Aller au contenu principal
Sony CPF-IP001 Subwoofer Replacement
Mike Bolton
Mike Bolton et 4 autres contributeurs
Dernière mise à jour le June 25, 2015
30 minutes
Modérée
Tutoriel étudiant vedette
This guide will show you how to replace the subwoofer speaker if you hear muffled or distorted sound coming from the subwoofer unit.
Ce dont vous avez besoin
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Sony CPF-IP001 Subwoofer Replacement, Subwoofer Housing Disassembly: étape 1, image 1 de 2 Sony CPF-IP001 Subwoofer Replacement, Subwoofer Housing Disassembly: étape 1, image 2 de 2
    • Remove fourteen 8 mm Phillips #2 screws from the bottom of the subwoofer.
    • Once all of the screws are removed, the cover can be taken off using a metal spudger.
  2. Sony CPF-IP001 Subwoofer Replacement: étape 2, image 1 de 2 Sony CPF-IP001 Subwoofer Replacement: étape 2, image 2 de 2
    • Remove eight 14 mm Phillips #2 screws holding the circuit board in place.
    • Using the plastic opening tool, carefully remove the circuit board.
    • There will be 3 wires connected to the opposite side of the circuit board. Be careful not to pull the board out of the device too far and damage these wires.
  3. Sony CPF-IP001 Subwoofer Replacement: étape 3, image 1 de 2 Sony CPF-IP001 Subwoofer Replacement: étape 3, image 2 de 2
    • Remove the first of the three wires by squeezing the clip and pulling it out.
    • After disconnecting the first wire, the two attached wires can be more easily accessed.
  4. Sony CPF-IP001 Subwoofer Replacement: étape 4, image 1 de 3 Sony CPF-IP001 Subwoofer Replacement: étape 4, image 2 de 3 Sony CPF-IP001 Subwoofer Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Remove the wire furthest to the left by squeezing the clip and pulling it out.
    • Detach the third wire by carefully using the tweezers.
    • The circuit board is now completely detached and can be set aside.
  5. Sony CPF-IP001 Subwoofer Replacement: étape 5, image 1 de 2 Sony CPF-IP001 Subwoofer Replacement: étape 5, image 2 de 2
    • Remove six 8 mm Phillips #2 screws.
    • Slide the side panel with the power cord out from the housing.
    • The side panel with the power cord will come out as a whole unit with the subwoofer air tunnel.
  6. Sony CPF-IP001 Subwoofer Replacement, Subwoofer: étape 6, image 1 de 1
    • Remove two 8 mm Phillips #2 screws holding the side panel in place.
  7. Sony CPF-IP001 Subwoofer Replacement: étape 7, image 1 de 1
    • Remove eight 8 mm Phillips #2 screws holding the subwoofer tray to the housing.
  8. Sony CPF-IP001 Subwoofer Replacement: étape 8, image 1 de 2 Sony CPF-IP001 Subwoofer Replacement: étape 8, image 2 de 2
    • Using a metal spudger, slightly peel back the plastic the has been glued to the tray and the housing.
    • Slide the tray containing the subwoofer out of the housing.
  9. Sony CPF-IP001 Subwoofer Replacement: étape 9, image 1 de 2 Sony CPF-IP001 Subwoofer Replacement: étape 9, image 2 de 2
    • After removing the tray, flip it over and you will find four screws connecting the subwoofer.
    • Remove four 7.5 mm Phillips #2 screws.
  10. Sony CPF-IP001 Subwoofer Replacement: étape 10, image 1 de 2 Sony CPF-IP001 Subwoofer Replacement: étape 10, image 2 de 2
    • The subwoofer has now been removed from the device and can be replaced.
3 autres ont terminé cette réparation.
Mike Bolton
Membre depuis le 04/14/15
473 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 6-14, Maness Spring 2015 Membre de l'équipe Cal Poly, Team 6-14, Maness Spring 2015
CPSU-MANESS-S15S6G14
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 19
30 derniers jours : 22
Total : 792
