Proximity Switch Replacement - BallyPal
Introduction
Passez à l'étape 1To replace the BallyPal Proximity Switch, follow the steps below:
Ce dont vous avez besoin
Outils
Document vedette
Park the BallyPal and activate the emergency stop button.
Use an Allen wrench to unbolt the two (2) 6mm screws on the Display Panel Assembly. Set aside.
Unplug the connector from the switch.
Using a cross-tip screwdriver, remove the switch from the tiller assembly.
Replace with the new interlock (proximity) switch.
Reuse screws to secure switch.
Insert and tighten screws with Allen wrench to secure the Display Panel Assembly.
Proximity switch has been replaced. Technician should perform an Operations Check to confirm unit is ready for store use.
