 6061 Button Pad Replacement: étape 2, image 1 de 3 Nokia 6061 Button Pad Replacement: étape 2, image 2 de 3 Nokia 6061 Button Pad Replacement: étape 2, image 3 de 3
    • Use a T6 screwdriver to remove the four screws (one from each corner of the keypad).
  3. Nokia 6061 Button Pad Replacement: étape 3, image 1 de 1
    • Carefully lift and remove the keypad.
rosin7
Membre depuis le 02/14/13
61 Réputation
2 tutoriels rédigés
Équipe
Ohio State, Team 1-3, Buehl Spring 2013 Membre de l'équipe Ohio State, Team 1-3, Buehl Spring 2013
OSU-BUEHL-S13S1G3
4 membres
4 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 18
Total : 1,041
