Aller au contenu principal
Nokia 6200 Classic Circuit Board Replacement
Reid Polstra
Reid Polstra et 4 autres contributeurs
Dernière mise à jour le January 28, 2014
10 minutes
Modérée
This guide requires that the front plate and keypad already be removed. You will have to remove 6 screws and separate the circuit board from the rest of the phone.
Ce dont vous avez besoin
Outils
  1. Nokia 6200 Classic Circuit Board Replacement, Front Plate: étape 1, image 1 de 3 Nokia 6200 Classic Circuit Board Replacement, Front Plate: étape 1, image 2 de 3 Nokia 6200 Classic Circuit Board Replacement, Front Plate: étape 1, image 3 de 3
    • Pull up on both of the clips near the bottom of the phone as shown.
    • Lift off the front plate.
  2. Nokia 6200 Classic Circuit Board Replacement: étape 2, image 1 de 1
    • The keypad and LCD screen are revealed.
  3. Nokia 6200 Classic Circuit Board Replacement, Circuit Board: étape 3, image 1 de 2 Nokia 6200 Classic Circuit Board Replacement, Circuit Board: étape 3, image 2 de 2
    • Separate the keypad from the phone and place aside.
    • Wipe off any excess dust from where the keypad was attached to the phone.
  4. Nokia 6200 Classic Circuit Board Replacement: étape 4, image 1 de 2 Nokia 6200 Classic Circuit Board Replacement: étape 4, image 2 de 2
    • Remove the 6 - 7.9 mm screws highlighted by the markers using the T-6 head on the screwdriver.
  5. Nokia 6200 Classic Circuit Board Replacement: étape 5, image 1 de 2 Nokia 6200 Classic Circuit Board Replacement: étape 5, image 2 de 2
    • Separate the inside of the phone from the back of the phone.
  6. Nokia 6200 Classic Circuit Board Replacement: étape 6, image 1 de 2 Nokia 6200 Classic Circuit Board Replacement: étape 6, image 2 de 2
    • Gently pull apart the circuit board from the rest of the phone.
    • There is a small connector holding these two pieces together, so use caution when pulling apart so as not to damage it.
To reattach the circuit board, line up the connector at the top of the board with the back of the LCD Screen attachment. Place the two boards together, and screw in the 6 screws.
Reid Polstra
Membre depuis le 10/22/12
1 Réputation
7 tutoriels rédigés
Équipe
Clemson, Team 15-5, Benson Fall 2012 Membre de l'équipe Clemson, Team 15-5, Benson Fall 2012
CLEM-BENSON-F12S15G5
3 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 840
