Aller au contenu principal
Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement
Ian
Ian et 3 autres contributeurs
Dernière mise à jour le August 6, 2024
25 - 30 minutes
Très difficile
A besoin de meilleures images
Nécessite plus d'images
Étapes manquantes
If your Oontz Angle 3 ULTRA speaker is playing faulty audio with a 3.5mm auxiliary cable, you may need to replace your speaker’s 3.5mm auxiliary port. This replacement guide will walk you through replacing the 3.5mm auxiliary port of your Oontz Angle 3 ULTRA Bluetooth speaker. For this guide, you will need a plastic spudger, a Soldering Iron, and Solder Wick or a Solder Sucker. Follow this guide to learn how to solder and de-solder connections.
Warning: This guide is missing a crucial step between steps 4 and 5. The original author of this guide did not include the steps to remove the daughterboard from the device.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Back Panel: étape 1, image 1 de 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Back Panel: étape 1, image 2 de 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Back Panel: étape 1, image 3 de 3
    Outil utilisé dans cette étape :
    • Remove the two black rubber sheaths around the edges of the speaker.
    • Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
    • On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
  2. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: étape 2, image 1 de 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: étape 2, image 2 de 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: étape 2, image 3 de 3
    • Use a JIS #0 screwdriver to remove the six screws to expose the motherboard.
  3. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: étape 3, image 1 de 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: étape 3, image 2 de 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: étape 3, image 3 de 3
    • Using a pair of tweezers, pinch and pull the rubber fillings obstructing the screws.
  4. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: étape 4, image 1 de 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: étape 4, image 2 de 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: étape 4, image 3 de 3
    • Using a JIS #0 screwdriver, remove the 6 screws holding the backplate in.
    • Remove the back panel off of the device.
  5. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Auxiliary Port: étape 5, image 1 de 1
    • With your solderwick and soldering iron, remove the solder at each point, and gently pull the 3.5mm port away from the motherboard with your tweezers.
    • For more information on soldering and desoldering connections, please visit the How to Solder and Desolder Connections guide.
Ian
Membre depuis le 01/16/20
386 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 15
Total : 241
