Aller au contenu principal
Nokia E90 Front Screen and Front Keypad Replacement
Cameron Weinberg
Cameron Weinberg et 5 autres contributeurs
Dernière mise à jour le January 10, 2025
1 - 2 minutes
Modérée
Outils incorrects
Photos d’action
If your front screen has stopped working and you need a new one, this guide will show you how to access the front screen.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Nokia E90 Front Screen and Front Keypad Replacement, Front Cover: étape 1, image 1 de 1
    • Start with the phone in the flipped open position.
    • You must remove the sticker in the center, below the screen to reveal the center screw.
    • Use a T5 screwdriver to remove all three screws, loosening the front screen.
  2. Nokia E90 Front Screen and Front Keypad Replacement: étape 2, image 1 de 2 Nokia E90 Front Screen and Front Keypad Replacement: étape 2, image 2 de 2
    • Flip the phone to the closed position and turn to the front screen.
    • The front cover will now be loose enough for you to remove by grabbing the edges and lightly pulling the cover off.
  3. Nokia E90 Front Screen and Front Keypad Replacement, Front Screen and Front Keypad: étape 3, image 1 de 1
    • With the front cover off, the screen and keypad should be loose.
  4. Nokia E90 Front Screen and Front Keypad Replacement: étape 4, image 1 de 2 Nokia E90 Front Screen and Front Keypad Replacement: étape 4, image 2 de 2
    • Using a plastic opening tool pry up the cable connecting the LCD screen to the rest of the phone.
    • With the cable disconnected, the screen should be free for removal or replacement.
In order to reassemble the front screen or install a new screen, follow the steps provided, in reverse order.
Cameron Weinberg
Membre depuis le 04/12/11
567 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 18-21, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 18-21, Garner Spring 2011
CPSU-GARNER-S11S18G21
3 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 15
Total : 6,114
