Aller au contenu principal
Pour réparer ensemble - Je crée un compte
RK5 PLUS VR Headset Headband Replacement
Ce dont vous avez besoin
    1. RK5 PLUS VR Headset Headband Replacement, Headband: étape 1, image 1 de 3 RK5 PLUS VR Headset Headband Replacement, Headband: étape 1, image 2 de 3 RK5 PLUS VR Headset Headband Replacement, Headband: étape 1, image 3 de 3
      • Place the headset right side up and facing you on a flat surface.
      • Gently detach the velcro straps from the top, left, and right sides of the headset and set them aside.
      Demander à FixBot
      Ajouter un commentaire
    2. RK5 PLUS VR Headset Headband Replacement: étape 2, image 1 de 1
      • Remove the white headband adjustment part and carefully pull it off of the three straps.
      Demander à FixBot
    3. RK5 PLUS VR Headset Headband Replacement: étape 3, image 1 de 3 RK5 PLUS VR Headset Headband Replacement: étape 3, image 2 de 3 RK5 PLUS VR Headset Headband Replacement: étape 3, image 3 de 3
      • To access the straps that need to be replaced, remove the padding around the visual lenses of the headset.
      • To do this, use your hands to detach the plastic frame between the padding and the lenses.
      • If you need help getting started, use a spudger or opening tool and undo the clips holding the plastic frame.
      • Unhook the old straps from the sides of the headset.
      Demander à FixBot
    4. RK5 PLUS VR Headset Headband Replacement: étape 4, image 1 de 3 RK5 PLUS VR Headset Headband Replacement: étape 4, image 2 de 3 RK5 PLUS VR Headset Headband Replacement: étape 4, image 3 de 3
      • Reattach the new velcro straps to each of the white hooks.
      • Make sure the straps are securely attached to the hooks before moving on to the next step.
      Demander à FixBot
    5. RK5 PLUS VR Headset Headband Replacement: étape 5, image 1 de 2 RK5 PLUS VR Headset Headband Replacement: étape 5, image 2 de 2
      • Reattach the plastic frame with the padded back onto the headset.
      • Make sure the padding is properly aligned and clicked into place.
      Demander à FixBot
    6. RK5 PLUS VR Headset Headband Replacement: étape 6, image 1 de 3 RK5 PLUS VR Headset Headband Replacement: étape 6, image 2 de 3 RK5 PLUS VR Headset Headband Replacement: étape 6, image 3 de 3
      • Reattach the top band into the top hook of the headset.
      • Take the other sides of the velcro straps and hook them into the white headband adjustment part.
      • Check that the straps are properly aligned and securely attached to the headband adjustment part.
      Demander à FixBot
    7. RK5 PLUS VR Headset Headband Replacement: étape 7, image 1 de 1
      • You have successfully replaced your damaged headbands for the RK5 Plus VR headset!
      Demander à FixBot
Faraaz Abdul
Membre depuis le 01/30/23
145 Réputation
1 tutoriel rédigé
Équipe
York University, Team M-1, Allen Winter 2023 Membre de l'équipe York University, Team M-1, Allen Winter 2023
YORK-ALLEN-W23SMG1
1 membre
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 18
Total : 636
