Aller au contenu principal
Nokia E62 Complete Disassembly
Jose Gustavo Abreu Murta
Jose Gustavo Abreu Murta et 5 autres contributeurs
Dernière mise à jour le May 14, 2019
Aucune estimation
Modérée
Tutoriel réalisé par la communauté
Ce dont vous avez besoin
  1. Nokia E62 Complete Disassembly, Nokia E62 Complete Disassembly: étape 1, image 1 de 1
    • To start, press one of the latches at the top of the phone to open the rear cover.
  2. Nokia E62 Complete Disassembly: étape 2, image 1 de 1
    • Carefully press the other latch.
  3. Nokia E62 Complete Disassembly: étape 3, image 1 de 1
    • Open rear cover by this side.
  4. Nokia E62 Complete Disassembly: étape 4, image 1 de 1
    • Press the three latches to open this side of the cover.
  5. Nokia E62 Complete Disassembly: étape 5, image 1 de 1
    • Remove the rear cover.
  6. Nokia E62 Complete Disassembly: étape 6, image 1 de 1
    • Removed rear cover. See the latches .
  7. Nokia E62 Complete Disassembly: étape 7, image 1 de 1
    • Remove the screws using Torx T6 screw driver.
  8. Nokia E62 Complete Disassembly: étape 8, image 1 de 1
    • Remove six T6 screws.
  9. Nokia E62 Complete Disassembly: étape 9, image 1 de 1
    • Remove the assembly. The front cover will be released.
  10. Nokia E62 Complete Disassembly: étape 10, image 1 de 1
    • The front cover released.
  11. Nokia E62 Complete Disassembly: étape 11, image 1 de 1
    • To remove the display , unscrew the T6 Torx at top.
  12. Nokia E62 Complete Disassembly: étape 12, image 1 de 1
    • CAUTION! Remove the bottom screw with T5 Torx screw driver, not T6 !
  13. Nokia E62 Complete Disassembly: étape 13, image 1 de 1
    • Carefully disconnect the Flex cable connector. Then remove the display.
  14. Nokia E62 Complete Disassembly: étape 14, image 1 de 1
    • Carefully remove the adhesive keyboard membrane.
    • You can replace it at this step if you need to.
  15. Nokia E62 Complete Disassembly: étape 15, image 1 de 1
    • You can clean the keyboard surface with alcohol, if you dropped a drink here.
  16. Nokia E62 Complete Disassembly: étape 16, image 1 de 1
    • When you replace the keyboard membrane, align the two contacts at bottom.
  17. Nokia E62 Complete Disassembly: étape 17, image 1 de 1
    • You can wash the front cover and keyboard if they are dirty.
  18. Nokia E62 Complete Disassembly: étape 18, image 1 de 1
    • Keyboard - clean it if necessary.
  19. Nokia E62 Complete Disassembly: étape 19, image 1 de 1
    • Rear side of the circuit board.
  20. Nokia E62 Complete Disassembly: étape 20, image 1 de 1
    • Speaker and antenna contacts.
  21. Nokia E62 Complete Disassembly: étape 21, image 1 de 1
    • If necessary, you can replace the joystick, the button module or the connector housing.
3 autres ont terminé cette réparation.
Membre depuis le 07/06/10
4 794 Réputation
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 7,073
