Aller au contenu principal
Remplacement du Taptic Engine de l'iPhone 7 Plus
Ce dont vous avez besoin
  1. Remplacement du Taptic Engine de l'iPhone 7 Plus, Vis Pentalobe: étape 1, image 1 de 1
    • Avant de commencer, déchargez la batterie de votre iPhone au dessous de 25%. Une batterie au lithium peut prendre feu et/ou exploser si elle est accidentellement percée.
    • Éteignez votre iPhone avant de commencer le démontage.
    • Enlevez les deux vis Pentalobe de 3,4 mm sur le bord inférieur de l'iPhone.
    • Ouvrir l'iPhone va compromettre son étanchéité. Préparez de nouvelles bandes adhésives avant de continuer, ou prenez bien soin d'éviter tout contact avec un liquide si vous souhaitez remonter votre iPhone sans remplacer les bandes adhésives.
    The recommendation of discharging the battery is completely unnecessary. Even a 25% charged battery can explode. Completely ridiculous suggestion.
    pargoff - Réponse
    The risk of thermal runaway on these batteries decreases with the battery's SOC (state of charge). Below 50% charge the risk is fairly low, and at 25% charge the risk of a thermal event is near zero. If I recall correctly, the same suggestion appears in Apple's official (non-public) service manuals for the iPhone.
    Jeff Suovanen -
    @jeffsu Yes, that is correct. Apple does require all certified staff to discharge the battery below 25%. This is an industry standard for all LiION batteries. If you don’t want to do this, just make sure to not puncture the battery and disconnect it first thing.
    iHelpU.Tech - Réponse
    Hang on a second here, doesn’t the Ifixit part I ordered come with the seals? The display assembly? It doesn’t. Now I have to wait another week?!
    Vanessa Pinter - Réponse
    How do you turn off if the screen isn’t responding to touch?
    adam - Réponse
    The replacement battery came with the seal—but how do you put it on???
    lkollar - Réponse
    I just found the instructions on how to install the seals AFTER I was completed and had to figure it out. Maybe, just maybe you should link this somewhere on the guild instead of buried in a comment. Just a thought.
    Charles Meitin - Réponse
    Step 1 is: Read through all the steps and comments or the method prior to starting on this Step 1. There's a lot of much needed information and experience that you can learn from which will reduce the chance of struggling, wasting time or even breaking your device.
    My favourites are:
    Use a hot water bottle.
    Label all screws you remove with their size and location on a piece of paper with double sided sticky tape.
    Test the lightning assembly at step 13
    There is a Standoff driver bit in the box, don't use a screwdriver.
    etc...
    Neil Eriksen - Réponse
    A tip for looking out for all those little screws. I used an ice block tray, for all the little screws etc. I numbered each with the step number, as in the instructions, but not all steps have bits to look out for. Where two different size screws are used I had a tray for each size and marked step a and step b. For this I coloured each tray sticker with the colour of the screw as shown in the instructions. All this worked a treat with no confusion or using the wrong part.
    Herb
    Herb Adler - Réponse
    The screw size for those with a screw set is P2.
    Gareth Flandro - Réponse
  2. Remplacement du Taptic Engine de l'iPhone 7 Plus, Marquer vos médiators: étape 2, image 1 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus, Marquer vos médiators: étape 2, image 2 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus, Marquer vos médiators: étape 2, image 3 de 3
    • S'il est inséré trop loin, un médiator risque d'endommager votre appareil. Suivez cette étape pour tracer un repère sur votre médiator et éviter que l'appareil ne soit endommagé.
    • Mesurez 3 mm à partir de la pointe et tracez une ligne sur le médiator avec un marqueur permanent.
    • Vous pouvez également marquer les autres coins du médiator avec des mesures différentes.
    • Une autre solution consiste à scotcher une pièce de monnaie sur votre médiator, à 3 mm de la pointe.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - Réponse
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - Réponse
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - Réponse
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - Réponse
  3. Remplacement du Taptic Engine de l'iPhone 7 Plus, Instructions Anti-Clamp: étape 3, image 1 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus, Instructions Anti-Clamp: étape 3, image 2 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus, Instructions Anti-Clamp: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    Anti-Clamp
    $24.95
    J'achète
    • Les trois étapes suivantes sont consacrées à la procédure avec l'Anti-Clamp, un outil facilitant les procédures d'ouverture. Si vous n'avez pas d'Anti-Clamp, passez à la procédure alternative deux étapes plus loin.
    • Pour des instructions complètes sur comment utiliser l'Anti-Clamp, jetez un œil à ce tutoriel.
    • Tirez la poignée bleue vers l'arrière pour débloquer les bras de l'Anti-Clamp.
    • Insérez le bord gauche ou droit de votre iPhone entre les bras de l'Anti-Clamp.
    • Placez les ventouses près du bord inférieur de l'iPhone, juste au-dessus du bouton home - une à l'avant et une à l'arrière.
    • Pressez les ventouses l'une contre l'autre pour appliquer la succion sur la zone souhaitée.
    • Si vous trouvez que la surface de votre iPhone est trop glissante pour que l'Anti-Clamp puisse adhérer, vous pouvez utiliser du ruban adhésif afin de créer une surface plus adhérente.
  4. Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 4, image 1 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 4, image 2 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 4, image 3 de 3
    • Tirez la poignée bleue vers l'avant pour bloquer les bras.
    • Tournez la poignée dans le sens horaire de 360 degrés ou jusqu'à voir les ventouses commencer à s'étirer.
    • Veillez à ce que les ventouses restent alignées. Si elles commencent à bouger, desserrez légèrement les ventouses et réalignez les bras.
  5. Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 5, image 1 de 2 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 5, image 2 de 2
    • Chauffez un iOpener et passez-le dans les bras de l'Anti-Clamp.
    • Vous pouvez également utiliser un sèche-cheveux, un pistolet thermique ou une plaque chauffante, mais la chaleur extrême peut endommager l'écran et/ou la batterie interne, donc faites bien attention.
    • Pliez l'iOpener de manière à ce qu'il repose sur le bord inférieur de l'iPhone.
    • Attendez au moins une minute pour permettre à l'adhésif de se décoller et d'ouvrir un interstice.
    • Insérez un médiator dans l'interstice.
    • Si l'Anti-Clamp ne crée pas un espace assez grand, chauffez davantage la zone et tournez la poignée d'un quart de tour.
    • Ne faites pas plus d'un quart de tour à la fois et attendez une minute entre chaque tour. Laissez l'Anti-Clamp et le temps faire le travail à votre place.
    • Passez les trois prochaines étapes.
    it looks like a....
    Gergely Soki - Réponse
  6. Remplacement du Taptic Engine de l'iPhone 7 Plus, Faire chauffer l'écran: étape 6, image 1 de 1
    • Les trois prochaines étapes montrent comment séparer l'écran à l'aide d'une ventouse.
    • Chauffer la partie inférieure de l'iPhone aide à ramollir la colle qui fixe l'écran. Il sera alors plus facile d'ouvrir celui-ci.
    • Utilisez un sèche-cheveux ou préparez un iOpener. Posez celui-ci sur la partie inférieure de l'iPhone pendant environ 90 secondes afin de ramollir la couche d'adhésif en dessous.
    No hair dryer so GENTLY heated over stove burner
    John Toth - Réponse
    Hello,
    What temperature is suitable for removing the front display ? I bought i-Fixit ProTech which is not include the heating "roller" . Thanks for help
    Jiří Sítko - Réponse
    Ich habe eine heiße Wärmflasche verwendet. Das hat gut funktioniert :-)
    Moritz Hartges - Réponse
    I laid my phone face-down on my 3D printer’s heated bed, and set the temperature to 60 C. After a few minutes, it was ready to loosen.
    Nate B - Réponse
    If you don’t have an “iOpener” or heat gun, try using an electric heating pad. I have a small $11 pad I got at CVS for my knee. On medium heat it worked fine for removal and with the “pennies” for setting the new seal.
    Pete P - Réponse
    I used a heated tea kettle and a tea towel, it worked!
    Adam Yavner - Réponse
    I put on the furnace vent for 10 minutes to get it warm to the touch but not hot.
    terrelldoc - Réponse
    I attached it to the after burner of my rocket ship and that worked.
    Matt Brown - Réponse
    I'm holding mine just above an erupting volcano but I'm still waiting to see if it has worked. How long does it need?
    Paul Aron - Réponse
    I used a water-filled ziploc bag, heated it in microwave. fast, cheap, worked.
    John Barker - Réponse
    Hairdryer works fine for this step. No issues.
    tripmusic - Réponse
    The most effective way to heat up the glue is to leave the phone in full sun - if it's available. In fact I would always wait for a sunny day to repair any glued together Apple device. The heat will be very even and the phone was probably designed to survive anything the sun can throw at it - although it can get very warm. (I'm in the UK) If you leave the phone turned on it will give a warning if it goes near the temperature limit.
    John - Réponse
    I'm sorry but I tried both the hair dryer (for 3 minutes!) and the eye opener (also 3 minutes) and no luck. Not even a hint of loosening the adhesive holding down the display!! Do I send this kit back for a refund or what??!!
    John Noble - Réponse
    No luck, guys. 3 minutes of hair drying and 3 minutes heating up the iopener. What next?
    Okay, a half hour later i finally got the screen loose, but not after super heating it for at leat 10 minutes with a hair drying and burning my hand trying to pry it open. Also, watch out for the power button because it inadvertently keeps switching the phone back on while you wrestle with it. More later . . .
    . . . and now I need to buy a new phone!!! the cable broke as I was trying to unscrew one of the top screws, so thanks! I FIXed IT but Good!!!!
    Nate B's advice was key. I couldn't get the temperature of the display hot enough to break the seal with a hair dryer. A heat gun set to low speed and 550F (287C) got the display up to just over 130F, close to the 60C Nate mentioned.
    Matt C - Réponse
  7. Remplacement du Taptic Engine de l'iPhone 7 Plus, Ouvrir l'écran: étape 7, image 1 de 2 Remplacement du Taptic Engine de l'iPhone 7 Plus, Ouvrir l'écran: étape 7, image 2 de 2
    • Posez une ventouse sur la partie inférieure de l'écran, juste au-dessus du bouton home.
    • Assurez-vous de ne pas poser la ventouse sur le bouton home, car cela empêcherait la ventouse d'adhérer de façon étanche à la vitre.
    Even with using high heat from a blow dryer, I had to put the suction cup over the home button or the bottom edge wouldn’t lift at all. That waterproof adhesive is incredibly strong.
    Aaron Soderholm - Réponse
    As others have said, this part really stinks, but it’ll work if you keep trying. Agree with multiple rounds of hair dryer on high (did about 60-90s each time), and with having to out the suction cup over the home button. You don’t need a big gap to pry it open - it’ll be slight …
    Johnny Emrica - Réponse
    Patience is the key here. Expletives and patience. Like previous comments say, putting the suction cup over the home button (I used packing tape to maintain the seal) will allow you to apply force to the proper location to separate the screen. Good luck!
    J Rawlinson - Réponse
    Get a suction cup pliers. It’ll make this part fun
    Bradley Steiner - Réponse
    iSclack EVO opened the iPhone easily even without heating with no fear of accidentally over-opening it like with a simple suction cup.
    Matti Haveri - Réponse
    If you don't have the anti-clamp device, to prevent the screen from tearing open when suctioning it, I suggest some layers of tape around it and the back of the phone (the tape has to be stretchy enough to just minimise the momentum when separating the screen), or some big rubberbands
    Raziocinjo - Réponse
  8. Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 8, image 1 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 8, image 2 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 8, image 3 de 3
    • Tirez sur la ventouse de façon ferme et constante pour créer un petit interstice entre l'écran et le châssis.
    • Insérez un médiator dans cet interstice.
    • L'adhésif étanche maintenant l'écran en place est très résistant, créer ce premier interstice demande donc de la force. Si vous avez du mal à le faire, refaites chauffer l'iPhone et bougez délicatement l'écran de bas en haut pour faire céder l'adhésif, jusqu'à ce que vous réussissiez à insérer votre outil.
    The screen on my phone was so broken, a suction cup did not work, so I softened the adhesive with a blow dryer and used a Jimmy to carefully pry open the phone from the bottom just enough to slip a pick in.
    charguy - Réponse
    Just completed a smashed screen replacement, this is probably the most time consuming part. Used packing tape to cover the screen to help create a suction surface (had to replace it a couple times because it pulls away after a purple good pulls ) Used consistent heat for about 5 minutes, then stuck a pick in the tiniest opening… and pry pry pry!
    Brian Gill - Réponse
    I failed at this step. No amount of heating, pulling, and rocking opened up enough of a gap to slip in even a knife let alone the blue plastic tool. That's with a phone that has an undamaged screen - just trying to replace the battery. Apple won this round :(
    Michael Sherman - Réponse
    Be really careful here. I placed a sucker to the front and rear to help lever off the screen. However, the whole thing came away much easier than I anticipated and I ripped the front part completely away from the rear, tearing all three connector cables. New iPhone required.
    Chris Wood - Réponse
    Note that the opening pick they show here does not appear to come with the kit, which is a bummer! The plunger, the mini blue crowbar thing, these are too thick. I ended up using a really thin guitar pick.
    Following careful methods can mostly preserve the seal and reusable. Won’t be as water tight but probably still pretty good.
    Bottom edge is pull up with suction + separating tool. Use small precision scissor to cut any tape that gets overly stretched upon initial opening.
    - For the 2 long edges, use an exacto knife to separate the seal from the screen. This keeps the tape on the chassis. Go slow along the long sides. Becareful to avoid scratching the paint on underside of the screen’s edge.
    - Top corners have a thick sealed tape. Best to just use separating tool to twist it open.
    In summary, top and bottom edge use separating tool. Side long edges can use exacto knife to gradually gently separate the seal from underside of the screen’s edge.
    Howard - Réponse
    4 picks and an exacto knife, plus 45 minutes later, I finally got it to open! Thanks tor the tip!
    Cat - Réponse
    Intact screen, check. Tool kit, check. Hair dryer hot enough to make the phone too hot to touch, check. Following all instructions, check. Screen still in place and refusing to come off, check.
    I heated, reheated, pulled and pulled. I simply could not get it off. Worked at it for an hour and a half, and I’m not a small guy. Yes it is hard to hold, but could get a grip. Just could not get it to budge. Off to the iPhone repair shop tomorrow. Anybody want to buy a repair kit and replacement battery?
    Jim Meyers - Réponse
    After struggling for 30m, I looked up some alternate methods and found this helpful:
    https://www.youtube.com/watch?v=25zAK5mG...
    - I used a utility knife and pried up right under the home button
    - the angle matters! I was trying to go too far down before going in. The top surface of the phone is rather thin, so you go in after barely getting under the chassis lip
    - tilt utility knife left to right once you’ve got it under to work it in
    - leave the utility knife in, and now add that pick
    Jared Wilk - Réponse
    Pro-tip: don't be an idiot like me. Instead, remove the screen protector you have on the phone before applying the suction cups. Derp.
    hunter.geofizz - Réponse
    I struggled with a hair dryer at first and a singular suction cup. However, I tried putting packing tape on the spot where I put the suction job (even though my screen isn't cracked) and I was able to do it first try with ease. Definitely recommend packing tape.
    Alessio Toniolo - Réponse
    Suction cup pliers. Dead easy
    After successful screen replacement, returning to give my thanks here. Excellent tips from you all - if you’re using force, you’re doing it wrong. Heat, very very gentle exact-o knife barely down then fully under the screen below the home button … perfect. Slow and patient around the upper corners, and don’t forget to heat there as well! Thank you all!
    dantegd - Réponse
    The problems with this step are (1) not having three hands and (2) managing to hold the phone in a way that doesn't put reverse pressure somewhere else on the screen. Exacto knife was the best tip. It's a little dangerous. On a misstep you may scratch the screen or jab yourself, but it's what got me in.
    thewrytstf - Réponse
    sorry, could not lift off the display any nano-meter even after applying enough force I think and heating it up. need to visit a store.
    Andi Tony - Réponse
    I used a razor blade and plenty of heat, and it somehow worked like a charm at the cost of me cutting myself. Definitely be careful when doing this, I used the razor blade on the left side of the iphone then wedged in a small screwdriver and then used the pick to cut the rest of the material away.
    Sharaf Kazi - Réponse
  9. Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 9, image 1 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 9, image 2 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 9, image 3 de 3
    • Faites glisser votre médiator le long du côté gauche en commençant par le bord gauche puis en progressant vers les boutons de contrôle du volume et le bouton du silencieux, pour faire céder l'adhésif qui maintient l'écran.
    • Arrêtez-vous juste avant le coin supérieur gauche de l'écran.
    • N'essayez pas d'écarter le bord supérieur de l'écran et la coque arrière, car des clips fragiles en plastique les assemblent.
    My Plektrum worked ok, but the edges broke off a bit towards the end
    griffin.weber - Réponse
  10. Remplacement du Taptic Engine de l'iPhone 7 Plus, Information sur l'écran iPhone: étape 10, image 1 de 1
    • Attention : il y a des nappes fragiles le long du bord droit de l'iPhone. En séparant l'adhésif, évitez ces zones pour ne pas couper les nappes concernées.
    I was trying to replace my battery, and accidentally cut one of the cords on my screen. I marked my pick, so i don't know how it happened.
    Gib Jeffries - Réponse
  11. Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 11, image 1 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 11, image 2 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 11, image 3 de 3
    • Réinsérez votre outil dans le coin inférieur droit de l'iPhone, faites-le glisser le long du coin, puis progressez vers le haut, le long du bord droit du téléphone, pour faire céder l'adhésif.
    • N'enfoncez pas le médiator à plus de 3 mm, vous risqueriez d'endommager les nappes de l'écran.
    No pick in the kit you sent me.
    Ted Cooper - Réponse
  12. Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 12, image 1 de 2 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 12, image 2 de 2
    • Tirez délicatement sur la ventouse pour soulever le bord inférieur de l'écran.
    • Ne soulevez pas l'écran à plus de 15°, sinon vous pourriez tendre ou déchirer les nappes connectées à l'écran.
    • Tirez sur la petite bosse de la ventouse afin de la décoller du panneau frontal.
  13. Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 13, image 1 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 13, image 2 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 13, image 3 de 3
    • Faites glisser un médiator sous l'écran, le long du bord supérieur gauche et du bord supérieur du téléphone, pour faire céder le reste de l'adhésif.
    I did end up using just a smidge of IFIXIT adhesive remover along the edge before opening and that seemed to really help
    Karen Flowers - Réponse
    I have been using the pointed tweezers to pull the adhesive strands apart and out as the display comes off.
    This bit was awkward as to get a good grip I kept inadvertently switching the %#*@ phone on!
    wendyhoward - Réponse
  14. Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 14, image 1 de 2 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 14, image 2 de 2
    • Faites glisser légèrement l'ensemble écran vers le bas (éloignez-le du bord supérieur du téléphone) pour ouvrir les clips le maintenant à la coque arrière.
  15. Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 15, image 1 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 15, image 2 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 15, image 3 de 3
    • Ouvrez l'iPhone en faisant pivoter l'écran vers le haut en partant du côté gauche, comme s'il s'agissait de la couverture d'un livre.
    • N'essayez pas encore de séparer complètement l'écran, car plusieurs nappes fragiles le relient toujours à la carte mère de l'iPhone.
    • Calez l'écran contre un objet afin qu'il reste bien stable pendant que vous travaillez sur les composants du téléphone.
    Nach RECHTS klappen - nicht nach links!
    Manfred Wachtel - Réponse
    Als ich das Flachbandkabel auf der rechten Seite sah, hab ich mich auch gefragt, ob die das mit nach Links klappen ernst meinen, und das „Buch“ lieber auf japanische Art nach rechts aufgeklappt. Das sollte dringend in der Anleitung korrigiert werden!
    Sebastian Plickert - Réponse
    “Up from the left” means lift up the left side.
    Which is the same as folding to the right.
    “Like the back cover of a book” explains it even more clearly.
    Maybe it gets lost in translation?
    Nick Shtangey -
    Fold to THE RIGHT - not to the left!
    Jim Glenys - Réponse
    When I saw the ribbon cable on the right side, I also wondered if they were serious about folding it to the left, and the "book" would rather be opened to the right in the Japanese way.This should be corrected urgently in the manual!
    Hi Jim, the display opens from the left side, toward the right side. It should look like the back cover of a book. Hope this helps. Good luck with the repair!
    Adam O'Camb -
    DO NOT LAY THE TWO HALVES FLAT!!! There is a reason why the third photo shows the screen half leaning against a box! This really needs to be a warning in addition to the one about not separating the display.
    Mangled Jargon - Réponse
    If you're skipping the screen and taptic engine removal like I did, I suggest you tape the back of the phone to the table, and also tape the screen to the vertical object it lays on, so it stays still. That way you will avoid having to constantly readjust it because of the sliding of the housing of the phone when you're working on it. Be careful where you're putting the tape on the screen though, if you're doing it on the internal components.
  16. Remplacement du Taptic Engine de l'iPhone 7 Plus, Déconnexion de la batterie: étape 16, image 1 de 1
    • Retirez les quatre vis tri-point Y000 suivantes fixant le cache de la nappe d'écran inférieur à la carte mère :
    • Trois vis de 1,2 mm
    • Une vis de 2,6 mm
    Is it really safe to lay the device fully open like a book? The cable leading to the LCD gets stretched across the sharp edge of the aluminum edge of the back cover.
    u204863 - Réponse
    Generally I'd say no, it's not safe. In reality I've seen a bit of variance in the cable length, and sometimes it'll be fine—but mostly I'd be prepared to prop the display up or hold it in place at a slight angle so it doesn't put too much stress on the cables. On prior iPhones it was easy to rubberband the display to a box or a can of soda, and something like that would probably work well here too. Use your own judgment.
    Jeff Suovanen -
    You could stick the suction cup back on, near the right side of the phone, with the blue hook oriented in such a way that it becomes a stand for the screen. That way it won’t open much more than 90 degrees, and leaves both your hands free.
    Mark -
    The tri wing screws are so hard to remove. What's the trick?
    shannon caldwell - Réponse
    At first I think I was being too careful and was getting no where. I got better results by pressing down on the screwdriver with more pressure while turning and those little screws came right out.
    LadyTech - Réponse
    I cannot remove one of the corner screws in this step and i have used the tweezers and the y000 tri tip and i am afraid that it is stripping it. is there a work around for this step?
    Katherine Monday - Réponse
    @katmonday1 No workaround unfortunately. Make sure the driver tip is in good condition and fits the screw correctly. Seat it in the screw, hold the driver perfectly vertical, press down hard (and maintain it), and turn. It’ll come out. If it’s really stripped you’ll have to get more aggressive—try one or more of the techniques in this guide or get some help. Good luck!
    Jeff Suovanen -
    my screwdriver will only remove the 2.6mm screw and not the others, what shall i do?
    AubreyG1 - Réponse
    A tip to remember which screw is which as the differences are pretty tiny: I used different colored sharpie fine-points and made a mark on the top of the screws before removing. I thought about having strips of tape that I stuck similar sizes to, but the coloring seemed to work more easily. I only did this for step 11 and it saved me down the road when trying to differentiate the 1.2 and the 1.3mm screws!
    Trey Smith - Réponse
    STOP! Before you remove Any screws, be sure to create several bins to hold the various sizes in… or mark them like Trey suggested. I failed to pay attention because I thought they were all the same… they are not. It is very hard to figure out the sizes if you remove them all and store them in a single location.
    John Grant - Réponse
    i had a piece of paper with the steps numbered that involved screws. I had double sided tape on the paper and the number of screws and thier position marked. This was so helpful in removing and then finding and installing the tiniest screws on earth. And i have TINY hands. I can’t imagine someone with large paws being able to accomplish any of this.
    Tina Matthews - Réponse
    there is one screw thats 1.2 mm but its bigger than the others and will fit in no hole of the entire phone. i got it out bot now i have no idea where it has to go i tried every hole. can somebody help me?
    Lars Göbel - Réponse
    what do i do if one of the screws dont want to come off
    Neylley Reynoso - Réponse
  17. Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 17, image 1 de 2 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 17, image 2 de 2
    • Retirez le cache de la nappe d'écran inférieur.
    I am confused, please help. LOL the bracket, the very first one being removed. I see it has three screws the same size and one a different size? I've been trying to fix my daughter's phone and ordered a 0.6 mm Tri Wing screwdriver for iPhone 7 plus /Apple watch. It seems to fit the screws and it seems to be turning them although I can't see that well but they're not coming out. However when I used it on a smaller bracket with two screws they came right out so I'm thinking I don't have the right screwdriver I am at my Wit's End!! I have been working on this phone or attempting to for a while now. I cannot find a list anywhere of the exact size screwdrivers needed to Take apart an iPhone 7 plus. Any help would be greatly appreciated.
    chris west - Réponse
    If your tri-wing screwdriver worked for other tri-point screws in the phone, then it should work for the screws you are struggling with! If it feels like the screws are spinning but not coming out, try to use tweezers to pull them out. I often struggle with tri-point screws, and need to apply some downward pressure to remove them. This can be risky though, as you do not want to strip the screw or damage components underneath the bracket. If you continue to struggle, you can give this driver and this bit a try.
    Scott Havard - Réponse
    Also be aware that the battery connector might stick to the bottom of the steel bracket. This part had me a bit puzzled at first. lol
    Just gently pry the connector off the steel bracket to release it and be sure the connector isn’t allowed to accidentally reconnect to the board.
    jeffrey griffith - Réponse
    I had to use a fingernail to dislodge the bracket. As Jeffrey said, it was apparently stuck to the connector.
    lkollar - Réponse
  18. Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 18, image 1 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 18, image 2 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 18, image 3 de 3
    • Utilisez la pointe d'une spatule (spudger) pour soulever le connecteur de la batterie de sa prise sur la carte mère.
    • Pliez légèrement la nappe du connecteur vers le haut pour éviter un contact avec la prise ce qui risquerait d'alimenter le téléphone.
    You could cover the battery socket with a small piece of tape to make sure that it doesn’t accidentally re-connect. It’s not likely to, but I liked the peace of mind.
    Mark - Réponse
    on reassembly, make sure that the connector cable is back in place, along side the battery, and not up, or on top in any way.
    Sarr Sheffer - Réponse
    I slipped a small piece of paper under the flap.
    MajorCouillon - Réponse
    After this step it is worth jumping to step 36 and disconnecting the lighting connector assembly (indicated with the orange rectangle) and connecting the new cable to test it out. After attaching the new lightning connector assembly, reattach the battery, and try plugging it in to see if the new assembly works correctly. If it does, then power down the phone, disconnect the battery, and disconnect the new lightning connector assembly. Then continue. If it doesn’t work, this check will save you a couple of hours of work.
    Evan O - Réponse
  19. Remplacement du Taptic Engine de l'iPhone 7 Plus, Écran complet: étape 19, image 1 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus, Écran complet: étape 19, image 2 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus, Écran complet: étape 19, image 3 de 3
    • Assurez vous que la batterie est déconnectée avant de toucher aux nappes dans cette étape.
    • À l'aide de l'extrémité plate d'un spudger (spatule) ou d'un ongle, faites levier sur les deux connecteurs d'écran inférieurs afin de les déconnecter de leurs prises sur la carte mère.
    • Pour remettre des connecteurs à pression, appuyez sur un côté jusqu'à ce qu'il se mette en place avec un clic, puis répétez la même chose de l'autre côté. N'appuyez pas sur le milieu. Si le connecteur est ne serait-ce qu'un peu mal aligné, il risque de se tordre et causer des dommages permanents.
    • Si vous avez un écran blanc, des lignes blanches sur l'écran, ou s'il n'y a pas de retour tactile après que vous ayez remonté votre iPhone, essayez de déconnecter et soigneusement reconnecter les deux nappes et vérifiez qu'elles sont bien insérées.
    The note about the danger of pressing on the connector incorrectly is very legitimate. Though I find it more practical to use a wide (1.5 cm) case opener tool to press it down all at once. Minimizes risk of bending the connector.
    Talon - Réponse
    What can happen if the battery is not disconnected before the two lower display connectors?
    Alextay - Réponse
    Hello, by my expierence and what i have learned iphone repair videos you can ‘blow up’ capacitors which one in logic board, screen is sensetive with voltages and etc….
    Darius Varanavičius -
    what are my options if the display connector broke? can it be replaced or do I need to get a whole new screen?
    matomach - Réponse
    When I removed the lower display cable bracket in step 12, the top connector stuck to the bracket and became disconnected.
    Grant Crawford - Réponse
    My replacement screen wouldn't sit in the display connector properly, (wouldn't clip in both sides at same time) so I made sure it sat on one and it was lined up and got a thin piece of dense sponge and placed that over the connector, then proceeded to install the connector shield and screen works perfectly fine without a hitch. Very good tutorial just earnt me £25 lol
    Joshua Driscoll - Réponse
    have the same issue, sometimes it doesn’t sit on the left side, other time not on the other, the difference is iphone not starting at all or looping with apple logo reboot…
    ibisiki -
    Bent the pins on the connector out of place, worked them very carefully back with fine nose tweezers. This was by far the crux of the repair for me.
    nicO - Réponse
  20. Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 20, image 1 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 20, image 2 de 3 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 20, image 3 de 3
    • Retirez les trois vis tri-point Y000 fixant le support au dessus du connecteur de l'ensemble capteur du panneau frontal:
    • Une vis de 1,3 mm
    • Deux vis de 1,0 mm
    • Retirez le support.
    Posted a comment above on the first step. The screwdriver that I ordered Works taking out these two screens shown in the picture. However it does not work on the first bracket that needs to be removed. It seems that all screw sizes are somewhat different but I'm not finding a list showing different screwdriver sizes needed. Does this make sense? Could anybody please give me some advice on this thank you much.
    I know your comment was posted a long time ago but just in case someone else has the same problem, the only difference in the screws are the lengths. The ends are the same.
    mcr4u2 - Réponse
    What happens if you break “tear in half” the black tape stuff?
    assweeetasyou - Réponse
    Unfortunately if you tear the black cable you will need to replace it !!!
    Wayne Lyell -
    Chris West the screwdriver that probably came with the kit was pentalobe to get the first two screws out to open the case. you need a .6mm Y tip driver for internal. its deceptively Phillips looking but is not it only has three blades in a Y, not 4 in a +
    Jeremiah Kjensmo - Réponse
    I called the y tip a triangle tip until I read these comments. Thanks for the correction
    Kayla Tobin -
    Hello is it if I put wrong screw can damage the board?
    alicenine84 - Réponse
    Care should be taken while removing the last 1.0mm screw, on the far right in the picture. This screw is screwed into another screw (or standoff) beneath the bracket. This standoff may come unscrewed and upon removing the bracket you may find the screw and standoff are still attached to the bracket. Do not lose this part if you decide to separate them , the standoff is not a normal phillips, and may require a special driver to reinstall. I used the phillips to start it back in, and relied on the screw to tighten it upon reassembly.
    Benji - Réponse
    I know this is late bit a trick I use to put the standoffs in (had to do 2 cause someone lost the screws I was replacing) is to take the screw that goes in it srew them together loosely to give it a fake phillips head then gently screw both into the spot the standoff goes in. you can then take the phillips out (may need to put a spudger between the screw and standoff to keep the standoff down then use a tiny flathead to gently tighten the standoff down. its a few steps but makes life easier if you need to replace it quickly.
    Stephen Patterson -
    I was able to remove the first 1.0 mm three tri-point Y000 screw from the bracket but I cannot for the life of me get the other 1.0 mm screw undone or the one 1.3 mm screw undone. Any tips?
    I tried pressing down a bit harder and I even put the first screw back in to see if it helped me loosen the other two but it did not work.
    My screwdriver was doing the job up until this point, and I’m worried I’ll strip the screw if I keep trying.
    Would appreciate any advice!
    jrosegoep - Réponse
    Dear IFixit: First, I want You to know I love your repair guides. I consider You to be the absolute best repair manuals available. But, hopefully as your friend I am going to point out once the bracked is removed a 2.0 mm Standoff screw should appear. It’s 1 of 2 screws holding the Antena Flex Cable in place. Rob
    Robert Schmidt - Réponse
  21. Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 21, image 1 de 2 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 21, image 2 de 2
    • Déconnectez le connecteur de l'ensemble capteur du panneau frontal de sa prise sur la carte mère.
    • Ce connecteur à pression doit également être remis un côté à la fois, pour réduire le risque de le tordre.
    Make sure that the orientation of the cable when you attach is correct! See the picture for the correct orientation. If it gets installed 180 degrees out(i.e., the ribbon goes up instead of down, then the earphone, front camera, and Home button will be inoperative. Ask me how I know!?! Worked great when installed correctly!
    Kevin Reilly - Réponse
    Thanks Kevin. I would be stuck if I hadn't read your comment!?! Great input.
    Lukas Watts -
    That's save my life!thanks god!
    neg -
    I also made this mistake! Thank goodness it didn’t break anything.
    That Guy - Réponse
  22. Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 22, image 1 de 1
    When removing the old adhesive from the edges, duct tape can be useful. Simply use small strips of duct tape and your spudger to press the tape’s adhesive side carefully into the edges of the phone’s display and slowly peel the duct tape away from the display. The duct tape should pick up the remaining adhesive and carry it away from the edges. use the tip of the spudger to gently scrape away any remaining dirt or film from the crease around the edge and repeat the action with a new strip of tape to pick up any dirt, adhesive or grime from the surface. This should save considerable time.
    Benji - Réponse
    Thank you for including a link to the iPhone Display Adhesive Replacement guide, this was very helpful!
    Robert O'Brien - Réponse
    is it really necessary to remove the display? the screen connectors are delicate and I fear re-assembly errors. I changed the battery and did not remove any screen connectors. no problems.
    jacobra - Réponse
    Due to the fact that THIS is the repair guide for replacing the DISPLAY it IS necessary to remove the display connectors. There is another guide for changing the battery -- you might want to follow that one.
    Hannes -
    I did not remove the display and ended up ripping one of the lower display cable ribbons when I turned the phone to remove one of the connectors. Be careful. I had to get a new display and move the Touch ID button.
    Shawn Hime - Réponse
    I think that moving the replacement of the seal lower in the chain of events would be more beneficial. I'm replacing the battery, and stretching the adhesive tabs that held the battery in at a low angle kept sticking themselves to the newly-installed adhesive seal.
    In the end, I wound up having to just remove the section of the seal along the bottom of the case :-/
    If I'd been looking at the bigger picture, I'd have wanted to put the seal on right before reattaching the screen cables.
    Rob Russell - Réponse
    This guide does not show you the removal process for the top camera assembly. My screen looks like the one pictured but my replacement doesn't have the top connector or any of the front facing camera components and since the ribbon for the connectors looks like its coming out from underneath the display I can't see how to swap it over to the new display.
    Jezagee - Réponse
  23. Remplacement du Taptic Engine de l'iPhone 7 Plus, Conduit pour le baromètre: étape 23, image 1 de 1
    • Retirez les deux vis cruciformes suivantes fixant le conduit pour le baromètre au boîtier arrière :
    • Une vis de 2,9 mm
    • Une vis de 2,1 mm
    I skipped this step and go straight to step 25. I skipped it because I couldn’t get the screws to come off. But skipping those step did not prevent me or has any detrimental effects on performing step 25.
    Jamie Liao - Réponse
    I agree, I don’t see any reason to remove the Taptic engine to remove the battery…It seems like more of a chance of screwing something else up…keep it simple…
    William Karis - Réponse
    If you’re replacing the battery, removing the Taptic Engine gives you a much better chance of removing the battery adhesive strips successfully. To keep them from snagging and breaking, you want to pull them from as low an angle as possible. With the Taptic Engine in the way, you have to pull them at almost 90 degrees, or risk snagging them on the Taptic Engine.
    Jeff Suovanen -
    i can’t get the 2.1 screw 2 come out pls help anyone
    John Bryce - Réponse
    I agree with Jamie Liao above. Skips steps 18-24 as described. Before proceeding with step 25, I heated a microwavable hot/cold compress (used to treat muscle strains). I set the iPhone back casing on the heated compress before pulling out the adhesive strips.
    Again, there is no need to do steps 18 through 24.
    Thomas Young - Réponse
    i didn’t remove this and had major issues pulling the adhesive strips out. I literally couldn’t grasp them and then when i did, they broke! UGH! I was able to complete the installation but i must have done something wrong because my phone still isnt working. It just ‘flashes’ the apple logo. Won’t do anything else. Should have just taken it in for repair. Now i have to buy a new phone anyway.
  24. Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 24, image 1 de 2 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 24, image 2 de 2
    • Poussez délicatement le conduit pour baromètre dans la direction du Taptic Engine afin de décoller l'adhésif le fixant au bord supérieur de l'iPhone.
    Adhesive may require a tiny amount of tugging of the barometric vent to free it…
  25. Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 25, image 1 de 1
    • Retirez le conduit.
  26. Remplacement du Taptic Engine de l'iPhone 7 Plus, Taptic Engine: étape 26, image 1 de 2 Remplacement du Taptic Engine de l'iPhone 7 Plus, Taptic Engine: étape 26, image 2 de 2
    • À l'aide de l'extrémité plate d'une spatule (spudger), déconnectez le connecteur du Taptic Engine de sa prise sur la carte mère.
  27. Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 27, image 1 de 1
    • Retirez les trois vis cruciformes de 1,5 mm fixant le Taptic Engine au boîtier arrière.
    what do you do if the top left screw is not coming out?
    Karrington Dowe - Réponse
    There is a little guide pin for the Taptic Engine proper seating
    Landis - Réponse
  28. Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 28, image 1 de 2 Remplacement du Taptic Engine de l'iPhone 7 Plus: étape 28, image 2 de 2
    • Retirez le Taptic Engine.
Comparez votre nouvelle pièce de rechange à la pièce d'origine - vous devrez peut-être transférer les composants restants ou retirer les films adhésifs de la nouvelle pièce avant l'installation.
Pour remonter votre appareil, suivez les étapes ci-dessus dans l'ordre inverse.
Apportez vos déchets électroniques à un un recycleur certifié R2 ou e-Stewards.
La réparation ne s'est pas déroulée comme prévu ? Essayez nos conseils basiques de diagnostic ou cherchez de l'aide sur notre Forum.
61 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Scott Havard
Membre depuis le 06/27/16
49 633 Réputation
31 tutoriels rédigés
3 commentaires
is there a replacement taptic engine available to purchase?
Jody Tamplen - Réponse
Did you end up finding one anywhere?
Matthew Lafond -
you can purchase a taptic engine on the ifixit store :-)
I Malloy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 69
30 derniers jours : 315
Total : 42,129
