Aller au contenu principal
Sony Cyber-Shot DSC-W170 Front Panel Replacement
Katharina Anglett
Katharina Anglett et 2 autres contributeurs
Dernière mise à jour le December 20, 2023
3 - 6 minutes
Facile
This guide will help you to replace the front panel unit on the Sony Cyber Shot DSC-W170.
If the front panel is damaged, the solution is to replace the front panel unit. Be sure to remove power/disconnect batteries before performing this task!
Take a look at our troubleshooting page if you need help to remove the battery.
On the Sony website you can find replacement parts for the camera.
Ce dont vous avez besoin
Outils
  1. Sony Cyber-Shot DSC-W170 Front Panel Replacement, LCD Panel Assembly: étape 1, image 1 de 3 Sony Cyber-Shot DSC-W170 Front Panel Replacement, LCD Panel Assembly: étape 1, image 2 de 3 Sony Cyber-Shot DSC-W170 Front Panel Replacement, LCD Panel Assembly: étape 1, image 3 de 3
    • Be sure to remove the battery before performing this task.
    • Remove the five 4 mm screws with a Phillips #000 screwdriver.
  2. Sony Cyber-Shot DSC-W170 Front Panel Replacement: étape 2, image 1 de 1
    • Use an opening pick to pry the LCD panel open.
  3. Sony Cyber-Shot DSC-W170 Front Panel Replacement: étape 3, image 1 de 1
    • Gently remove the LCD panel from the rest of the camera.
  4. Sony Cyber-Shot DSC-W170 Front Panel Replacement, Front Panel: étape 4, image 1 de 3 Sony Cyber-Shot DSC-W170 Front Panel Replacement, Front Panel: étape 4, image 2 de 3 Sony Cyber-Shot DSC-W170 Front Panel Replacement, Front Panel: étape 4, image 3 de 3
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
  5. Sony Cyber-Shot DSC-W170 Front Panel Replacement: étape 5, image 1 de 1
    • Gently open the front panel and remove it from the rest of the camera.
Katharina Anglett
Membre depuis le 09/13/23
529 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 10
Total : 112
