Aller au contenu principal
Nvidia Shield Pro Android TV Controller Motherboard Replacement
Aidan Shelton
Aidan Shelton et 2 autres contributeurs
Dernière mise à jour le October 17, 2024
30 - 45 minutes
Modérée
Meilleure introduction
The Nvidia Controller Mother Board may fail due to wires becoming undone and the rumble motor not working.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Nvidia Shield Pro Android TV Controller Motherboard Replacement, Thumbsticks: étape 1, image 1 de 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Thumbsticks: étape 1, image 2 de 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Thumbsticks: étape 1, image 3 de 3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 2, image 1 de 1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 3, image 1 de 2 Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 3, image 2 de 2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 4, image 1 de 2 Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 4, image 2 de 2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 5, image 1 de 2 Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 5, image 2 de 2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
  6. Nvidia Shield Pro Android TV Controller Motherboard Replacement, Triggers: étape 6, image 1 de 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Triggers: étape 6, image 2 de 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Triggers: étape 6, image 3 de 3
    • Use a Torx T6 screwdriver to remove the two 7 mm screws from the triggers (one on each trigger).
    • Use a Torx T5 screwdriver to remove the two 5 mm screws securing the motherboard.
    • Gently lift the motherboard from the controller housing.
  7. Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 7, image 1 de 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 7, image 2 de 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement: étape 7, image 3 de 3
    • Use a Torx T5 screwdriver to remove the two 5 mm screws from the motherboard.
    • Carefully pull the trigger directly out of its socket.
  8. Nvidia Shield Pro Android TV Controller Motherboard Replacement, Controller Motherboard: étape 8, image 1 de 1
    • After removing the triggers, your motherboard is completely separate and ready to be replaced.
Your motherboard is ready to be replaced.
Aidan Shelton
Membre depuis le 02/11/22
73 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 16
Total : 336
