Aller au contenu principal
Opening the Column in the Hamilton Galileo
Ian Van Sciver
Ian Van Sciver et un autre contributeur
Dernière mise à jour le July 3, 2020
3 minutes
Facile
Utilize this guide to access inside the column, a step required for other guides such as replacing the power supply. For more information on opening the column, please refer to page 11-6 in the full service manual.
Ce dont vous avez besoin
  1. Opening the Column in the Hamilton Galileo, Opening the Column in the Hamilton Galileo: étape 1, image 1 de 1
    • Use a grounding cable and wrist band connected to the GALILEO or other work surface when you are working on the GALILEO.
    • Remove from GALILEO: External mains power supply, Air and oxygen supplies, Patient breathing circuit (for convenience only), Flow Sensor tubes (for convenience only).
  2. Opening the Column in the Hamilton Galileo: étape 3, image 1 de 1
    • Loosen the rear panel of the column by removing the six hexagonal-drive (Allen) screws that hold it in place.
  3. Opening the Column in the Hamilton Galileo: étape 4, image 1 de 2 Opening the Column in the Hamilton Galileo: étape 4, image 2 de 2
    • Without removing any electrical connections, open the left side of the column as wide as practical.
    • This exposes: GALILEO’s internal power supply, The battery fuse, The diagnostic LEDs on the power supply’s main circuit board, and the back up batteries.
    • Make sure no electrical connections are touching the column.
    • Make sure all green/brown grounding (earthing) cables are securely in place.
Ian Van Sciver
Membre depuis le 04/09/20
332 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S7-G26, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S7-G26, Paton Spring 2020
CPSU-PATON-S20S7G26
3 membres
4 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 152
