Il est possible que cette traduction ne reflète pas les dernières mises à jour du tutoriel source. Aidez à mettre à jour la traduction ou bien consultez le tutoriel source.
Introduction
Consultez ce tutoriel pour retirer et remplacer les caméras arrière de l'iPhone 13. Les différents modules de la caméra se remplacent d'un bloc.
Ce dont vous avez besoin
Éteignez votre iPhone avant de commencer à le démonter.
Dévissez les deux vis Pentalobe P2 de 6,8 mm de long en bas de l'écran de l'iPhone.
Mesurez 3 mm à partir de la pointe et tracez une ligne sur le médiator avec un marqueur permanent.
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
Will the phone still work if the sensor assembly on the back of the screen is damaged?
Recouvrez l'écran de bandes de ruban adhésif, qui se chevauchent, jusqu'à ce que toute la surface soit couverte.
Si la ventouse n'adhère pas au cours des étapes suivantes, pliez un morceau de ruban adhésif épais (du ruban adhésif toilé p.e.) pour former une poignée et soulevez l'écran de cette façon.
Outil utilisé dans cette étape :Clampy - Anti-Clamp$24.95
Tirez la poignée bleue vers l'arrière pour débloquer les bras de l'Anti-Clamp.
Insérez le côté droit ou gauche de votre iPhone entre les bras.
Positionnez les ventouses en bas de l'iPhone – une devant, une derrière.
Appuyez sur les ventouses pour qu'elles adhèrent à l'endroit voulu.
Tirez la poignée vers l'avant pour bloquer les bras.
Tournez la poignée de 360 degrés dans le sens des aiguilles d'une montre ou jusqu'à ce que les ventouses commencent à s'étirer.
Vérifiez que les ventouses restent bien alignées entre elles. Si elles commencent à se décaler, détachez-les pour les réaligner.
Posez votre iPhone sur quelque chose de solide comme un livre à couverture rigide, pour qu'il tienne tout seul à l'horizontale. Ainsi, il sera plus facile de procéder aux étapes suivantes.
Servez-vous d'un sèche-cheveux pour faire chauffer le bord inférieur de l'iPhone. L'écran doit être légèrement trop chaud au toucher.
Attendez une minute pour donner à l'adhésif le temps de se détendre et d'ouvrir un interstice.
Insérez un médiator sous le joint en plastique de l'écran, dès que l'Anti-Clamp a ouvert un interstice suffisant.
Passez les trois étapes suivantes.
Utilisez un sèche-cheveux ou un pistolet thermique pour chauffer le bord de l'iPhone pendant 90 secondes ou jusqu'à ce que l'écran soit légèrement trop chaud au toucher.
Ne pointez jamais votre sèche-cheveux au même endroit pendant un temps prolongé.
Si vous utilisez une simple ventouse, posez-la sur le bord inférieur du téléphone, tout en évitant de vous approcher trop du rebord.
Tirez fermement et constamment sur la ventouse pour ouvrir un léger espace entre l'écran et le châssis.
Insérez un médiator dans l'espace sous le joint en plastique de l'écran.
The adhesive on the 13 model is certainly, "very strong." Keep this in mind when performing the repair. I had never opened up an iPhone as recent as the iPhone 13 and this adhesive that Apple uses for the water tight seal is strong. I had not been patient enough when opening my iPhone 13 that I had actually broken the screen. I was swapping the battery, but now I have to actually buy a new display assembly.
Utilisez un sèche-cheveux pour chauffer le bord droit de l'iPhone (celui avec le bouton de marche) pendant 90 secondes ou jusqu'à ce que l'écran soit légèrement trop chaud au toucher.
Faites glisser le médiator autour du coin inférieur droit de l'iPhone afin de décoller l'adhésif.
Parcourez ensuite le bord droit de l'iPhone, jusqu'au coin supérieur droit.
Laissez le médiator dans le coin supérieur droit avant de continuer.
Utilisez un sèche-cheveux pour chauffer le bord gauche de l'iPhone pendant 90 secondes ou jusqu'à ce que l'écran soit légèrement trop chaud au toucher.
Insérez un second médiator dans le coin inférieur gauche de l'iPhone.
Faites pivoter les deux médiators en même temps, jusqu'à ce que les clips du bord gauche se détachent.
Retirez votre ventouse de l'écran si vous ne l'avez pas encore fait.
Tournez votre iPhone de façon que son bord droit est en face de vous.
Ouvrez l'iPhone en soulevant le côté droit de l'écran comme on ouvre la couverture d'un livre.
Calez l'écran contre un objet stable pendant que vous continuez à manipuler le téléphone.
Outil utilisé dans cette étape :Magnetic Project Mat$19.95
Ôtez les trois vis cruciformes de 1,3 mm de long, qui fixent le cache des connecteurs de la batterie et de l'écran.
Prenez la pointe d'une spatule (spudger) ou un ongle propre pour soulever le connecteur de la batterie de sa prise sur la carte mère.
Repliez légèrement le connecteur par rapport à la carte mère pour l'empêcher de faire accidentellement contact avec la prise et d'alimenter le téléphone pendant votre réparation.
Avec une spatule ou un ongle, débranchez le connecteur de la nappe de l'écran.
Retirez les trois vis qui fixent le cache du connecteur des capteurs frontaux :
Une vis cruciforme de 1,7 mm
Une vis cruciforme de 1,3 mm
Une vis Y000 de 1,8 mm
Faites pivoter le bord intérieur du cache jusqu'à ce que le petit clip au bord de l'iPhone se détache.
Avec une spatule ou un ongle, débranchez le connecteur de la nappe du module capteurs frontaux.
Retirez l'écran.
what do I do if i cant get the screw out?
Prenez un tournevis cruciforme pour dévisser les trois vis de 1,7 mm qui fixent le cache de la caméra arrière.
Soulevez le cache de la caméra par son bord opposé à la carte mère et retirez-le.
Faites levier à la verticale sur la nappe de la caméra avec une spatule ou un ongle, pour la débrancher de sa prise.
Insérez la pointe de votre spatule sous la nappe inférieure gauche reliée à l'ensemble caméra et soulevez-la légèrement afin de déloger l'ensemble caméras arrière.
Toujours avec la pointe de la spatule, soulevez le bord supérieur de l'ensemble de façon à pouvoir le saisir avec vos doigts.
Commencez par insérer les deux nappes dans l'espace.
Puis, enfoncez la caméra dans son compartiment.
Comparez votre pièce de remplacement à la pièce d'origine. Il vous faudra peut-être transférer d'éventuels composants restants ou retirer des films adhésifs de la nouvelle pièce avant de commencer le remontage.
Pour remonter votre appareil, suivez ces instructions en sens inverse.
Déposez vos déchets électroniques dans un centre de recyclage certifié.
La réparation ne s’est pas déroulée comme prévu ? Consultez nos conseils basiques de diagnostic ou la section iPhone 13 de notre Forum pour obtenir de l’aide.
8 autres ont terminé cette réparation.
Merci à ces traducteurs :
88%
Claire Miesch nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
2 commentaires
Habrá alguna guía para reemplazar el flash del iPhone 13 Pro? Gracias
thanks! helped a lot!
