Aller au contenu principal
Remplacement du boîtier supérieur MacBook Unibody modèle A1342
Ce dont vous avez besoin
Vidéo d'introduction
  1. Remplacement du boîtier supérieur MacBook Unibody modèle A1342, Boîtier inférieur: étape 1, image 1 de 1
    • Retirez les huit vis Phillips 4 mm par lesquelles le boîtier inférieur est fixé au MacBook.
    According to this page http://support.apple.com/kb/HT1651?viewl..., the 8 screws are not identical.
    Can anybody tell me where each kind of screw is supposed to go?
    Gregoire - Réponse
    They are all 100% Identical. You were probably looking at a different model, or Apple has entered the wrong information... Hey, It happens...
    Owen Davies -
    The screws on the Late 2009 are identical. The blue lock compound might make tightening some require a little more effort.
    svenaustx - Réponse
    Can I replace it with a SATA 3 cable?
    nm - Réponse
    A1342 macbook does not have the right controller to support sata III
    Owen Davies -
    hi, i just got back from the apple store and they are really keen for me to upgrade to a new laptop since my battery is old and the screen is cracked, so glad i found ifixit i would love to upgrade this puppy! gonna make it a real sleeper! styler hall wrote about sticking 16 gb of ram in his a 1342 ? is this a simply mather of ordering 3 4gb sticks ?aslo i currently have 4 gb and would like to upgrade to 8 ( or indeed 16) does that mean i need to buy all new sticks or can i continue to use the old one and stick a new one next to it ?
    thanks again mick van aar, perth western aus.
    michelvanaar - Réponse
    The A1342 will take up to 16 GB of RAM, however, there are only two RAM slots, so use two 8-GB RAM modules. Other World Computing (OWC) is a great reference source for info on exactly which RAM to use with which model; prices are usually much better on EBay though. Add an SSD from OWC and your machine will really scream!
    I hope that helps!
    gdesbrisay -
    Gregoire is right. The 8 screws are absolutely NOT identical, I’m looking at them right now, weeowey weeowey.
    John Guzman - Réponse
    I just wanted to say that, in 2020, i used these instructions to replace the magsafe socket on my A1286, mid-2012, pre-Retina MacBook Pro. The internal layout is not quite the same but close enough for me to do the job. I skipped the steps of fully disconnecting the fans and speakers because of what others had said about breaking the sockets. it just meant I had to be extremely careful when lifting up the main board so that I did not tear and break the connections. I was able to disconnect the old magsafe socket with the board flat and in situ, but there was no where near enough room to be able to aline and press home the new par home. Reluctantly i had to lever up the board. This was difficult as there is a tapped post that holds a screw in the way close to where the USB sockets are, that prevented the board lifting up and out. I had to be quite forceful to manouevre the sockets out from the edge of the case.
    Paul Burridge - Réponse
  2. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 2, image 1 de 3 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 2, image 2 de 3 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 2, image 3 de 3
    • Le boîtier inférieur est construit en aluminium avec un revêtement en caoutchouc. Ne pliez pas trop l'aluminium lors du retrait, car une déformation permanente générerait des problèmes de tolérance après le remontage.
    • Soulevez légèrement le boîtier arrière au niveau de la fente.
    • Continuez à faire courir vos doigts entre les boîtiers inférieur et supérieur jusqu'à ce que le boîtier supérieur se dégage des clips de fixation.
    • La position de ces trois clips est indiquée dans la troisième photographie.
    Do the retaining clips have to be re-engaged when replacing the lower case?
    John Morley - Réponse
    Answering my own question, the clips re-engage when the lower case is correctly positioned. You can help them by gently pressing the lower case with your thumbs midway along the two short sides. When everything is correctly aligned the eight screw holes line up.
    John Morley -
    Rather than running your fingernail down the sides to free up the retaining clips, I found that using an old credit card, inserted about 1/4”, to run along the left and right side popped those end retaining clips right off with no problem. You may need to twist the card slightly when in the middle area to help pop those off.
    bdahl385 - Réponse
  3. Remplacement du boîtier supérieur MacBook Unibody modèle A1342, Batterie: étape 3, image 1 de 1
    • Pour des raisons de précaution, nous conseillons de déconnecter le connecteur de la batterie de la carte mère pour éviter une décharge électrique. Cette étape est facultative et non obligatoire.
    • Avec l'extrémité plate d'une spatule (spudger), soulevez le connecteur de la batterie de sa prise sur la carte mère.
    • Il est peut-être plus facile de soulever les deux côtés du connecteur avec vos ongles.
    you do not need to remove the battery when replacing the hard drive or ram
    brilldoctor - Réponse
    beware not to lift the connector to close of the angle, as the picture suggest it. It might broke the angle. Attack by the middle.
    naamol - Réponse
    Not necessary?
    hikkymemo - Réponse
    Be careful of the corner of the battery cable connector when trying to pry it off with the spudge. I knocked the corner of mine. No operational impact but was not very pleasing!
    jljordanweb - Réponse
    Not necessary, but a good idea, so as to avoid any spurious charges going through the boards...
    svenaustx - Réponse
    @Svenaustx - What could happen if not removing this battery? Worst case? Not a geek on this but did change RAM on my Macbook Pro "15. Can't remember disconneting the battery back then. Shouldn't it be sufficient shutting the Mac off and ensure it has been used for an hour or so before replacing RAM?
    Allan Clarke -
    i used a metal pry and noticed some sparking when i disconnected the battery. replaced ram. now it wont turn on. did i fry it?
    Ian Lynch - Réponse
  4. Remplacement du boîtier supérieur MacBook Unibody modèle A1342, Grille d'aération arrière: étape 4, image 1 de 1
    • Retirez les vis suivantes de la grille d'aération arrière, du côté du lecteur optique :
    • Deux vis Torx T8 10 mm
    • Deux vis Phillips 5 mm
    Hi, i have an issue with the screw in the middle: it is blocked and the top is now damaged... Any suggestion?
    Corrado - Réponse
    I have a problem with the two middle screws
    Harlan Shannon - Réponse
  5. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 5, image 1 de 1
    • Retirez les vis suivantes de la grille d'aération arrière, du côté du port :
    The left-most philips screw in this picture does not seem to go in properly. The best I could do was use the screw with least of the blue screwlock on it and then err on the side of leaving the white plastic a bit Ioose in that location.
    QuincyMB - Réponse
    Be very careful when putting the Torx screws back as they are very easy to leverage and seems to bend the white piece at some point, making me nervous they could crack it. Don't overdo these.
    QuincyMB - Réponse
  6. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 6, image 1 de 1
    • Sortez avec précaution la grille d'aération arrière du boîtier supérieur.
    you can actually stop disassembling now and try to replace it now. after removing two t6 screws it came off pretty easily
    grze - Réponse
    Good tip, thanks! I skipped ahead to step 17 and had no problem getting the magsafe board out from under the logic board and the new one installed. Saves a lot of work disconnecting connectors indicated as Fragile!
    matt15 -
    Thank You! Saved me an hour or so of work and a lot of stress!
    15sweyandt -
    I also did Step 6, then skipped to Step 17 & 18. Once I had the display data cable off, I could remove the 2 T6 Torx screws holding the MagSafe board on and remove it. You can reach under the logic board with the point of the spudger to work the cable out of the socket. Note how you maneuver the board out of the tight space so you can maneuver it back in. When you put the new MagSafe board in, plug in the cable first. If you bend the wires so the plug approaches the socket at the appropriate angle, you can nudge it in with the pointed end of the spudger.
    hpendleton -
    Thanks a lot for this hint! You saved my macbook, when I failed to unscrew the fan because of one completely destroyed screw. Thanks to your comment I skipped steps 7-16 and went straight to replacing the magsafe board without problems. The spudger and some 3D imagination and done,
    Sebastian M -
  7. Remplacement du boîtier supérieur MacBook Unibody modèle A1342, Carte mère: étape 7, image 1 de 1
    • Avec l'extrémité plate d'une spatule (spudger), faites levier pour retirer la nappe AirPort/Bluetooth de la carte mère.
    The steps from 7 up to 16, and then 19 and 20 are not necessary. It looks like Apple intentionally designed the shape in the corner around the magsafe connector, so that it can be replaced without disconnecting and unmounting the main board. Also, the placement of the two screws mounting the magsafe board confirms that - they are easily available. This is true at least for the 2009 model, which I've successfully repaired.
    So you can skip the risky steps of disconnecting of all the main board connectors and go straight to unscrewing the magsafe connector. Then, having the spudger and some 3D imagination, you can remove the magsafe board with some 3D rotations. Same for mounting the new magsafe.
    I've found out that crucial simplification only because I failed to unscrew the fan (broken a screw completely, while following this guide step by step). Then I found a comment from user grze under step 6, which saved my macbook by confirming, that 7 to 16 can be skipped.
    Sebastian M - Réponse
  8. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 8, image 1 de 3 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 8, image 2 de 3 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 8, image 3 de 3
    • Avec la pointe d'une spatule (spudger), soulevez le connecteur du ventilateur vers le haut pour le débrancher de sa prise sur la carte mère.
    • Il est utile de faire pivoter la spatule en dessous des câbles du ventilateur pour débrancher le connecteur.
    • La prise et le connecteur du ventilateur sont montrés sur la deuxième et troisième photo. Veillez à ne pas casser la prise en plastique du ventilateur quand vous retirez le connecteur du ventilateur de sa prise. La configuration de la carte mère de votre appareil peut différer de celle de la deuxième photo mais la prise du ventilateur est la même.
    Since this kind of connector and very fragile and easy to damage even with a spudger I use a needle that I insert in the front side of the connector, between the connector and the socket and only apply a little pressure while lifting up the needle. The connector will then pop up from one side. Repeat the procedure for the other side. With this method it's impossible to damage the connector. I adopted this method after ruining two or three connectors using the spudger.
    lemerise - Réponse
    Hi, how do you fix the axial which connects the fan with logic board..it's broken! Thanks in advance..
    Gagandeep -
    HELP! Both the connector AND socket detached from the logic board! Is it possible (barring micro-surgery) to reattach the socket to the logic board?
    John Watson - Réponse
    same problem here...any ideas? Did you fix it again, John?
    Ben Kn -
    I disconnected the connector and socket from the logic board because I wasn't being careful and wasn't using a spudger tool as was recommended. Luckily, a friend of mine that's handy with a soldering gun was able to individually solder each wire from the cooling fan's wire assembly back onto the soldering points on the logic board. It's really intricate, tricky, and risky...but at that point, what choice do you have? I verify it's possible to fix and my cooling fan is now running perfectly fine.
    Dan Barnhart - Réponse
    Hi my name is Lynn I made a mistake on the logic board trying to detach fan from laptop
    A1342 and the whole thing came off so I was wondering do
    I solder it back on or how can I fix it thank you and be Blessed
    lynn6202388 - Réponse
  9. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 9, image 1 de 2 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 9, image 2 de 2
    • Dévissez les trois vis suivantes, fixant le ventilateur au boîtier supérieur :
    • Une vis cruciforme de 7,1 mm.
    • Deux vis cruciformes de 5 mm.
    • Ôtez le ventilateur du boîtier supérieur.
  10. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 10, image 1 de 1
    • Soulevez soigneusement le connecteur fragile du haut-parleur arrière de la carte mère. Les petits connecteurs des haut-parleurs droite/gauche se cassent très facilement.
    • Faites extrêmement attention ; ce connecteur se casse facilement.
    While these connectors are very delicate, a new upper body case will have new connectors already installed. I slightly broke two connectors while removing them.
    Also, the connectors have a notch underneath (on the logic board) for the corner of the spudger to fit into. The hard part is that you cannot see the notches until the connectors are removed.
    Nations81 - Réponse
    Hi. Long time ago, I know but.... How did you fix them?
    I snapped mine off, can it be soldered back on?
    Simon G -
    I used pointed tip of one side of the tweezers from the ifixit Home Tech Toolkit. I found this thinner pointed tip better than a spudger for hitting that notch in the socket underneath the connectors. Since this is a metal tool, I pried very gently and I was working on a MacBook with the battery taken out entirely (early on as suggested in the video) and was also using an Anti-Static wrist strap. I found the spudger broke one of the connectors because it's relatively thick plastic, and put too much pressure under the cables before the tip could reach the plastic block of the connector. The pressure under the cable popped the wire contact right through the top of the plastic block connector. (it was OK this connector broke since I didn't need to reuse it--my replacement keyboard/upper case came with its own cables.)
    Because the tips of the tweezers are angled, I felt I had better control of the torque I was applying than if I used a jeweler's flathead screwdriver.
    kenhtanaka - Réponse
    i used a very sharp dental pick - a tool i've permanently "added" to my ifixit tool kit bag
    pprod - Réponse
    Using a needle/pin works well. I did what another person mentioned in Step 8. Pry up from the back corner with the tip of the needle. Be gentle. One side will pop up a tiny bit. Move to the other side and gently pry there. Mine popped out completely at that point.
    stanos1 - Réponse
    Totally agree with the needle solution prying up from the side of the connector. A dentist tool is perfect!
    (yes, in 2021 i’m fixing a 2009 macbook! :P)
    Filippo Giadrossi - Réponse
  11. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 11, image 1 de 1
    • Avec l'extrémité plate d'une spatule (spudger), retirez le connecteur du lecteur optique de la carte mère.
  12. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 12, image 1 de 2 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 12, image 2 de 2
    • Avec une spatule, faites levier pour retirer le connecteur du haut-parleur droit et le connecteur du LED veille de la carte mère.
    • Ces connecteurs sont très fragiles et se cassent facilement.
    I broke a speaker connector on this step. I found it easier to use a tiny flathead screwdriver to gently pry these connectors up.
    brad - Réponse
    Did u manage to fix the broken speaker connexion Brad? Mine snapped off. How can I fix that?
    Simon G - Réponse
    what is the connector in the image that is two prong and has the orange and red box around it in the 3rd image? Need to replace that connector. Please help. Part number would be great
    ajfrasca - Réponse
  13. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 13, image 1 de 1
    • Avec l'extrémité plate d'une spatule, soulevez le connecteur de la nappe du pavé tactile pour le débrancher de sa prise sur la carte mère.
  14. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 14, image 1 de 2 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 14, image 2 de 2
    • Avec votre ongle, ouvrez le clapet de retenue de la prise ZIF de la nappe du clavier.
    • Avec la pointe d'une spatule, faites glisser la nappe du clavier hors de sa prise.
    I had to remove the battery again to insert the keyboard ribbon cable. I just couldn't get the right angle and force otherwise.
    asciimo - Réponse
    When reassembling make sure this cable is really deep in it's socket. (Use some force with the spudger wedging it in between the cable and battery). If you don't, you won't be able to power up the board. I had 2 logicboards that I thought were dead, but it turned out the cable was not inserted enough. Jump starting them with the jump pads did nothing (with or without cable connected), but connecting the cable properly made the board come alive. Really check this!!
    Peterdk - Réponse
    You sir, just saved my day! Switching boards between two mac and I thought I broke the two at once... This should be documented on the manual!!
    jorgecarleitao -
    Thanks for your help!!! I thought I did the replacement wrong. Greetings from Peru.
    Lalo Gonzalez -
    This was hugely helpful! The cable requires much more force than expected.
    Daniel DeGrasse -
    There really should be a comment in the steps regarding tips on how to put the ribbon back in. The tape did the trick and I am back up and running.
    alexhgreene - Réponse
    The two silver squares above the left corner of the Keyboard and to the right of the Trackpad cable ribbon are the jump pads to power on the MacBook if your power button may not be working.
    Jason Ognosky - Réponse
    Accidentally I broke this flap thing. Can I replace it some point?
    Thank you!
    MJS Nope - Réponse
    Nope big job to replace it. Use Kapton tape to hold it in place. https://www.amazon.com/Retermit-Resistan...
    mayer - Réponse
  15. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 15, image 1 de 1
    • Avec l'extrémité plate d'une spatule, soulevez le connecteur de la nappe du disque dur pour le débrancher de la carte mère.
  16. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 16, image 1 de 2 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 16, image 2 de 2
    • Avec une spatule, soulevez le connecteur du haut-parleur gauche et le connecteur du microphone pour les débrancher de la carte mère.
    Note: the 2009 and 2010 model differ here. On one the 3 point connector is left and 2 point is right, on the other one the 3 point connector is right and 2 point is left.
    I found this while installing several logicboards for A1342.
    Peterdk - Réponse
    @Peterdk, are the connectors exchangeable?
    I mean, would putting the 3 pin on the 3 pin, and the 2 pin on the 2 pin, regardless of the position (left or right) be ok?
    Have you successfully used a 2010 logic board on a 2009 case?
    Alberto Einstein -
    I can't seem to connect those any suggestions
    Ayat - Réponse
    how do you reconnect these?
    yourstruly69101 - Réponse
    hi! i know iʻm 6 years late, and you probably figured it out already, but for the rest of us newbies , line the plug over the socket and gently press down. the correct orientation of the plug is the side with the tiny slots in them faces the logic board, aligning with the contacts in the socket. it may help to press the side farthest from the ribbon cable first.
    Kahana -
  17. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 17, image 1 de 2 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 17, image 2 de 2
    • Saisissez la languette en plastique fixée au dispositif de verrouillage du câble de données de l'écran et pivotez-la vers le côté DC-In (prise d'alimentation) de l'ordinateur.
    Just lift the tab up slightly to release the clip that secures the data display cable. Then the cable will slide out easily.
    matt15 - Réponse
    If the video data cable has been disconnected before, the adhesive on the might not hold. Be extra cautious in disconnecting this. An illuminated magnifier would be a good help on this step as it is very delicate. This was where I feared I would fail. Was very relieved in getting through this step...
    svenaustx - Réponse
    I wasn't careful enough here, and didn't realize that the silver metal piece around the connector is actually a locking clip. No wonder disconnecting the cable required more than a gentle pull. The clip popped out of the cable-side connector in the process, and was bent; fortunately I was able to very carefully bend the clip out just enough to get it re-seated in the connector; there are tiny slots on the sides of the connector that the clip fits into.
    kmcrawford111 - Réponse
  18. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 18, image 1 de 2 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 18, image 2 de 2
    • Tirez délicatement le connecteur du câble de données de l'écran hors de sa prise sur la carte mère.
    • Tirez parallèlement à la surface de la carte mère.
    • La prise du câble de données de l'écran est en métal très fin et se tort facilement. Assurez-vous de tirer le connecteur tout droit hors de sa prise.
  19. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 19, image 1 de 1
    • Dévissez les six vis Torx T6 de 4,1 à 4,4 mm fixant la carte mère au boîtier supérieur.
    • Dévissez les deux vis Torx T6 de 4,1 à 4,4 mm fixant la carte de raccordement MagSafe au boîtier supérieur.
    • Sur quelques modèles, vous pouvez trouver des vis T7. Veillez alors à ne pas abîmer la tête de vis avec un embout trop petit.
    incorrect photo of motherboard...
    Devin R - Réponse
  20. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 20, image 1 de 3 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 20, image 2 de 3 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 20, image 3 de 3
    • Soulevez le côté de la carte mère opposé aux ports hors du boîtier supérieur.
    • Faites pivoter la carte mère hors du boîtier supérieur jusqu'à ce que les ports s'écartent du bord moulé dans le boîtier supérieur.
    • Éloignez la carte mère et la carte de raccordement MagSafe du bord du boîtier supérieur, comme si elles étaient d'une pièce.
    • La carte de raccordement MagSafe peut se déconnecter accidentellement au cours de cette étape. Par précaution, assurez-vous que le connecteur de la carte carte de raccordement MagSafe est bien fixé dans sa prise avant de rabattre la carte mère dans le boîtier supérieur.
    • Avant de rabattre la carte mère dans le boîtier supérieur, assurez-vous que les nappes du haut-parleur gauche et du microphone sont correctement acheminés (comme sur la troisième photo).
    (When re-installing) Before screwing down the logic board, go around the edge and make sure no cables are caught underneath, remember there are 11 of them, 12 if the battery is present at this point.
    I reassembled the macbook A1342 using this guide and everything is perfect, except that if I shut down the computer and power it up after 1hour or so, I have to press the power button a few times before it starts. What could I have gone wrong? I checked the magsafe connector and it seems to be firmly seated. :(
    Alok - Réponse
  21. Remplacement du boîtier supérieur MacBook Unibody modèle A1342, Boîtier supérieur: étape 21, image 1 de 2 Remplacement du boîtier supérieur MacBook Unibody modèle A1342, Boîtier supérieur: étape 21, image 2 de 2
    • Dévissez les deux vis cruciformes Phillips attachant la fixation du disque dur au boîtier supérieur.
    • Ces vis sont captives et restent prises dans la fixation du disque dur.
    • Ôtez la fixation du disque dur du boîtier supérieur.
  22. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 22, image 1 de 1
    • Soulevez le côté dégagé du disque dur et éloignez-le du côté du boîtier supérieur.
    • Le disque dur est toujours attaché au boîtier supérieur par la nappe du disque dur.
  23. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 23, image 1 de 2 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 23, image 2 de 2
    • Déconnectez le disque dur en retirant le connecteur de la nappe du disque dur de sa prise sur le disque dur.
  24. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 24, image 1 de 2 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 24, image 2 de 2
    • Dévissez l'unique vis cruciforme de 3,1 mm fixant la nappe du disque dur au boitier supérieur.
    • Ôtez la nappe du disque dur du boîtier supérieur.
  25. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 25, image 1 de 1
    • Dévissez les deux vis Tri-Wing de 5 mm fixant la batterie au boîtier supérieur près du connecteur de la batterie.
  26. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 26, image 1 de 1
    • Avec la pointe d'une spatule (spudger), décollez soigneusement la languette de l'étiquette d'avertissement pour faire apparaître une vis Tri-Wing cachée.
    • Dévissez la vis Tri-Wing de 5 mm fixant la batterie au boîtier supérieur.
  27. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 27, image 1 de 1
    • Dévissez les trois vis cruciformes fixant la batterie près du bord du boîtier supérieur.
    • Quand vous réinstallez la batterie, veillez à remettre ces trois vis avant les vis Tri-Wing. Faites attention à la nappe du clavier, vous devrez éventuellement la maintenir de côté avec l'extrémité plate d'une spatule au moment de remettre la batterie dans son emplacement.
    When reinstalling, I leave this step till last. It'll help you get that frackin keyboard ribbon inserted.
    maccentric - Réponse
  28. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 28, image 1 de 1
    • Saisissez la batterie près de son connecteur et ôtez-la du boîtier supérieur.
    • Au moment de remettre la batterie, vérifiez que la nappe du clavier n'est pas coincée en dessous.
  29. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 29, image 1 de 3 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 29, image 2 de 3 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 29, image 3 de 3
    • Avec la pointe d'une spatule, soulevez les connecteurs des antennes AirPort/Bluetooth (trois au total) de la carte AirPort/Bluetooth.
    • Si nécessaire, enlevez le long câble d'antenne de sa fente dans le boîtier du haut-parleur arrière.
    To save some time and frustration, leave the antennae connected, just take off the 3 screws holding the speaker down and lift it out of the way. You will remove everything with the screen.
  30. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 30, image 1 de 1
    • Dévissez l'unique vis cruciforme de 3 mm fixant la tresse de masse de l'antenne au boîtier du haut-parleur arrière.
  31. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 31, image 1 de 1
    • Dévissez l'unique vis cruciforme de 2,2 mm insérée horizontalement dans le côté du lecteur optique.
    I couldn’t access this screw with the screwdriver I had (socket head was too big). But I didn’t need to remove this screw anyway. Just leave the speaker assembly (step 33) attached to the optical drive.
    Vaughn Berger - Réponse
  32. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 32, image 1 de 1
    • Dévissez l'unique cis cruciforme de 12 mm fixant le haut-parleur arrière au boîtier supérieur.
  33. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 33, image 1 de 1
    • Ôtez l'ensemble haut-parleur arrière de votre MacBook.
  34. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 34, image 1 de 1
    • Dévissez l'unique vis cruciforme de 4,5 mm fixant le bord intérieur du lecteur optique au boîtier supérieur.
  35. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 35, image 1 de 1
    • Dévissez les deux vis cruciformes de 2,5 mm fixant le lecteur optique au boîtier supérieur près de l'ouverture du lecteur.
  36. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 36, image 1 de 1
    • Saisissez le lecteur optique du près de son connecteur et retirez-le du boîtier supérieur pour l'ôter de l'ordinateur.
  37. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 37, image 1 de 1
    • Ouvrez votre MacBook de sorte que l'écran est perpendiculaire au boîtier supérieur.
    • Posez votre MacBook sur une table comme sur la photo.
    • Pendant que vous maintenez ensemble l'écran et le boîtier supérieur avec votre main gauche, dévissez l'unique vis Torx T8 restante de la fixation inférieure de l'écran.
    • Avant de resserrer les vis Torx T8, fermez l'écran et ajustez-le afin que les bords arrières du boîtier supérieur et de l'écran soient alignés et que les interstices aux bouts de la charnière correspondent.
    Torx screws could be T9 and not T8. Be sure your Torx driver fits snugly into the screw so that you don't strip it.
    evandove - Réponse
  38. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 38, image 1 de 1
    • Veillez à maintenir ensemble l'écran et le boîtier supérieur avec votre main gauche. Si vous lâchiez l'écran ou le boîtier, un de ces composants pourrait tomber et s'endommager.
    • Dévissez la dernière vis Torx T8 restante fixant l'écran au boitier supérieur.
  39. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 39, image 1 de 2 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 39, image 2 de 2
    • Saisissez le boîtier supérieur de votre main droite et faites-le légèrement pivoter vers le haut de l'écran afin que la fixation supérieure de l'écran s'éloigne du bord du boîtier supérieur.
    • La fixation supérieure de l'écran pourrait rester accrochée au boîtier supérieur à cause du câble de données de l'écran. Il peut être utile de faire pivoter le boîtier supérieur et de l'éloigner légèrement de l'écran pour mieux y voir.
    • Faites pivoter et éloignez légèrement l'écran du boîtier supérieur.
  40. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 40, image 1 de 1
    • Soulevez et retirez l'écran du boîtier supérieur en veillant à ce que aucune fixation ni aucune nappe ne reste accrochée.
  41. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 41, image 1 de 3 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 41, image 2 de 3 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 41, image 3 de 3
    • Il y a quatre inserts en caoutchouc orange et noir aux endroits où le disque dur était fixé, d'un côté des cercles complets et de l'autre des demi-cercles. (Les autres demi-cercles se trouvent sur la fixation du disque dur, qui a déjà été retirée.)
    • Il se peut que le nouveau boîtier supérieur n'ait pas ces inserts. Assurez-vous de les enlever de l'ancien boîtier et de les réinsérer dans le nouveau boîtier.
    • Il est facile de retirer les inserts avec une spatule ou un tournevis plat. Ils ne sont pas collés mais maintenus en place par une extrémité entaillée.
  42. Remplacement du boîtier supérieur MacBook Unibody modèle A1342, Boîtier supérieur: étape 42, image 1 de 1
    • Dévissez les quatre vis cruciformes de 1,3 mm fixant le bord supérieur du pavé tactile au boîtier supérieur.
  43. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 43, image 1 de 1
    • Inclinez soigneusement le pavé tactile en l'éloignant du côté clavier du boîtier supérieur.
    • Enlevez le pavé tactile de son emplacement dans le boîtier supérieur pour dégager les deux languettes d'attache sur le bord inférieur.
  44. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 44, image 1 de 1
    • Dévissez la vis de blocage Torx T6 de 1 mm à côté du bord avant du boîtier supérieur.
  45. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 45, image 1 de 2 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 45, image 2 de 2
    • Suivez les instructions suivantes pour installer l'ancien pavé tactile dans votre nouveau boîtier supérieur.
    • Revissez la vis de blocage Torx T6 jusqu'à ce qu'elle soit alignée avec la fixation en aluminium entourant la pavé tactile.
    • Remettez le pavé tactile dans son emplacement dans le boîtier supérieur. Assurez-vous d'abord que les languettes d'attache sont insérées sous le boîtier supérieur du côté clavier.
    • Veillez à ne pas coincer la nappe du clavier entre le pavé tactile et le boîtier supérieur.
    this is saying the THREADED END of the screw should be flush with the aluminum bracket into which it is threaded.
    tom - Réponse
  46. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 46, image 1 de 2 Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 46, image 2 de 2
    • Remettez les quatre cis cruciformes argentées fixant le pavé tactile à ses fixations en acier.
    • Desserrez les quatre vis argentées d'un seizième de tour
    • Retournez le boîtier supérieur et ajustez la position du pavé tactile jusqu'à ce que l'espace entre le pavé et le boîtier supérieur soit réparti régulièrement tout autour du périmètre du pavé tactile.
    • Serrez les quatre vis argentées pour maintenir le pavé tactile en place.
    • Répétez cette étape jusqu'à ce que le pavé tactile soit parfaitement positionné dans son emplacement dans le boîtier supérieur.
  47. Remplacement du boîtier supérieur MacBook Unibody modèle A1342: étape 47, image 1 de 1
    • Pendant que vous cliquez de façon répétée sur le pavé tactile pour simuler un clic, serrez la vis de blocage Torx T6 jusqu'à ce que le pavé ne bouge plus librement.
    • Ne serrez pas trop la vis de blocage, sinon le pavé arrêtera de cliquer à un certain point. Ajustez la vis de blocage jusqu'à ce que la partie mobile du pavé tactile ait un minimum de jeu.
Pour remonter votre ordinateur, suivez les instructions dans l'ordre inverse.
198 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
25 commentaires
NOTE: Ensure you don't pull the entire assembly straight up or the base will come off the logic board. Use an extremely small straight blade screw drive to gently loosen the inside assembly while gently pulling on the wire bundle! Will save buying a new logic board!!!!
janesem - Réponse
Some of the screws are extremely tight, I stripped at least 6 Phillips screws during the upper case replacement.
firstn10 - Réponse
I used the iFixit 54 bit kit and found that the Phillips 000 bit fits the screws better than the recommended 00 bit. When loosening or tightening I use plenty of downward pressure to keep the bit from rising out of the screw head and damaging it. The torx screws are so much easier to work with and I wonder why they don't use only those.
Matthew Hester -
Definitely only use unworn, appropriately sized drivers when going into any Mac or iPhone. If the driver starts to slip, stop and access the situation. That said, I have encountered many screws with damaged screw heads. I usually first try the “rubber band” trick to loosen the ruined screw. If that doesn’t work, I often resort to using a dremel tool to cut a slot in the screw (while protecting everything from the debris generated). In all cases, be careful - one slip can do a lot of damage.
Lance J -
Great guide! My only comment would be to remove the battery first. It makes dealing with the keyboard ZIF cable much easier to install/remove.
sales - Réponse
I like that idea. I did feel challenged by the tight space when trying to put it back in it's socket.
Matthew Hester -
Similarly, re-installing the logic board before the battery is helpful, as it reduces the amount of cable interference.
Lance J -
I went a little further and, although is not recommended, I unglued the Upper case from the keyboard and replaced it after a coffee accident. Had to reglue the new keyboard back in place and it´s working. The fix is not very good (keys dont go up as when originally assembled) so I´d recomend you to change the whole upper case instead of trying to change the keyboard as you may actually break it.
vendemechiles - Réponse
is there a way i can rip the keyboard of the upper case??? and then later put it back together? look forward to spray painting my laptop.
Akhil John - Réponse
I don't know much about paints but I'm guessing that it would scratch and flake easily unless you use the correct paint, and even then it might deteriorate rapidly leaving a mess and poor appearance.
Matthew Hester -
Is it possible to replace only the keyboard? I do not want to replace the whole upper case. also where can I buy the keyboard only online? Please share a link.
Thank you
Churchill - Réponse
I did it. Got a new keyboard on ebay (only the keyboard) but the process of replacing it breaks tiny holds it has on the cover so when you put thw new one the keys in the middle (hgtyvb) do not stand up as the others. they sink a little bit. I'd suggest to replace the whole part unless you are ok with this aesthetic issue.
Mine have been working pretty well so far.
vendemechiles -
You bet it’s possible. It’s a lot of work. If you have a top case in nice physical condition, you might want to consider it. Search YouTube for an overview. Doing this requires breaking a lot of epoxy bonds, and then re-applying a lot of epoxy. An A1278 MBP keyboard will fit, but you’ll have to get a little inventive when it comes to attaching it, and the power button cable routing is a little different.
My A1342 MacBook has a black MBP keyboard in it.
Lance J -
I was trying to do this, and the power came on when I put the battery in. I turned it off from the keyboard, and then it immediately powered on. After I took the battery out and tried reassembling by putting everything but the battery in, and then connecting the battery at the end, I had no power whatsoever, either from the power cable or from the battery. What could have caused this?
Yvonnel - Réponse
I tried this. Got all the components undone, replaced the trackball, and started replacing the components. Midway through, I noticed that the computer had turned on. I turned it off with the power button, and it immediately turned itself back out. I removed the battery, and started putting the components back together, this time putting the battery on last. Now, the computer won't turn on at all. No LED from the power cable, won't turn on from the battery. Does anyone have any ideas?
Yvonnel - Réponse
It looks harder than it actually is! Just keep track of what screws are what (number them with what step in the instructions they're from), put some good music on and it'll be fine. Great guide.
ryancurle - Réponse
I'm still dumbfounded that changing the keyboard is such an ordeal. That being said... EXCELLENT JOB on the guide! Thank you very much.
Changing the keyboard is a big deal because the keyboard is bonded to the top case - and the top case bracket acts as the chassis that holds everything together. But changing out the top case is more tedious than challenging.
Lance J -
I Have a macbook with the rubber elastic band like seal on hinge coming out, how do you get this back in without it bulging out?
Greg Brooker - Réponse
I got my macbook used and it already had some cracks in the top case. they are now getting worse. I was wondering if it is possible to replace my white poly case with an aluminum one. is there an aluminum that is compatible with the a1342?
Tiffany Reveles - Réponse
Despite their similarities, most of the important internals of the A1342 will not fit within any aluminum MacBook housing.
The only parts that you might get to fit are: the drives, the LCD panel (not its housing), and the keyboard (sort-of, and not its housing)
Possible Solution 1:
Shore up cracks and holes with an appropriate epoxy and/or epoxy filler. Hide resulting repair cracks with a fancy vinyl overlay or protective snap-on case
Possible Solution 2:
Find good replacement A1342 housing parts, which are readily available on the used market.
Lance J -
Anybody still looking at this? I replaced my top case because the keyboard was shot. Put it all back together and now the screen won’t work. The connector is not bent. No idea why it won’t work.
the computer apparently starts up - I hear the chime- and the volume buttons control the speakers. Without the screen I can’t tell anything else.
Timothy McPherson - Réponse
I cleaned the contacts and reinserted the connector. Nothing.
Reset PRAM. Nothing.
Timothy McPherson -
Glad for the set screw tip. My replacement case already had the trackpad installed but it was too tight.
Dan Hustmyer - Réponse
Really good guide. I had bought an IFixIt tool kit before and it was extremely helpful in doing this teardown. The only thing that was beezlebub was that my trackpad wasn't working after I replaced the top case (bought from Ebay). The cursor worked but not the clicking. After struggling for a while doing all sorts of things, I finally ended up adjusting that set screw in step 47. I had ignored it the first time as the top case came with the trackpad and I ASSUMED. So, make sure you pay attention to this, it's critical though it's easy enough to adjust after everything is put back it. Just have to take out the battery so I was grateful for that.
Seacrest Smith - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 23
30 derniers jours : 66
Total : 178,719
