Aller au contenu principal
Sony Cyber-shot DSC-W730 LCD Screen Replacement
Jeremy Petchonka
Jeremy Petchonka et 4 autres contributeurs
Dernière mise à jour le May 7, 2024
15 minutes
Facile
This will help solve a lot of black screen problems, as you should be able to see if the ribbon is connected or the LCD screen is damaged. Be careful with the ribbons.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Sony Cyber-shot DSC-W730 LCD Screen Replacement, Removing the Case: étape 1, image 1 de 3 Sony Cyber-shot DSC-W730 LCD Screen Replacement, Removing the Case: étape 1, image 2 de 3 Sony Cyber-shot DSC-W730 LCD Screen Replacement, Removing the Case: étape 1, image 3 de 3
    • Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
  2. Sony Cyber-shot DSC-W730 LCD Screen Replacement: étape 2, image 1 de 3 Sony Cyber-shot DSC-W730 LCD Screen Replacement: étape 2, image 2 de 3 Sony Cyber-shot DSC-W730 LCD Screen Replacement: étape 2, image 3 de 3
    • Take off the front part of the case with a plastic opening tool.
  3. Sony Cyber-shot DSC-W730 LCD Screen Replacement: étape 3, image 1 de 2 Sony Cyber-shot DSC-W730 LCD Screen Replacement: étape 3, image 2 de 2
    • Pull off the two silver side pieces on the left and right sides.
  4. Sony Cyber-shot DSC-W730 LCD Screen Replacement: étape 4, image 1 de 2 Sony Cyber-shot DSC-W730 LCD Screen Replacement: étape 4, image 2 de 2
    • Remove the main back piece. It should easily lift off.
  5. Sony Cyber-shot DSC-W730 LCD Screen Replacement: étape 5, image 1 de 3 Sony Cyber-shot DSC-W730 LCD Screen Replacement: étape 5, image 2 de 3 Sony Cyber-shot DSC-W730 LCD Screen Replacement: étape 5, image 3 de 3
    • Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
  6. Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Control Board: étape 6, image 1 de 2 Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Control Board: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    • Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard.
  7. Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Screen: étape 7, image 1 de 2 Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Screen: étape 7, image 2 de 2
    • Use tweezers to remove the ribbon that is connected from the LCD screen to the camera by pulling the part that is folded under, out.
  8. Sony Cyber-shot DSC-W730 LCD Screen Replacement: étape 8, image 1 de 2 Sony Cyber-shot DSC-W730 LCD Screen Replacement: étape 8, image 2 de 2
    • Slide the right side of the LCD screen clockwise, which will push it off the camera. The rest of the screen should come off with it with ease.
Jeremy Petchonka
Membre depuis le 01/20/15
279 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 9-4, Blackwell Winter 2015 Membre de l'équipe USF Tampa, Team 9-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G4
3 membres
12 tutoriels rédigés
2 commentaires
Excellent tutorial. It helped me a lot. I ve just replaced my LCD with success.
Thank you
joao - Réponse
I can record with the camera but I can't see the image while taking photos. Any suggestions?
Robin_o - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 15
30 derniers jours : 29
Total : 1,628
