Aller au contenu principal
Nokia 6590i Logic Board Replacement
Colby Leslie
Colby Leslie et 2 autres contributeurs
Dernière mise à jour le February 19, 2016
10 - 15 minutes
Modérée
Photos d’action
Étudiant en action
This guide will show how to remove the phone's logic board.
Ce dont vous avez besoin
Outils
  1. Nokia 6590i Logic Board Replacement, Battery: étape 1, image 1 de 1
    • Before taking apart your Nokia 6590i, you will need to purchase a new battery. You can find them at Amazon, Walmart, or any cell phone repair store.
    • For reference, pictured here is a photo of a new battery for the Nokia 6590i.
    • Most new batteries will have a price range of $10 to $30.
  2. Nokia 6590i Logic Board Replacement: étape 2, image 1 de 2 Nokia 6590i Logic Board Replacement: étape 2, image 2 de 2
    • After purchasing a new battery, we can begin the replacement.
    • First, press the button on the bottom of the rear cover.
    • Second, keep the button pressed while pulling the cover downward to remove the back cover.
    • Third, lift the cover off.
  3. Nokia 6590i Logic Board Replacement: étape 3, image 1 de 1
    • Then, to remove the old battery, push it down from the top and pull it out.
    • To install the new battery, just follow this guide in reverse order!
  4. Nokia 6590i Logic Board Replacement, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: étape 4, image 1 de 1
    • Grip the front cover from the bottom.
  5. Nokia 6590i Logic Board Replacement: étape 5, image 1 de 1
    • Lift the front cover off.
  6. Nokia 6590i Logic Board Replacement: étape 6, image 1 de 1
    • Remove the six screws using a T6 torx screwdriver.
  7. Nokia 6590i Logic Board Replacement: étape 7, image 1 de 1
    • Insert spudger along edge of assembly and gently lift assembly away from case
  8. Nokia 6590i Logic Board Replacement: étape 8, image 1 de 1
    • Remove assembly from phone
  9. Nokia 6590i Logic Board Replacement, Logic Board: étape 9, image 1 de 1
    • The logic board now sits on top of the phone.
  10. Nokia 6590i Logic Board Replacement: étape 10, image 1 de 1
    • Lift the logic board out of the phone.
Colby Leslie
Membre depuis le 10/05/10
13 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 22-3, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 22-3, Maness Fall 2010
CPSU-MANESS-F10S22G3
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,100
