Aller au contenu principal
SodaStream Fountain Jet A200 Spring Replacement
Katie Fetters
Katie Fetters et 3 autres contributeurs
Dernière mise à jour le July 9, 2024
10 minutes
Facile
This guide will be used to instruct a person how to replace the spring that controls the up and down motion of the carbonation button should it become worn over time.
  1. SodaStream Fountain Jet A200 Spring Replacement, removing back cover: étape 1, image 1 de 2 SodaStream Fountain Jet A200 Spring Replacement, removing back cover: étape 1, image 2 de 2
    • Press in the two gray buttons found on either side, at the top of the machine.
    • Pull back on the cover until it releases from the device and pull the back off.
  2. SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: étape 2, image 1 de 2 SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: étape 2, image 2 de 2
    • Place your hand under the carbonation button and gently pull up and away from you, towards the back of the machine.
  3. SodaStream Fountain Jet A200 Spring Replacement, spring removal: étape 3, image 1 de 2 SodaStream Fountain Jet A200 Spring Replacement, spring removal: étape 3, image 2 de 2
    • Remove the spring located under the carbonation button.
    • Replace with the new spring, by lining it up and pushing it down.
5 autres ont terminé cette réparation.
Katie Fetters
Membre depuis le 09/17/14
815 Réputation
4 tutoriels rédigés
Équipe
2 commentaires de tutoriel
Does anyone know where I can get a carbonation button?
draganr@wi.rr.com
draganr - Réponse
Do we know the spring parameters?
Outside Diameter
Inside Diameter
Overall Length
Wire Diameter
Total # of Coils
Active # of Coils
Solid Height
Space between the Coils
John Friedman - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 33
Total : 10,572
