Aller au contenu principal
Remplacement de l'écran du Huawei P9 Lite
Ce dont vous avez besoin
  1. Remplacement de l'écran du Huawei P9 Lite, Coque arrière: étape 1, image 1 de 2 Remplacement de l'écran du Huawei P9 Lite, Coque arrière: étape 1, image 2 de 2
    • Utilisez un médiator pour déverrouiller la coque arrière, en commençant par le coin en bas à gauche.
    • Travaillez dans le sens inverse des aiguilles d'une montre et défaites soigneusement les attaches en plastique une par une.
    What could you use instead of an opening pick??
    Alfredo - Réponse
    Like, could a guitar pick wor? Or anything else?
    Alfredo - Réponse
    A guitar pick will also do.
    Tobias Isakeit -
    what can still be used besides guitar pick
    Tarshia Thompson - Réponse
    I had a hard time to open the back cover by opening pick. Then I used little, really little knife at first, and I continue to opening back cover using opening pick.
    Andy B - Réponse
    Heating up aroud the finger sensor to loosen the square adhesive tape ..
    Hishamchohan - Réponse
    If you do not have any picks, You can also adapt an old credit or utility card by cutting it in to thirds. Then with some fine emery or sand paper, rub a sharp point on the one edge of the card. This will help you get access to the clips that hold the rear cover on. The one i did yesterday had quite a lot of adhesive around the edge & around the finger print sensor. Another tip with an old credit card is to cut it in to narrow strips to insert in to where you have separated the cover from the frame to stop it getting stuck to the adhesive again.
    gazza667 - Réponse
  2. Remplacement de l'écran du Huawei P9 Lite: étape 2, image 1 de 1
    • La coque arrière est collée à la batterie et la plaque métallique en haut.
    • Faites attention à la nappe sur le côté droit.
    • Tournez le médiator pour soulever la coque arrière et la détacher de l'adhésif.
    Most of the adhesive is around the fingerprint cell and on the battery itself. You can slowly pull the back cover from its side but make sure not to break it. Push the mediator or a longer piece of plastic under the back cover to slowly destroy the adhesive.
    Nicolas Combaret - Réponse
    Slowly, slowly wins the day. Nicolas is right and comes off a charm. The most nerve wracking part of this longish repair.
    John Nordstrom - Réponse
  3. Remplacement de l'écran du Huawei P9 Lite: étape 3, image 1 de 1
    • Une fois la coque arrière décollée, vous pouvez la retirer complètement d'une main.
    Hi! Im so sad! At the begginig of the operation i ve broken the white seal/connector that in one side is connected to the board and the other side is "glued" to the battery. Can someone help me? how can i solve this?? There is no image displayed on the screen. but there is vibration, sound, notifications... can someone help me please???
    Diogo - Réponse
    What you broke is handling the NFC, and doesn’t have anything to do with the display. You probably damaged the ribbon right below the battery, since that’s what links the display to the motherboard.
    Polaris -
    Oups ! L’antenne NFC était solidement collée à l’intérieur de la coque et j’ai donc déchiré sa nappe en ouvrant la coque. Heureusement, je n’utilise pas les fonctions NFC et, à part cela, tout a l’air de fonctionner normalement.
    Michel Orban - Réponse
  4. Remplacement de l'écran du Huawei P9 Lite, Haut-parleur: étape 4, image 1 de 3 Remplacement de l'écran du Huawei P9 Lite, Haut-parleur: étape 4, image 2 de 3 Remplacement de l'écran du Huawei P9 Lite, Haut-parleur: étape 4, image 3 de 3
    • Retirez les vis suivantes du bas du téléphone :
    • Trois vis cruciformes #00 de 2,9 mm
    • Quatre vis cruciformes #00 de 3,8 mm
    • À présent, vous pouvez saisir l'ensemble du haut-parleur et le retirer.
  5. Remplacement de l'écran du Huawei P9 Lite, Plaque de protection de la carte mère: étape 5, image 1 de 1
    • Dévissez les 9 vis cruciformes #000 qui fixent la plaque de protection métallique.
    • Il se peut que des vis soient recouvertes de scellés. Retirez-les pour que votre tournevis ait une bonne prise.
    Qu’est ce qu’un “indicateur d’eau”?
    chevaliernoir - Réponse
    Une petite pastille qui change de couleur au contact de l’eau. Les fabricants s’en servent pour nullifier la garantie : si ta pastille indique que de l’eau s’est infiltré, tu devra payer ta réparation.
    Polaris -
    Are all the screws the same size ?
    yes they are
    Adam M -
  6. Remplacement de l'écran du Huawei P9 Lite: étape 6, image 1 de 2 Remplacement de l'écran du Huawei P9 Lite: étape 6, image 2 de 2
    • Ne retirez pas encore la plaque de protection, elle est toujours reliée à un connecteur et collée à une nappe.
    • Prenez une spatule pour déconnecter le capteur d'empreintes digitales de la carte mère.
    • Décollez la nappe de l'antenne NFC de la plaque métallique.
    can we just remove NFC antenna and dont want to install int back?
    Mohd Danial Bin Harun - Réponse
    Note there are two plastic tabs at the top of the shield plate. Unlock them with a mediator, the plate will come easily after that.
    Buongiorno,
    va sostituita l'intera piastra metallica contenente il sensore impronte e la fotocamera, oppure il sensore é estraibile dalla piastra?
    Grazie
    LUIGI
    GI GI - Réponse
    Yes, it is possible to remove just the fingerprint sensor from the motherboard shield. Remove the small metal plate on the inside of the shield covering the sensor and push the fingerprint sensor through from the other side.
    Tobias Isakeit -
    Grazie mille.
    GI GI - Réponse
  7. Remplacement de l'écran du Huawei P9 Lite, Batterie: étape 7, image 1 de 3 Remplacement de l'écran du Huawei P9 Lite, Batterie: étape 7, image 2 de 3 Remplacement de l'écran du Huawei P9 Lite, Batterie: étape 7, image 3 de 3
    • Déconnectez la nappe de la carte mère sur les deux côtés et retirez-la.
  8. Remplacement de l'écran du Huawei P9 Lite: étape 8, image 1 de 2 Remplacement de l'écran du Huawei P9 Lite: étape 8, image 2 de 2
    • Décollez l'antenne NFC de la batterie.
    • Veillez à ne pas déchirer ou plier l'antenne.
    • Si vous retirez juste la batterie pour accéder à l'écran, vous pouvez laisser l'antenne NFC sur la batterie.
    • Débranchez le connecteur de la batterie.
    The NFC Antenna is delicate. If you are just replacing the batter then i had to use a bit of heat to soften the adhesive before gently peeling it away from the battery. The adhesive is quite stubborn.
    gazza667 - Réponse
  9. Remplacement de l'écran du Huawei P9 Lite: étape 9, image 1 de 3 Remplacement de l'écran du Huawei P9 Lite: étape 9, image 2 de 3 Remplacement de l'écran du Huawei P9 Lite: étape 9, image 3 de 3
    Outil utilisé dans cette étape :
    Tesa 61395 Tape
    $5.99
    • Faites glisser une spatule (spudger) sous la batterie à l'endroit indiqué sur l'image et décollez-la doucement.
    • Évitez de plier la batterie et refaites chauffer si nécessaire.
    • Veillez à ne pas endommager la nappe située au centre sous la batterie.
    • Au moment de remonter votre téléphone, remplacez l'ancien adhésif avec du ruban adhésif double-face ou des bandes adhésives pré-découpées.
    Bonjour j'ai réalisé toutes les etapes mais mon telephone ne se charge plus.que faire ?
    Amenis - Réponse
    Bonjour ! Alors deux options sont possibles :
    1) la batterie était complètement vide et cela prend du temps avant que le téléphone s’allume et affiche que la batterie est en train de charger.
    2) vérifiez que les connexions des nappes à l’intérieur, surtout celle de cette étape. Cette nappe relie en effet le circuit inférieur au supérieur, fait donc le lien entre la batterie et le port de recharge.
    Bonne chance !
    Claire (iFixit EU)
    Claire Miesch -
    Super !
    J’ai réussi. Le plus pénible sont les différents endroits collés.
    Particulièrement sous la batterie… et l’antenne NFC ! Qu’on ne peut pas recoller ! (jai mis du scotch, j’espère que ça ira…)
    A priori, le sèche-cheveux aide un peu pour ramollir la colle sous la batterie.
    J’ai pu aussi enlever de la colle en soulevant l’autre côté (doucement). Prendre son temps est essentiel ^^
    Par contre pas remis de l’adhésif dessous comme indiqué.
    ChtiClem - Réponse
    The battery i removed yesterday had way more adhesive on the under side than in the above pic. I ended up having to get the old battery fairly warm before the adhesive would release. A tip if you are doing this is to use an old credit card cut in to narrow strips and insert them in to the gap where the adhesive release. That way the battery shouldn’t re-stick before you remove it.
    gazza667 - Réponse
  10. Remplacement de l'écran du Huawei P9 Lite, Écran: étape 10, image 1 de 2 Remplacement de l'écran du Huawei P9 Lite, Écran: étape 10, image 2 de 2
    • Avec l'extrémité plate d'une spatule (spudger), déconnectez la nappe de l'écran.
    • Retournez le téléphone et servez-vous d'un iOpener pour faire ramollir l'adhésif sur le bord de l'écran.
  11. Remplacement de l'écran du Huawei P9 Lite: étape 11, image 1 de 3 Remplacement de l'écran du Huawei P9 Lite: étape 11, image 2 de 3 Remplacement de l'écran du Huawei P9 Lite: étape 11, image 3 de 3
    • Soulevez légèrement l'écran avec une ventouse pour ouvrir un espace.
    • Insérez juste la pointe d'un médiator dans cet espace et faites-la glisser tout le long du bord vers le haut de l'appareil. Vous devrez peut-être faire plusieurs allers et retours.
    • Essayez de progresser le long du coin et de la partie supérieure de l'écran. Changez la ventouse de place si nécessaire.
    • Laissez le médiator derrière l'écran pour éviter que la colle adhère à nouveau.
  12. Remplacement de l'écran du Huawei P9 Lite: étape 12, image 1 de 3 Remplacement de l'écran du Huawei P9 Lite: étape 12, image 2 de 3 Remplacement de l'écran du Huawei P9 Lite: étape 12, image 3 de 3
    • Faites encore une fois chauffer l'iOpener et posez-le sur l'écran pour ramollir l'adhésif en haut.
    • Faites glisser un second médiator le long du bord supérieur, vers le coin suivant.
  13. Remplacement de l'écran du Huawei P9 Lite: étape 13, image 1 de 3 Remplacement de l'écran du Huawei P9 Lite: étape 13, image 2 de 3 Remplacement de l'écran du Huawei P9 Lite: étape 13, image 3 de 3
    • Tant que l'adhésif est chaud, essayez de continuer à décoller l'écran le long de l'autre côté. Refaites chauffer l'iOpener au besoin.
    • Ne surchauffez pas l'iOpener. Respectez les instructions de l'iOpener.
    • Faites également chauffer la partie inférieure de l'écran pour les prochaines étapes.
  14. Remplacement de l'écran du Huawei P9 Lite: étape 14, image 1 de 3 Remplacement de l'écran du Huawei P9 Lite: étape 14, image 2 de 3 Remplacement de l'écran du Huawei P9 Lite: étape 14, image 3 de 3
    • Une fois que vous vous êtes frayé un chemin le long de l'écran, servez-vous d'une ventouse pour soulever la partie supérieure de l'écran et l'écarter du châssis.
    • Lentement mais constamment, faites pivoter l'écran pour décoller l'adhésif en bas de l'appareil.
    • Vous pouvez à présent faire passer la nappe de l'écran à travers le trou dans le châssis.
    • Avant de poser le nouvel écran, posez une couche d'adhésif là où c'est nécessaire.
    割れがある場合はかなり剥がしにくい。画面を温め、マイナスドライバーの極細で抉った所、フレーム周りの白い枠ごと剥がそうとしたたため枠が折れてしまった。ここは注意して欲しい。特に撮影レンズ付近は接着が強めにしてあるため最後に剥がすのが良いと思う。順番はサイド→下→上部がベストと感じた。はがした後にきづいたが、撮影レンズ裏、ディスプレイフレックスケーブル等の穴から押せばディスプレイが浮きやすいのではないかと感じた。
    ヒデトシ - Réponse
    アドバイス、ありがとうございました!
    Midori Doi -
Pour remonter votre appareil, suivez ces instructions en sens inverse.
26 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Claire Miesch nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Tobias Isakeit
Membre depuis le 03/31/14
123 785 Réputation
189 tutoriels rédigés
Équipe
Tobias Isakeit - Repairability Engineer Membre de l'équipe Tobias Isakeit - Repairability Engineer
Business
1 membre
1 131 tutoriels rédigés
3 commentaires
About release battery ... fishing braided line works better :) battery taken without any destruction.
Slawomir Z. - Réponse
Grazie a questa guida ho potuto sostituire batteria e schermo da me. Grazie!
themafiakiller1967 - Réponse
Non si può sostituire solo il vetro? X forza anche lcd?
feliciemanuele - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 15
30 derniers jours : 37
Total : 27,753
