Aller au contenu principal
Philips Norelco MultiGroom 3100 Battery  Replacement
Mahmoud
Mahmoud et 3 autres contributeurs
Dernière mise à jour le July 16, 2024
15 - 25 minutes
Modérée
This guide will demonstrate how to change the battery of a Philips Norelco MultiGroom 3100. Tear down/reassembly requires a plastic spudger and soldering equipment.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Philips Norelco MultiGroom 3100 Battery  Replacement, Power Button: étape 1, image 1 de 1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco MultiGroom 3100 Battery  Replacement: étape 2, image 1 de 2 Philips Norelco MultiGroom 3100 Battery  Replacement: étape 2, image 2 de 2
    • Grip the attachment and twist it counterclockwise until you hear a click.
    • Pull the attachment up to remove it from the trimmer.
  3. Philips Norelco MultiGroom 3100 Battery  Replacement: étape 3, image 1 de 2 Philips Norelco MultiGroom 3100 Battery  Replacement: étape 3, image 2 de 2
    • Hold the trimmer upright so it is facing you.
    • Insert the plastic opening tool in the gap at the top of the power button.
  4. Philips Norelco MultiGroom 3100 Battery  Replacement: étape 4, image 1 de 1
    • Apply pressure to pry off the power button.
  5. Philips Norelco MultiGroom 3100 Battery  Replacement, Casing: étape 5, image 1 de 2 Philips Norelco MultiGroom 3100 Battery  Replacement, Casing: étape 5, image 2 de 2
    • Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
    • Separate the bezel one clip at a time so that the clips do not break.
  6. Philips Norelco MultiGroom 3100 Battery  Replacement: étape 6, image 1 de 2 Philips Norelco MultiGroom 3100 Battery  Replacement: étape 6, image 2 de 2
    • Insert the spudger in the indicated hole and apply a tilting force to loosen the outer casing.
    • Pull upward on the top of the inner housing to remove it from the outer casing.
  7. Philips Norelco MultiGroom 3100 Battery  Replacement, Battery: étape 7, image 1 de 1
    • Grab the upper casing firmly and pull to seperate from lower casing.
    • This will require some force and may separate suddenly.
  8. Philips Norelco MultiGroom 3100 Battery  Replacement: étape 8, image 1 de 1
    • Once upper casing is removed, use plastic spudger and insert into the side tabs to free battery casing.
    • Once tabs are freed, pull battery casing from upper casing.
    • Upper casing will not separate from tab separation alone, removal will still require manipulation by hand.
  9. Philips Norelco MultiGroom 3100 Battery  Replacement: étape 9, image 1 de 1
    • Insert plastic spudger into battery brackets individually. "Wiggle" the bracket out of place
    • Be careful to not bend bracket severely --brackets will need to fit back into place later.
  10. Philips Norelco MultiGroom 3100 Battery  Replacement: étape 10, image 1 de 1
    • Use a soldering gun and apply heat to the battery contact tabs until solder is malleable.
    • Once solder is malleable, carefully insert a plastic spudger beneath the tab and over the battery to pry battery away from the contact tab.
    • Use proper safety equipment when operating a soldering gun, as burns can occur. Gloves and eye protection recommended.
  11. Philips Norelco MultiGroom 3100 Battery  Replacement: étape 11, image 1 de 1
    • Once contact tabs have been removed from the battery, the battery can now be removed by hand or by use of a plastic spudger.
    • Locate new battery and prepare for soldering in next step.
  12. Philips Norelco MultiGroom 3100 Battery  Replacement: étape 12, image 1 de 1
    • Make sure battery is safely secured and re-solder the battery contact tab onto new battery.
    • Check that contact tab is re-soldered onto the original solder.
    • Once solder is dried and cool, toggle the power switch (not the power button) to check that the device is functional.
    • Make sure solder adequately covers the contact tab so the solder will not break in the future
    • Solder with caution. Use gloves and eye protection. Solder contains lead, work in a properly ventilated area.
Ligne d'arrivée
15 autres ont terminé cette réparation.
Mahmoud
Membre depuis le 09/05/17
101 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S1-G5, Freund Fall 2017 Membre de l'équipe IUPUI, Team S1-G5, Freund Fall 2017
IUPUI-FREUND-F17S1G5
4 membres
2 tutoriels rédigés
10 commentaires de tutoriel
Capitalize Battery in the Title
Go ahead and upload the picture of the device.
Be sure to submit to iFixit for their comments when done.
Linda Freund - Réponse
Also include prerequisite guides
For the Multigroom QG3380 (which I bought at Costco in Canada), there are some differences. Don’t remove the power button – not needed. Pry off the silver frame – very hard not to break some clips. It uses two 750 mAh AAA NiMH batteries (Suppo HSY-AAA0). I’ve ordered 900 mAh batteries with clips to replace these.
Brian Panhuyzen - Réponse
Where did you order the replacement batteries ?
Ferdinando Anceschi -
I had mine from Japan, QG3380 too many clips broke off and indeed don’t remove the power button on that one.
alexander_binder -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 33
30 derniers jours : 145
Total : 31,457
