Aller au contenu principal
Scotch TL901 Heating Element Replacement
JackMacWindows
JackMacWindows et 3 autres contributeurs
Dernière mise à jour le July 31, 2024
5 minutes
Facile
Tutoriel réalisé par la communauté
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Scotch TL901 Heating Element Replacement, Unscrewing top: étape 1, image 1 de 1
    • Remove six Phillips screws from underneath the unit. Four screws are placed under the pads, one is open, and one may be covered by a sticker.
  2. Scotch TL901 Heating Element Replacement, Removing cover: étape 2, image 1 de 1
    • Open the unit by holding down the black bottom and pulling the silver top off.
    • Be careful of the wires connecting the power switch, as the power switch is screwed to the top case..
    • Remove the beige-colored foam piece from the rollers. This is where the heating element is placed.
    • It may be hard to remove the element from the rollers because the element is tightly fastened in between the rollers.
    • Pull off the cover to the fuse underneath. This may also be hard because the foam material is very grippy.
    • You can either cut off the fuse from the wire or desolder the fuse. I chose to cut the fuse off, because I do not have tools needed to desolder.
    • Then just solder the new fuse onto the wires. You may want to make sure to have solder that can handle high temperatures, as this will go up to about 200 °C.
JackMacWindows
Membre depuis le 04/10/17
128 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 15
Total : 1,099
