Aller au contenu principal
Polaroid LCD-0700P Case Replacement
Mario T
Mario T et 11 autres contributeurs
Dernière mise à jour le January 8, 2025
5 minutes
Facile
Étapes manquantes
Meilleure introduction
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Polaroid LCD-0700P Case Replacement, Case: étape 1, image 1 de 2 Polaroid LCD-0700P Case Replacement, Case: étape 1, image 2 de 2
    • Turn the entire device over, so that the underside of the device is facing upward.
    • With the underside of the device facing up, locate the 11mm screw found in each far corner of the device. Remove the single 11mm screw from each of the four corners, using the Phillips #0 screwdriver.
  2. Polaroid LCD-0700P Case Replacement: étape 2, image 1 de 2 Polaroid LCD-0700P Case Replacement: étape 2, image 2 de 2
    • Turn the device so that the underside faces you, and the edge where the case and device bind, faces upward. The opening of the device should be face down.
    • In this position you will see a crease line between the device and the top cover. Gently Insert your blue plastic opening tool into the crack of the crease line, between the front and back cover to separate them.
    • Be careful when separating the front and back covers, as the two are held together by a thin wire.
    • Separate the halves of the case.
  3. Polaroid LCD-0700P Case Replacement: étape 3, image 1 de 1
    • Locate the input/output board on the top left hand corner of the device. It will look like a green circuit board with wires protruding and connecting to the case cover.
    • Using your blue plastic opening tool, disconnect the multicolored wires located on the input/output board. These will be the same multicolored wires that connect the back cover to the input/output board.
Mario T
Membre depuis le 01/09/12
466 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 8-14, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 8-14, Maness Winter 2012
CPSU-MANESS-W12S8G14
4 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 1,944
