Sony Alpha NEX-6 Lens-release Button Replacement
Introduction
Passez à l'étape 1Prior to replacing the lens-release button, the lens and the lens mount must first be removed. Following this, the button may be swiftly removed.
Ce dont vous avez besoin
Turn the camera with the lens facing up.
Find the lens release button - located along the side of the silver lens mount.
Press and hold the lens release button while rotating the lens counterclockwise.
Lift the lens when it is no longer attached to the camera.
After removing the lens, you will come into contact with the lens mount. Start by unscrewing the four 3.5 mm Phillips #00 screws.
The outer lens mount ring can now be removed.
Outil utilisé dans cette étape :Tweezers$4.99
By using tweezers, carefully remove the lens-release button by lifting upward.
