Aller au contenu principal
Nvidia Shield Pro Android TV Controller Thumbsticks Replacement
Ben Carrasco
Ben Carrasco et 5 autres contributeurs
Dernière mise à jour le October 17, 2024
30 minutes
Facile
If the thumbsticks on your Nvidia Shield Pro Android TV controller are unresponsive or are behaving irregularly, use this guide to replace them. The tools you will need are a T6 Torx screwdriver and a plastic opening tool. The process is simple, but gently remove the thumbstick you intend to replace as to not damage the plastic.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement, Thumbsticks: étape 1, image 1 de 3 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement, Thumbsticks: étape 1, image 2 de 3 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement, Thumbsticks: étape 1, image 3 de 3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: étape 2, image 1 de 1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: étape 3, image 1 de 2 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: étape 3, image 2 de 2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: étape 4, image 1 de 2 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: étape 4, image 2 de 2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: étape 5, image 1 de 2 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: étape 5, image 2 de 2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
3 autres ont terminé cette réparation.
Ben Carrasco
Membre depuis le 01/23/20
347 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S18-G2, White Winter 2020 Membre de l'équipe Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 membres
12 tutoriels rédigés
3 commentaires de tutoriel
Very good instructions that were very helpful. Do you have recommendations on which thumbsticks are the best since the shield seems to have wider and deeper ones? Thanks again for the guide.
Charles Brodie - Réponse
Just wondering where would I be able to buy a thumbstick spare part to replace it.
xguyun - Réponse
Thanks, very good post, and it could be very useful for me. Just wondering where would I be able to buy a spare part for this thumbstick to replace my broken one.
xguyun - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 51
Total : 2,049
