Aller au contenu principal
Sony Cyber-shot DSC-W570 Case Cover Replacement
Zizheng Su
Zizheng Su et 4 autres contributeurs
Dernière mise à jour le March 7, 2025
10 minutes
Facile
Meilleure introduction
Étudiant en action
Outline what you are going to teach someone how to do.
Ce dont vous avez besoin
Outils
  1. Sony Cyber-shot DSC-W570 Case Cover Replacement, Case Cover: étape 1, image 1 de 1
    • Begin by facing the camera bottom side up to reveal the two 2.93 mm long screws
    • Remove these two screws using a Philips #00 screwdriver
    • Make sure the battery compartment door is in lock position.
  2. Sony Cyber-shot DSC-W570 Case Cover Replacement: étape 2, image 1 de 1
    • Turn the camera sideways on its left side making sure the two 2.93 mm long screws are facing upwards
    • Remove the two 2.93 mm long screws using a Phillips #00 screwdriver
    • Keep all screws on stable surface to not loose them
  3. Sony Cyber-shot DSC-W570 Case Cover Replacement: étape 3, image 1 de 1
    • Turn the camera on its right side making sure it is facing upwards
    • Remove the last two 2.93 mm long screws using a Phillips #00 screwdriver
  4. Sony Cyber-shot DSC-W570 Case Cover Replacement: étape 4, image 1 de 2 Sony Cyber-shot DSC-W570 Case Cover Replacement: étape 4, image 2 de 2
    • Face the device with the camera lens facing upwards
    • Now that all the screws are unscrewed, the plastic opening tool will be used to remove the front cover.
    • Gently pry off each corner of the cover to remove it
    • Once all corners are pried off, gently lift off the cover and place it on the side
  5. Sony Cyber-shot DSC-W570 Case Cover Replacement: étape 5, image 1 de 2 Sony Cyber-shot DSC-W570 Case Cover Replacement: étape 5, image 2 de 2
    • Flip the device, making sure the screen is facing upwards
    • The back case should now be visible and ready to remove
    • Use the plastic opening tool to gently pry all along the corners and sides of the camera.
    • Gently lift off the entire back cover and place it on the side
Zizheng Su
Membre depuis le 01/21/15
101 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 9-1, Brown Winter 2015 Membre de l'équipe USF Tampa, Team 9-1, Brown Winter 2015
USFT-BROWN-W15S9G1
5 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 7
Total : 812
