Aller au contenu principal
Nokia Asha 201 Audio Jack Replacement
Betsy Walker
Betsy Walker et 4 autres contributeurs
Dernière mise à jour le June 7, 2023
7 minutes
Modérée
Nécessite plus d'images
Étapes manquantes
Have you ever tried listening to music on your phone with headphones to only hear no sound? Don't want to spent the money to replace the phone in its entirety? Using this guide, you can easily go step by step to replace your Nokia Asha 201 audio jack and get back to listening to the things you love. There are no special skills required for this guide and the only tools you need are an iFixit opening tool and a T6 Torx screwdriver. Instead of buying a brand new phone, use this guide to take matters into your own hands and replace your audio jack yourself!
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Nokia Asha 201 Audio Jack Replacement, Audio Jack: étape 1, image 1 de 1
    • Remove the white case by popping apart the front and back with your finger.
  2. Nokia Asha 201 Audio Jack Replacement: étape 2, image 1 de 1
    • Remove the battery by taking it out with your fingers.
  3. Nokia Asha 201 Audio Jack Replacement: étape 3, image 1 de 1
    • Remove the two 5.5mm screws by using the T6 screwdriver.
  4. Nokia Asha 201 Audio Jack Replacement: étape 4, image 1 de 1
    • Use the blue plastic opening tool to remove the front of the white case.
  5. Nokia Asha 201 Audio Jack Replacement: étape 5, image 1 de 1
    • Remove the keyboard using your fingers and set aside.
  6. Nokia Asha 201 Audio Jack Replacement: étape 6, image 1 de 1
    • Unscrew the two 5.5mm screws near the bottom of the device on either side using the T6 screwdriver.
  7. Nokia Asha 201 Audio Jack Replacement: étape 7, image 1 de 1
    • Separate the black plastic internal case from the screen by prying with the blue plastic opening tool.
  8. Nokia Asha 201 Audio Jack Replacement: étape 8, image 1 de 1
    • The black plastic cover should now be separated from the motherboard. Replace the audio jack by removing it with your fingers.
Betsy Walker
Membre depuis le 10/10/19
157 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S1-G3, Leahy Fall 2019 Membre de l'équipe USF Tampa, Team S1-G3, Leahy Fall 2019
USFT-LEAHY-F19S1G3
4 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 222
