Aller au contenu principal
Nokia E61i Display Replacement
Christopher Patton
Christopher Patton et 13 autres contributeurs
Dernière mise à jour le February 14, 2025
10 - 15 minutes
Modérée
Étapes manquantes
Photos d’action
A besoin de meilleures images
Meilleure introduction
Use this guide to replace the Nokia E61i screen.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Nokia E61i Display Replacement, Battery: étape 1, image 1 de 2 Nokia E61i Display Replacement, Battery: étape 1, image 2 de 2
    • First, gather all necessary tools.
    • Remove the back cover to access the battery by pushing the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing down on the tab.
  2. Nokia E61i Display Replacement: étape 2, image 1 de 1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Nokia E61i Display Replacement: étape 3, image 1 de 1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Nokia E61i Display Replacement, Front Cover: étape 4, image 1 de 2 Nokia E61i Display Replacement, Front Cover: étape 4, image 2 de 2
    • To remove the top of the back cover, pry the sides and pop it off.
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Nokia E61i Display Replacement: étape 5, image 1 de 1
    • Remove the cover by pulling it up and off.
  6. Nokia E61i Display Replacement, Display: étape 6, image 1 de 2 Nokia E61i Display Replacement, Display: étape 6, image 2 de 2
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon, disconnecting contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  7. Nokia E61i Display Replacement: étape 7, image 1 de 2 Nokia E61i Display Replacement: étape 7, image 2 de 2
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
3 autres ont terminé cette réparation.
Christopher Patton
Membre depuis le 04/07/11
208 Réputation
12 tutoriels rédigés
Équipe
Cal Poly, Team 9-63, Walters Spring 2011 Membre de l'équipe Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 membres
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 3,695
