Aller au contenu principal
Philips Norelco 5801XL Front and Back Housing Replacement
Ben Gibbs
Ben Gibbs et 7 autres contributeurs
Dernière mise à jour le July 15, 2024
10 - 20 minutes
Facile
We will show how to replace the housing of the device, on both the front or rear. This guide will be useful if the housing is cracked or broken, not so much so if the device itself does not work. No special skills are required for this easy fix! Prior to beginning the assembly please purchase replacements from the links provided on the troubleshooting page.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Philips Norelco 5801XL Front and Back Housing Replacement, Front and/or back housing: étape 1, image 1 de 2 Philips Norelco 5801XL Front and Back Housing Replacement, Front and/or back housing: étape 1, image 2 de 2
    • Remove the two T8 2 mm Phillips screws on the back housing.
  2. Philips Norelco 5801XL Front and Back Housing Replacement: étape 2, image 1 de 2 Philips Norelco 5801XL Front and Back Housing Replacement: étape 2, image 2 de 2
    • Separate the back housing and the front housing using the plastic opening tool.
  3. Philips Norelco 5801XL Front and Back Housing Replacement: étape 3, image 1 de 3 Philips Norelco 5801XL Front and Back Housing Replacement: étape 3, image 2 de 3 Philips Norelco 5801XL Front and Back Housing Replacement: étape 3, image 3 de 3
    • Using the plastic opening tool, carefully pry the inside of the middle bracket towards the outside of the housing in order to remove it.
  4. Philips Norelco 5801XL Front and Back Housing Replacement: étape 4, image 1 de 1
    • Remove the two T8 2 mm screws near the bottom of the device.
    • Remove the bracket the screws were holding in place.
  5. Philips Norelco 5801XL Front and Back Housing Replacement: étape 5, image 1 de 1
    • Insert the plastic opening tool into the charging port and push inwards.
  6. Philips Norelco 5801XL Front and Back Housing Replacement: étape 6, image 1 de 1
    • Remove the two T8 2 mm screws near the top of the device shown here.
  7. Philips Norelco 5801XL Front and Back Housing Replacement: étape 7, image 1 de 3 Philips Norelco 5801XL Front and Back Housing Replacement: étape 7, image 2 de 3 Philips Norelco 5801XL Front and Back Housing Replacement: étape 7, image 3 de 3
    • Cautiously lift and twist the circuit board, then begin sliding the inside assembly forward.
    • After sliding it forward, the whole assembly will separate from the rear housing.
  8. Philips Norelco 5801XL Front and Back Housing Replacement: étape 8, image 1 de 1
    • The housing and the inside assembly should be completely separated.
Now, you can put the new housing on. To reassemble your device, follow these instructions in reverse order.
Ben Gibbs
Membre depuis le 02/16/16
361 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 3-2, Harley Spring 2016 Membre de l'équipe IUPUI, Team 3-2, Harley Spring 2016
IUPUI-HARLEY-S16S3G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 633
