Aller au contenu principal
Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement
Tim
Tim et 2 autres contributeurs
Dernière mise à jour le February 19, 2016
45 minutes - 1 heure
Modérée
A besoin de meilleures images
Problème de balise
Nécessite plus d'images
Tutoriel réalisé par la communauté
Ce dont vous avez besoin
Outils
  1. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: étape 1, image 1 de 3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: étape 1, image 2 de 3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: étape 1, image 3 de 3
    • Remove the battery
    • Remove the five 2.5mm Philips #0 screws.
    • Remove the one 2.5mm Philips #0 screw inside the HDMI case.
  2. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: étape 2, image 1 de 1
    • Gently work and pull the front cover off of the camera
  3. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: étape 3, image 1 de 1
    • Gently pull and disconnect the ribbon cable connecting the front cover to the main body
  4. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: étape 4, image 1 de 3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: étape 4, image 2 de 3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    iSesamo Opening Tool
    $9.99
    • Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry off the cover of the OLED/LCD assembly.
    • Take care of the tab/clip at the bottom, it can be a little tricky.
    • iSesamo Opening Tool is highly recommended
  5. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: étape 5, image 1 de 2 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: étape 5, image 2 de 2
    • Remove the copper phillips screw holding the HDMI mounting plate and detach the mounting plate.
  6. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: étape 6, image 1 de 3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: étape 6, image 2 de 3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: étape 6, image 3 de 3
    $9.99
    • Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry the OLED/LCD assembly from the adhesive strip on the main body.
    • Note: where the adhesive strip is located.
    • Turn the device over and remove the clear tape and black tape.
    • Important: Save the clear and black tape, they will be used for the replacement unit.
  7. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: étape 7, image 1 de 1
    • Gently pull the small flat ribbon cable from the main body
    • In order to disconnect the large flat ribbon cable, you need to flip up the black ribbon clamp located on the main body where the socket is located
  8. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: étape 8, image 1 de 1
    • Reattach new display, and reconnect all components
    • Test camera to ensure the new screen is working
    • Congrats!
Tim
Membre depuis le 03/12/12
2 199 Réputation
2 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 46
30 derniers jours : 64
Total : 4,626
