Aller au contenu principal
Nvidia Shield Pro Android TV Controller Rumble Motor Replacement
Andrew Boyce Hanson
Andrew Boyce Hanson et 2 autres contributeurs
Dernière mise à jour le October 17, 2024
20 - 30 minutes
Modérée
Meilleure introduction
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Thumbsticks: étape 1, image 1 de 3 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Thumbsticks: étape 1, image 2 de 3 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Thumbsticks: étape 1, image 3 de 3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: étape 2, image 1 de 1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: étape 3, image 1 de 2 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: étape 3, image 2 de 2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: étape 4, image 1 de 2 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: étape 4, image 2 de 2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: étape 5, image 1 de 2 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: étape 5, image 2 de 2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
  6. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Rumble Motors: étape 6, image 1 de 3 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Rumble Motors: étape 6, image 2 de 3 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Rumble Motors: étape 6, image 3 de 3
    • Grip the plugs as close to their ports as possible and pull them directly up and out.
    • Lift the rumble motors up and out of the chassis.
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 202
