Aller au contenu principal
SOMNOcomfort and SOMNObalance Ventilator Fan Replacement
Diya Jamwal
Diya Jamwal et un autre contributeur
Dernière mise à jour le July 3, 2020
1 heure
Difficile
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Reference page 28-30 from the Service and Repair Instructions linked under Documents on the Main Page.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement, How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): étape 1, image 1 de 1
    • Remove the covering cap. (pg. 23)
  2. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 2, image 1 de 1
    • Place the unit upside down on a non-slip surface and remove the six screws. (pg. 23)
  3. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 3, image 1 de 1
    • Remove the lower part of the housing with a swiveling motion away to the side. Note the SOMNOcomfort series uses a shorter circuit board than the balance series ventilator. (pg. 23)
  4. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 4, image 1 de 3 SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 4, image 2 de 3 SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 4, image 3 de 3
    • Remove the connector (X1) from the circuit board.
    • Pull the connecting cable (64) from its mount.
    • Now set aside the lower part of the housing. (pg. 23)
  5. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 5, image 1 de 2 SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 5, image 2 de 2
    • Next, how to close the compartment and reverse the process.
    • Hold the lower part of the housing to the upper part at an angle
    • Attach the connector (X1) to the main circuit board. When doing so the connector’s nub has to point towards the lock. (pg. 24)
  6. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 6, image 1 de 2 SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 6, image 2 de 2
    • Properly align the main circuit board inside the unit.
    • Attach the connecting cable (64) to its mount (pg. 24)
  7. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 7, image 1 de 1
    • Place the lower part of the housing on the upper part (47). Please make sure the main circuit board (44) is aligned properly, and that the connecting cable (64) is not being squeezed anywhere. (pg. 24)
  8. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 8, image 1 de 1
    • Now reattach the upper part of the housing by tightening the six screws. (pg. 24)
  9. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 9, image 1 de 1
    • Insert the covering cap. (pg. 24)
  10. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement, Fan: étape 10, image 1 de 1
    • Remove baffle box.
  11. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 11, image 1 de 2 SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 11, image 2 de 2
    • Remove the decoupling tube(50) from the box.
  12. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 12, image 1 de 1
    • Remove the box(53) in an upwards motion. Leave the Foam bottom (59) attached.
  13. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 13, image 1 de 1
    • Remove the four screws (69) in the cover of the baffle box (60).
    • Remove the foam cover (58) and the cover of the baffle box (60).
  14. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 14, image 1 de 1
    • Remove the foam bottom and separate the two parts of the baffle box.
  15. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 15, image 1 de 1
    • Pull the decoupling tube(55) out of the motor frame’s borehole7.
  16. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 16, image 1 de 1
    • Loosen the motor mount(54). Cut the mount using scissors or scalpel.
    • Remove the Fan.
  17. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 17, image 1 de 1
    • Place three new motor mounts(54) into the box.
  18. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 18, image 1 de 1
    • Insert the fan into the motor frame and attach it using the motor mounts(54). Pull the motor mounts through the boreholes of the fan to reach the surrounding notch.
  19. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 19, image 1 de 1
    • Apply a small amount of 70% Isopropanol solution on the decoupling tube’s(55) circumference and attach it to the box. The tube’s notch must completely lock into the bore hole rim.
  20. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 20, image 1 de 1
    • Reconnect the two parts of the box. Pay attention to the proper alignment of the foam part (61) and the correct cable lead. The cable must be placed in the appropriate cut-out.
  21. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 21, image 1 de 1
    • Place the cover on the box and insert the screws.
  22. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 22, image 1 de 1
    • Insert Baffle Box. Place foam 58on the box, soft side up. You must be able to see the screw heads of the box through the holes in the foam
  23. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 23, image 1 de 1
    • Insert box(53) and foam (58) into the housing(47). Make sure the foam is spread out evenly.
  24. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 24, image 1 de 1
    • Pull the protective backing off the adhesive tape and stick on foam(59). Use the crosses as a positioning aid.
  25. SOMNOcomfort and SOMNObalance Ventilator Fan Replacement: étape 25, image 1 de 1
    • Apply a small amount of 70% Isopropanol solution on the decoupling tube’s (50) circumference and attach it to the box. The tube’s notch must completely lock into the bore hole rim.
Diya Jamwal
Membre depuis le 11/07/18
553 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S1-G3, Zimmerman Spring 2020 Membre de l'équipe Cal Poly, Team S1-G3, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G3
5 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 13
30 derniers jours : 23
Total : 178
