Aller au contenu principal
Réparer "Joystick Drift" manette Nintendo Switch Pro
Ce dont vous avez besoin
  1. Réparer "Joystick Drift" manette Nintendo Switch Pro, Retirer les poignées: étape 1, image 1 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Retirer les poignées: étape 1, image 2 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Retirer les poignées: étape 1, image 3 de 3
    • Dévissez les deux vis noires tout en bas de la manette à l'aide d'un tournevis cruciforme #00.
    • Vous pouvez utiliser un tournevis de taille différente ou un tournevis plat, cependant cela risque de rayer ou d'endommager les vis et de compliquer l'opération à l'avenir.
    • Retirez les poignées de la manette.
    Phillips #0 screwdriver did not fit into the screw and stripped it. #00 worked on the other screw, but now I'm unable to continue the teardown.
    Mitchell Harding - Réponse
    The screws are screwed in too tight by the factory that put it together, it can't be undone by hand, because all it did was strip the screw entirely. Need a powered tool to undo the screws.
    Alkaris - Réponse
    These are JIS #00 screws! DO NOT USE PHILIPS else you get stripped heads. Like me. Get a JIS screwdriver set for this breakdown.
    Christian Manahan - Réponse
    @christianma5187, thanks for the tip! I wish I'd read your comment and understood the difference between phillips and jis before I tried using the ph #00 and completely stripped one of the screws. I couldn't find a screw extractor small enough, and in the end I had to cut off the entire hand grip sleeve and get a new one. I hope nobody else makes the same mistake!
    Mike - Réponse
  2. Réparer "Joystick Drift" manette Nintendo Switch Pro, Retirer la plaque: étape 2, image 1 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Retirer la plaque: étape 2, image 2 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Retirer la plaque: étape 2, image 3 de 3
    • Dévissez les quatre vis argentées du dos de la manette avec un tournevis cruciforme #00.
    • Tenez la manette comme sur la troisième photo, les pouces placés surle haut de la manette. Utilisez vos pouces pour démonter la plaque arrière du reste de la manette.
    • Il se peut que vous ayez à forcer un peu pour enlever la plaque.
    When reassembling, don't forget to put the battery back in. I know it seems stupid, but I have taken apart many pro controllers and constantly set the battery to the side, just to forget about and scratch my head and wonder why the controller isn't working.
    Caden Helm - Réponse
  3. Réparer "Joystick Drift" manette Nintendo Switch Pro, Retirer la batterie: étape 3, image 1 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Retirer la batterie: étape 3, image 2 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Retirer la batterie: étape 3, image 3 de 3
    • Bouchez le trou gauche de la batterie avec un de vos doigts.
    • Aidez-vous du petit onglet sur le côté de la batterie pour la retirer de la manette.
  4. Réparer "Joystick Drift" manette Nintendo Switch Pro, Séparer la manette: étape 4, image 1 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Séparer la manette: étape 4, image 2 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Séparer la manette: étape 4, image 3 de 3
    • Enlevez les cinq vis noires de la manette entourées sur la photo avec le tournevis cruciforme #0.
    • Retirez la face avant du reste de la manette en mettant votre doigt dans l'ouverture créée suite au retrait des vis.
    • Ne forcez pas trop afin de ne pas déchirer la nappe qui relie les deux moitiés de la manette.
    • Le tournevis Mako Driver d'iFixitest trop épais pour atteindre correctement les deux vis du milieu en haut. La vis centrale en haut à gauche ne peut être atteinte qu'avec un léger angle, tandis que la vis centrale en haut à droite est presque impossible à atteindre sans utiliser l'extension flexible ou déformer un peu le plastique.
    • Le Mako Driver d'iFixit est également inclus dans les Pro Tech Toolkit.
    Ich besitze das ProTech-Set und hatte keine passende Verlängerung parat. Mir hat geholfen, einfach ein bisschen Taschentuchfetzen zwischen dem Bithalter und dem #00 Kreuz-Bit zu packen. Hat das Problem erstaunlicherweise super gelöst, kann ich empfehlen!
    DafuqRené - Réponse
    I couldn't get the middle top-right screw even with the Flex Extension and using wire cutters to nibble away some of the plastic. My son found a way, though. The bit could get in there, but neither holder. He set the Phillips #00 bit on the screw, pushed it down with a finger, then used needle nosed pliers to turn the bit.
    JT19 - Réponse
  5. Réparer "Joystick Drift" manette Nintendo Switch Pro, Retirer les capuchons des joysticks: étape 5, image 1 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Retirer les capuchons des joysticks: étape 5, image 2 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Retirer les capuchons des joysticks: étape 5, image 3 de 3
    • Retenez le dos de la manette contenant les joysticks avec une main. Utilisez votre main pour tirer soigneusement sur les capuchon en caoutchouc des joysticks et les retirer de leur socle.
    • Il se peut que vous ayez besoin de forcer un peu pour retirer les capuchons.
  6. Réparer "Joystick Drift" manette Nintendo Switch Pro, Nettoyer les saletés: étape 6, image 1 de 2 Réparer "Joystick Drift" manette Nintendo Switch Pro, Nettoyer les saletés: étape 6, image 2 de 2
    • Pulvérisez de l'air comprimé sur et autour des joysticks afin d'enlever tout résidu.
    • Il se peut que certains résidus ne partent pas avec l'air comprimé. Dans ce cas, vous pouvez enlever l'accumulation de poussière avec de l'essuie-tout ou un coton-tige et réutiliser la bonbonne d'air comprimé.
    • Veillez à bien lire les consignes d'utilisation sur la bonbonne d'air comprimé. La secouer peut résulter à l'expulsion de liquide au lieu d'air, ce qui risque d'endommager la manette.
    You may also want to use contact cleaner on the sticks.
    In my case just using compressed air did not fix the drift, I also had to use contact cleaner, after which the drift was completely fixed.
    Ashley Allen - Réponse
  7. Réparer "Joystick Drift" manette Nintendo Switch Pro, Réinsérer les capuchons des joysticks: étape 7, image 1 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Réinsérer les capuchons des joysticks: étape 7, image 2 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Réinsérer les capuchons des joysticks: étape 7, image 3 de 3
    • Réinsérez les capuchons sur les joysticks en appuyant dessus.
    • L'intérieur de chaque capuchon comprend un trou ovale. Faites attention à bien aligner le trou avec la tête ovale du joystick.
  8. Réparer "Joystick Drift" manette Nintendo Switch Pro, Réunir les deux moitiés: étape 8, image 1 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Réunir les deux moitiés: étape 8, image 2 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Réunir les deux moitiés: étape 8, image 3 de 3
    • Réassemblez les deux moitiés de la manette. Elles devraient s'emboîter facilement.
    • Faites attention à bien positionner la nappe intérieure afin qu'elle ne ressorte pas de la manette une fois les deux moitiés réassemblées.
    • Revissez les cinq vis noires au dos de la manette à l'aide du tournevis cruciforme #00.
  9. Réparer "Joystick Drift" manette Nintendo Switch Pro, Réinsérer la batterie: étape 9, image 1 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Réinsérer la batterie: étape 9, image 2 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Réinsérer la batterie: étape 9, image 3 de 3
    • Remettez la batterie dans le trou en faisant attention à bien aligner les connecteurs de la batterie à ceux du compartiment de la batterie.
  10. Réparer "Joystick Drift" manette Nintendo Switch Pro, Réinstaller la plaque arrière: étape 10, image 1 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Réinstaller la plaque arrière: étape 10, image 2 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Réinstaller la plaque arrière: étape 10, image 3 de 3
    • Emboîtez la plaque du dos de la manette comme sur la photo.
    • Vissez les quatre vis argentées à l'aide du tournevis cruciforme #00.
  11. Réparer "Joystick Drift" manette Nintendo Switch Pro, Réinstaller les poignées: étape 11, image 1 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Réinstaller les poignées: étape 11, image 2 de 3 Réparer "Joystick Drift" manette Nintendo Switch Pro, Réinstaller les poignées: étape 11, image 3 de 3
    • Rattachez les poignées en les faisant glisser sur les extrémités de la manette.
    • Sécurisez-les en vissant les deux vis restantes au bout des poignées avec le tournevis cruciforme #00.
    這玩意兒唯一的修復方法就是丟在垃圾桶,只要不是連switch, 連線其他系統切換畫面就會漂移,
    雷格神 - Réponse
Après avoir suivi ces étapes, votre manette devrait être plus propre qu'avant et fonctionner tout aussi bien que n'importe quelle autre manette à 70 € !
Si vous remarquez toujours ce drift, alors le problème vient du joystick. Vous pouvez opter pour un remplacement du joystick même. Les pièces détachées sont facilement accessibles en ligne, mais cela nécessitera potentiellement de souder lesdites pièces afin de les installer sur la manette.
58 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Raul Sanchez
Membre depuis le 03/21/22
1 738 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 4-67, Briggs Spring 2022 Membre de l'équipe CSU Los Angeles, Team 4-67, Briggs Spring 2022
CSULA-BRIGGS-S22S4G67
1 membre
8 tutoriels rédigés
13 commentaires
Excellent. Really clear guide. Thank you so much
Darren Townsend - Réponse
Worked like a charm! Thank you!
Patrick Meade - Réponse
My controller has been having this issue, I've been opening it up and dusting the stick, but that only temporarily fixes this issue. I am considering replacing the stick module, although I am a bit worried that something else is causing drift. Its possible that the shell or upper stick part has worn out or has some sort of opening which is allowing dust and other particles to get into the stick. Any advice?
MikeyLORR - Réponse
This is the first thing I have used my iFixit kit to try and fix and it worked perfectly. Thanks for a very helpful and clear to follow guide.
Ben Johnson - Réponse
A couple of warnings:
You need a long, thin screwdriver like the one listed under tools, but PH00 instead of PH0. My screwdriver with swappable bits could not fit in the holes for the top two screws in step 4.
Also, be super careful with the black screws as they strip really easily.
Thor - Réponse
I was lucky and had a very long ph00 lying around that came with a toy from the dollar store I bought over 15 years ago. My usual repair kit couldn’t reach the deep screws next to the battery, but that screwdriver saved the day. Excellent guide regardless.
Dingleberg - Réponse
This was the first time I used Ifixit. It worked perfectly, thanks a lot, saved my money, better repair than buy something new!
Wilfried Kraus - Réponse
Merci beaucoup, j'ai pu régler le problème :)
Loïc Ovigne - Réponse
My controller has gone from 'almost unusable' to 'most accurate controller I've ever seen'. It's absolutely brand-new again.
Adonis D. Prince - Réponse
兄弟, 十分感谢。这个攻略干货十足。
shengquan wang - Réponse
I dropped some 90% iso into the boxes after opening, moved the sticks around, and then used compresses air to blow the alcohol and anything left out. After that, I got some silicone grease spray I had lying around (said it's safe on plastics, let's hope) and sprayed a little inside the boxes. Let the controller sit over night and reassembled. Seems to be working now, drift is gone. Thanks for the guide.
Robert Giangregorio - Réponse
Merci mille fois Raul! Grâce à toi j'ai pu réparer ma manette sans difficulté.
Je te souhaite la meilleure vie qui soit!
Ludiquement.
Domi
Dominique PIGATI - Réponse
If you use the shark mako kit at #4, a warning two you, the screw driver will not go in there. You will get a long one to go there in there. If you try At #4 you will suffer the consequences. Those black screws can strip easily and you might damage what you are trying to fix. This guide was used to clean my pro controller thanks!
AvariceHW - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 80
7 derniers jours : 855
30 derniers jours : 2,935
Total : 139,020
