Aller au contenu principal
Philips Norelco MultiGroom 3100 Casing Replacement
ahaharevolution
ahaharevolution et un autre contributeur
Dernière mise à jour le July 16, 2024
5 - 10 minutes
Modérée
This guide will show you how to remove the casing in order to access the battery and motor.
Ce dont vous avez besoin
Outils
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
  1. Philips Norelco MultiGroom 3100 Casing Replacement, Power Button: étape 1, image 1 de 1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco MultiGroom 3100 Casing Replacement: étape 2, image 1 de 2 Philips Norelco MultiGroom 3100 Casing Replacement: étape 2, image 2 de 2
    • Grip the attachment and twist it counterclockwise until you hear a click.
    • Pull the attachment up to remove it from the trimmer.
  3. Philips Norelco MultiGroom 3100 Casing Replacement: étape 3, image 1 de 2 Philips Norelco MultiGroom 3100 Casing Replacement: étape 3, image 2 de 2
    • Hold the trimmer upright so it is facing you.
    • Insert the plastic opening tool in the gap at the top of the power button.
  4. Philips Norelco MultiGroom 3100 Casing Replacement: étape 4, image 1 de 1
    • Apply pressure to pry off the power button.
  5. Philips Norelco MultiGroom 3100 Casing Replacement, Casing: étape 5, image 1 de 2 Philips Norelco MultiGroom 3100 Casing Replacement, Casing: étape 5, image 2 de 2
    • Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
    • Separate the bezel one clip at a time so that the clips do not break.
  6. Philips Norelco MultiGroom 3100 Casing Replacement: étape 6, image 1 de 2 Philips Norelco MultiGroom 3100 Casing Replacement: étape 6, image 2 de 2
    • Insert the spudger in the indicated hole and apply a tilting force to loosen the outer casing.
    • Pull upward on the top of the inner housing to remove it from the outer casing.
9 autres ont terminé cette réparation.
ahaharevolution
Membre depuis le 10/04/15
771 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-1, Leahy Fall 2015 Membre de l'équipe USF Tampa, Team 1-1, Leahy Fall 2015
USFT-LEAHY-F15S1G1
2 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 22
Total : 5,227
