Aller au contenu principal
Shark ION Robot R75 Battery Replacement
Andrew Lowy
Andrew Lowy et 3 autres contributeurs
Dernière mise à jour le May 7, 2024
2 minutes
Facile
This guide will show the simple procedure of how to replace the battery on your Shark ION Robot R75. Before performing any maintenance or disassembly, ensure that the robot is turned off.
The battery supplies power to the vacuum while it is undocked and performing its cleaning functions throughout the desired area. While the robot should return to its dock at the end of its programmed path, it’s possible that the vacuum starts running out of battery before completing the program, especially as the device ages and the battery degrades. If your Shark Robot starts to die mid-cycle before reaching its charging dock, a battery replacement may restore your trusty vacuum to its former glory.
The part number for a replacement battery is RVBAT700 and can be purchased directly from Shark’s site.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Shark ION Robot R75 Battery Replacement, Battery: étape 1, image 1 de 3 Shark ION Robot R75 Battery Replacement, Battery: étape 1, image 2 de 3 Shark ION Robot R75 Battery Replacement, Battery: étape 1, image 3 de 3
    • Make sure the robot is shut off by pressing the power button on top.
    • Flip the R75 over so that the underside is facing up.
    • Using a Phillips #1 screwdriver, remove the 4mm screw in the battery cover.
    • Remove the battery cover.
  2. Shark ION Robot R75 Battery Replacement: étape 2, image 1 de 3 Shark ION Robot R75 Battery Replacement: étape 2, image 2 de 3 Shark ION Robot R75 Battery Replacement: étape 2, image 3 de 3
    • Be careful when removing the battery, as it will still be connected to a wire.
    • Slowly pull the white tabs outward to remove the battery.
  3. Shark ION Robot R75 Battery Replacement: étape 3, image 1 de 2 Shark ION Robot R75 Battery Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    • Be careful when removing the connector, as the part can break if too much force is used.
    • Push down on the tab of the battery connector using a set of tweezers and pull the connector away from the robot to free the wire.
    • Remove the battery from the device.
3 autres ont terminé cette réparation.
1 commentaire de tutoriel
After charging for several hours, my robotic shark stops after 10 minutes. I can push the start button and it will run for another 10 minutes. This has been repeated several times with out it docking itself. What are your thoughts on this?
Marsha Moon - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 67
Total : 7,795
