Aller au contenu principal
Razer DeathAdder Chroma Optical Sensor Replacement
Nathan D. Kappler
Nathan D. Kappler et 2 autres contributeurs
Dernière mise à jour le May 17, 2017
7 minutes
Facile
Tutoriel étudiant vedette
The optical sensor for the Razer DeathAdder Chroma is a crucial component for the device’s operation. A critical failure of the optical sensor will necessarily require a replacement.
Ce dont vous avez besoin
Outils
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  • Phillips #000 Screwdriver
Afficher plus…
  1. Razer DeathAdder Chroma Optical Sensor Replacement, Outer Casing: étape 1, image 1 de 1
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Turn the mouse over so the bottom is facing up.
  2. Razer DeathAdder Chroma Optical Sensor Replacement: étape 2, image 1 de 2 Razer DeathAdder Chroma Optical Sensor Replacement: étape 2, image 2 de 2
    • Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
  3. Razer DeathAdder Chroma Optical Sensor Replacement: étape 3, image 1 de 2 Razer DeathAdder Chroma Optical Sensor Replacement: étape 3, image 2 de 2
    • Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
  4. Razer DeathAdder Chroma Optical Sensor Replacement: étape 4, image 1 de 1
    • Use your fingers to identify the location of the screw under the bottom label.
  5. Razer DeathAdder Chroma Optical Sensor Replacement: étape 5, image 1 de 1
    • Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
    • Clear the label away from around the screw for easier removal.
  6. Razer DeathAdder Chroma Optical Sensor Replacement: étape 6, image 1 de 3 Razer DeathAdder Chroma Optical Sensor Replacement: étape 6, image 2 de 3 Razer DeathAdder Chroma Optical Sensor Replacement: étape 6, image 3 de 3
    • Turn the mouse over so the bottom is facing down.
    • Separate the top casing from the bottom base by pulling the top casing upwards.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the LED lights.
  7. Razer DeathAdder Chroma Optical Sensor Replacement: étape 7, image 1 de 2 Razer DeathAdder Chroma Optical Sensor Replacement: étape 7, image 2 de 2
    • Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
    • Pulling too hard could damage the wire connections.
  8. Razer DeathAdder Chroma Optical Sensor Replacement, Motherboard: étape 8, image 1 de 2 Razer DeathAdder Chroma Optical Sensor Replacement, Motherboard: étape 8, image 2 de 2
    • Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
  9. Razer DeathAdder Chroma Optical Sensor Replacement: étape 9, image 1 de 1
    • Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
  10. Razer DeathAdder Chroma Optical Sensor Replacement: étape 10, image 1 de 2 Razer DeathAdder Chroma Optical Sensor Replacement: étape 10, image 2 de 2
    • Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
  11. Razer DeathAdder Chroma Optical Sensor Replacement: étape 11, image 1 de 1
    • Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
  12. Razer DeathAdder Chroma Optical Sensor Replacement: étape 12, image 1 de 2 Razer DeathAdder Chroma Optical Sensor Replacement: étape 12, image 2 de 2
    • Disconnect the ribbon connector between the motherboard and the optical sensor.
  13. Razer DeathAdder Chroma Optical Sensor Replacement: étape 13, image 1 de 2 Razer DeathAdder Chroma Optical Sensor Replacement: étape 13, image 2 de 2
    • Remove the motherboard by grasping the sides and gently pulling upward.
  14. Razer DeathAdder Chroma Optical Sensor Replacement, Optical Sensor: étape 14, image 1 de 2 Razer DeathAdder Chroma Optical Sensor Replacement, Optical Sensor: étape 14, image 2 de 2
    • Use a Phillips #0 screwdriver to remove two 5.5mm screws.
  15. Razer DeathAdder Chroma Optical Sensor Replacement: étape 15, image 1 de 2 Razer DeathAdder Chroma Optical Sensor Replacement: étape 15, image 2 de 2
    • Remove the optical sensor by pulling it forward and up.
5 autres ont terminé cette réparation.
Nathan D. Kappler
Membre depuis le 03/27/17
343 Réputation
2 tutoriels rédigés
Équipe
Baylor, Team S5-G2, Williams Spring 2017 Membre de l'équipe Baylor, Team S5-G2, Williams Spring 2017
BU-WILLIAMS-S17S5G2
3 membres
6 tutoriels rédigés
2 commentaires de tutoriel
Where do I get the part?
youarestaringatme - Réponse
This is not a sensor, but a sensor backlight. Sensor on the underside of the main board
Guest Night - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 37
Total : 6,547
