Aller au contenu principal
Nokia N9 Battery Replacement
knipwim
knipwim et 2 autres contributeurs
Dernière mise à jour le December 28, 2022
30 minutes
Facile
Tutoriel réalisé par la communauté
After following this guide, you can replace the battery of the Nokia N9.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Nokia N9 Battery Replacement, remove top parts: étape 1, image 1 de 3 Nokia N9 Battery Replacement, remove top parts: étape 1, image 2 de 3 Nokia N9 Battery Replacement, remove top parts: étape 1, image 3 de 3
    • Click open the USB input protector lid and pull it from the housing.
    • Also remove the SIM card holder.
    • Remove screws from the top using the T3 torx screwdriver.
  2. Nokia N9 Battery Replacement, loosen the screen: étape 2, image 1 de 3 Nokia N9 Battery Replacement, loosen the screen: étape 2, image 2 de 3 Nokia N9 Battery Replacement, loosen the screen: étape 2, image 3 de 3
    • Press your screwdriver against the backside of the white pieces of plastic, and the screen will click out at the top side of the phone.
  3. Nokia N9 Battery Replacement, disconnect screen from phone: étape 3, image 1 de 3 Nokia N9 Battery Replacement, disconnect screen from phone: étape 3, image 2 de 3 Nokia N9 Battery Replacement, disconnect screen from phone: étape 3, image 3 de 3
    • Using a plastic tool, carefully open up the distance between the screen and the housing until the screen is only attached with 2 cables.
    • With the same plastic tool, disconnect the screen cables still attached to the phone.
    • The screen is now separated from the rest of the phone.
  4. Nokia N9 Battery Replacement, remove screws: étape 4, image 1 de 1
    • Unscrew the marked screws using the T4 torx screwdriver.
  5. Nokia N9 Battery Replacement, remove covering: étape 5, image 1 de 2 Nokia N9 Battery Replacement, remove covering: étape 5, image 2 de 2
    • You will see a strip holding the larger battery cover in place at one side.
    • Rotate the strip a quarter turn along the long axis, and lift it out.
    • Use the opening tool to lift the battery cover up and out.
  6. Nokia N9 Battery Replacement, replace the battery: étape 6, image 1 de 2 Nokia N9 Battery Replacement, replace the battery: étape 6, image 2 de 2
    • Click open the battery connector from beneath the connector.
    • Lift the battery from the phone and replace it.
2 autres ont terminé cette réparation.
knipwim
Membre depuis le 09/01/18
11 274 Réputation
36 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 26
30 derniers jours : 58
Total : 3,097
