Aller au contenu principal
Sony Alpha NEX-6 Lens Mount Replacement
Ce dont vous avez besoin
  1. Sony Alpha NEX-6 Lens Mount Replacement, Finding the Release Button: étape 1, image 1 de 1
    • Turn the camera with the lens facing up.
    • Find the lens release button - located along the side of the silver lens mount.
  2. Sony Alpha NEX-6 Lens Mount Replacement, Removing the Lens: étape 2, image 1 de 2 Sony Alpha NEX-6 Lens Mount Replacement, Removing the Lens: étape 2, image 2 de 2
    • Press and hold the lens release button while rotating the lens counterclockwise.
    • Lift the lens when it is no longer attached to the camera.
    • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
    • Insert the lens and rotate it clockwise until it is locked in place.
  3. Sony Alpha NEX-6 Lens Mount Replacement, Lens Mount: étape 3, image 1 de 1
    • While dealing with this guide, do not touch the delicate image sensor (the center rectangle encircled by the lens mount).
    • After removing the lens, you will come into contact with the lens mount. Start by unscrewing the four 3.5 mm Phillips #00 screws.
    • The outer lens mount ring can now be removed.
  4. Sony Alpha NEX-6 Lens Mount Replacement: étape 4, image 1 de 3 Sony Alpha NEX-6 Lens Mount Replacement: étape 4, image 2 de 3 Sony Alpha NEX-6 Lens Mount Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Pay attention to the positioning of the spacer rings for reassembly.
    • For the first (black) spacer ring, use the tweezers to gently pry the ring out of place.
    • Repeat this step for the second (silver) spacer ring.
    • The third image is what the camera should look like after all spacer rings are removed.
  5. Sony Alpha NEX-6 Lens Mount Replacement: étape 5, image 1 de 2 Sony Alpha NEX-6 Lens Mount Replacement: étape 5, image 2 de 2
    • To remove the inner lens mount ring, remove the two silver 2.0 mm Phillips #00 screws. This will complete the removal of the lens mount.
3 autres ont terminé cette réparation.
Clayton Dale
Membre depuis le 01/20/15
1 067 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 11-2, Blackwell Winter 2015 Membre de l'équipe USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 membres
14 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 16
Total : 1,757
