Samsung Gear S2 Battery Replacement
Introduction
Passez à l'étape 1Does your watch battery last less than a day with minimal use, or does the watch only power on when connected to the charger? Replacing the battery may fix these problems.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
Flip the watch over so that the face is down.
Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
Outil utilisé dans cette étape :Tweezers$4.99
Using tweezers, lift the battery casing.
102 autres ont terminé cette réparation.
39 commentaires
Excellent guidelines, and do you have steps for s3 frontier
A reference to the battery part number would be great.
Very good job and very easy
eb-br720ABE
