Aller au contenu principal
OnePlus 7T Screen Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. OnePlus 7T Screen Replacement, OnePlus 7T Screen Replacement: étape 1, image 1 de 3 OnePlus 7T Screen Replacement, OnePlus 7T Screen Replacement: étape 1, image 2 de 3 OnePlus 7T Screen Replacement, OnePlus 7T Screen Replacement: étape 1, image 3 de 3
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  2. OnePlus 7T Screen Replacement: étape 2, image 1 de 2 OnePlus 7T Screen Replacement: étape 2, image 2 de 2
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
    • An iFixit iOpener, hairdryer, or hot plate can also be used to heat the edges. See the iOpener Heating guide for instructions on using the iOpener.
  3. OnePlus 7T Screen Replacement: étape 3, image 1 de 3 OnePlus 7T Screen Replacement: étape 3, image 2 de 3 OnePlus 7T Screen Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    • Apply a suction cup to the lower portion of the phone's backing and pull firmly to create a crack between the back cover and the rest of the phone.
    • Insert a Jimmy tool, opening pick, or plastic card under the edge of the back cover.
  4. OnePlus 7T Screen Replacement: étape 4, image 1 de 2 OnePlus 7T Screen Replacement: étape 4, image 2 de 2
    • Use a plastic card or Jimmy tool to slice around the phone's seam, cutting through the adhesive.
  5. OnePlus 7T Screen Replacement: étape 5, image 1 de 3 OnePlus 7T Screen Replacement: étape 5, image 2 de 3 OnePlus 7T Screen Replacement: étape 5, image 3 de 3
    • Remove the phone's back cover.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
  6. OnePlus 7T Screen Replacement: étape 6, image 1 de 1
    • Use a Phillips screwdriver to remove the 11 screws from the plastic motherboard cover.
  7. OnePlus 7T Screen Replacement: étape 7, image 1 de 3 OnePlus 7T Screen Replacement: étape 7, image 2 de 3 OnePlus 7T Screen Replacement: étape 7, image 3 de 3
    • Use a spudger to pry up the plastic motherboard cover.
    • Remove the plastic motherboard cover.
  8. OnePlus 7T Screen Replacement: étape 8, image 1 de 2 OnePlus 7T Screen Replacement: étape 8, image 2 de 2
    • Use the flat end of a spudger to disconnect all flex cables leading to the motherboard.
  9. OnePlus 7T Screen Replacement: étape 9, image 1 de 3 OnePlus 7T Screen Replacement: étape 9, image 2 de 3 OnePlus 7T Screen Replacement: étape 9, image 3 de 3
    • Grasp the red battery tab with your fingers.
    • Pull upwards on the tab and remove the battery.
  10. OnePlus 7T Screen Replacement: étape 10, image 1 de 3 OnePlus 7T Screen Replacement: étape 10, image 2 de 3 OnePlus 7T Screen Replacement: étape 10, image 3 de 3
    • Use a pair of tweezers to grasp the end of the flex cables that were just disconnected.
    • Gently pull the cables backwards so that they remain bent back from the phone's motherboard area.
  11. OnePlus 7T Screen Replacement: étape 11, image 1 de 2 OnePlus 7T Screen Replacement: étape 11, image 2 de 2
    • Use a heat gun to lightly heat the edges of the phone's screen to soften the adhesive that connects the display to the rest of the frame.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges. Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges. Follow the iOpener Heating guide for instructions on using the iOpener.
  12. OnePlus 7T Screen Replacement: étape 12, image 1 de 3 OnePlus 7T Screen Replacement: étape 12, image 2 de 3 OnePlus 7T Screen Replacement: étape 12, image 3 de 3
    • Apply a suction cup to the lower portion of the phone's display and pull firmly to create a crack between the screen and the rest of the phone.
    • Insert a Jimmy tool, opening pick, or plastic card under the edge of the phone's display.
  13. OnePlus 7T Screen Replacement: étape 13, image 1 de 2 OnePlus 7T Screen Replacement: étape 13, image 2 de 2
    • Carefully remove the phone's display.
    • A flex cable is still attached to the back of the phone's display. Make sure the cable does not become caught when removing the display.
3 autres ont terminé cette réparation.
Selena
Membre depuis le 12/15/19
2 866 Réputation
14 tutoriels rédigés
1 commentaire de tutoriel
There needs to be steps on how to reseal the device after the replacement.
Asd - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 20
30 derniers jours : 213
Total : 12,944
