Aller au contenu principal
Rear Turn Signal Bulb Replacement
oldturkey03
oldturkey03 et un autre contributeur
Dernière mise à jour le October 3, 2016
10 minutes
Facile
Tutoriel réalisé par la communauté
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Rear Turn Signal Bulb Replacement, Rear Turn Signal Bulb: étape 1, image 1 de 3 Rear Turn Signal Bulb Replacement, Rear Turn Signal Bulb: étape 1, image 2 de 3 Rear Turn Signal Bulb Replacement, Rear Turn Signal Bulb: étape 1, image 3 de 3
    • The stop/turn signal bulb is located in the outer rear lamp unit that is secured at the rear of each quarter panel
    • Open the tail gate and locate the two fasteners holding the light assembly to the quarter panel.
    • Locate the notches in the outer ring of the fasteners. Those are to facilitate the use of a screw driver to remove the fasteners.
  2. Rear Turn Signal Bulb Replacement: étape 2, image 1 de 3 Rear Turn Signal Bulb Replacement: étape 2, image 2 de 3 Rear Turn Signal Bulb Replacement: étape 2, image 3 de 3
    • Insert a flathead screwdriver or similar tool and pry out the center of the fastener
    • A pair of pliers, or similar tool, can be used to get a better hold on the fastener
    • Completely remove the fastener
  3. Rear Turn Signal Bulb Replacement: étape 3, image 1 de 3 Rear Turn Signal Bulb Replacement: étape 3, image 2 de 3 Rear Turn Signal Bulb Replacement: étape 3, image 3 de 3
    • Proceed the same way with the bottom fastener. Pry out the center.
    • Use pliers or similar tool to pull the fastener
    • Completely remove fastener
  4. Rear Turn Signal Bulb Replacement: étape 4, image 1 de 3 Rear Turn Signal Bulb Replacement: étape 4, image 2 de 3 Rear Turn Signal Bulb Replacement: étape 4, image 3 de 3
    • The tail light assembly is still held in place by two guide pegs. Gently pull the complete assembly toward the rear of the vehicle to unseat the pegs.
    • Fully remove the tail light assembly
    • The assembly can rest on the top of the rear bumper. The Stop/Turn signal bulb is the larger one of the two bulb fixtures.
  5. Rear Turn Signal Bulb Replacement: étape 5, image 1 de 3 Rear Turn Signal Bulb Replacement: étape 5, image 2 de 3 Rear Turn Signal Bulb Replacement: étape 5, image 3 de 3
    • Remove the bulb socket by turning it about 1/4 turn in a counter clockwise direction
    • Remove the socket from the light assembly
    • Remove the bulb from the socket by pulling it straight out.
  6. Rear Turn Signal Bulb Replacement: étape 6, image 1 de 1
    • Replace the burned out bulb with a new type 3057 dual filament bulb
3 autres ont terminé cette réparation.
oldturkey03
Membre depuis le 09/29/10
812 949 Réputation
119 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
45 membres
702 tutoriels rédigés
5 commentaires
What if the trunk don’t open is it possible to change a blinker bulb ?
Shellie Gill - Réponse
No. Step 1 picture 2 can't be accessed if it does not open
oldturkey03 -
I'm a female and I will give it a try.
janice_montalto - Réponse
1*Onde posso ter informações de como trocar a lampada do farol dianteiro ?
2* Meu carro entrou água e agora as setas fficam piscando, algo q posso resolver ?
Tharles - Réponse
3* comprei um .módulo de tração que fica embaixo do banco do motorista , mais ao colocar o carro não reconheceu, com9 resolver?
Tharles - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 117
Total : 19,455
