Aller au contenu principal
Philips Norelco BeardTrimmer 3100 Blade Replacement
Darren Chu
Darren Chu et 4 autres contributeurs
Dernière mise à jour le July 15, 2024
5 minutes
Facile
If the blades of your beard trimmer are not working properly, there could be too much hair/dirt between the blades or the blade may have become worn out over time. The blade may need replacement. By following the steps in this guide you will have a new blade installed in no time.
Ce dont vous avez besoin
Outils
  1. Philips Norelco BeardTrimmer 3100 Blade Replacement, Blade: étape 1, image 1 de 1
    • Remove the comb from the head of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Blade Replacement: étape 2, image 1 de 2 Philips Norelco BeardTrimmer 3100 Blade Replacement: étape 2, image 2 de 2
    • Place thumb underneath the blade; push upward to pop the blade off.
  3. Philips Norelco BeardTrimmer 3100 Blade Replacement: étape 3, image 1 de 3 Philips Norelco BeardTrimmer 3100 Blade Replacement: étape 3, image 2 de 3 Philips Norelco BeardTrimmer 3100 Blade Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    • Grab the plastic arms with the tweezers and pull them apart from the base.
  4. Philips Norelco BeardTrimmer 3100 Blade Replacement: étape 4, image 1 de 3 Philips Norelco BeardTrimmer 3100 Blade Replacement: étape 4, image 2 de 3 Philips Norelco BeardTrimmer 3100 Blade Replacement: étape 4, image 3 de 3
    • Remove the plastic casing from the underside of the blade.
  5. Philips Norelco BeardTrimmer 3100 Blade Replacement: étape 5, image 1 de 3 Philips Norelco BeardTrimmer 3100 Blade Replacement: étape 5, image 2 de 3 Philips Norelco BeardTrimmer 3100 Blade Replacement: étape 5, image 3 de 3
    • Remove the last plastic casing from the front side of the blade.
  6. Philips Norelco BeardTrimmer 3100 Blade Replacement: étape 6, image 1 de 2 Philips Norelco BeardTrimmer 3100 Blade Replacement: étape 6, image 2 de 2
    • Pull the spring off from the base with the tweezers.
  7. Philips Norelco BeardTrimmer 3100 Blade Replacement: étape 7, image 1 de 1
    • Pull the blade apart from the base with the tweezers.
21 autres ont terminé cette réparation.
Darren Chu
Membre depuis le 09/03/15
1 617 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 15-2, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 15-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G2
4 membres
14 tutoriels rédigés
10 commentaires
what about getting it back togeather
andrewv100 - Réponse
Sadly it is impossible to put the parts back together. It isnt just as simple as start with the end. Normally i am quite good with fixing stuff. But this time... maybe because mine is broken? A guide for putting it back together should show me where it g9es wrong. But thanks for the guide anyways, thanks for the time you put into it.
Bart Teeuwen - Réponse
Now I can't get it back :-(
AbdulJalil - Réponse
Buy a new one. It not worth the time and effort unless you're trying to get away from the wife
zorba - Réponse
It's easy to get it back.i assembled mine a lot of times... Guys just try
tarangill.zippy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 35
Total : 22,538
