Aller au contenu principal
Sony Cyber-shot DSC-W800 LCD Screen Replacement
Thomas Campo
Thomas Campo et 4 autres contributeurs
Dernière mise à jour le May 7, 2024
15 - 20 minutes
Facile
A besoin de meilleures images
Some things to consider before you work on the Sony Cyber-shot DSC W800 to replace the LCD Screen:
  • The LCD Screen is an integral part of the device and any improper handling can cause issues in other parts of the camera.
  • Be cautious when removing ribbon wires.
  • Be sure to keep track of all pieces that are taken apart.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Sony Cyber-shot DSC-W800 LCD Screen Replacement, Button Board: étape 1, image 1 de 3 Sony Cyber-shot DSC-W800 LCD Screen Replacement, Button Board: étape 1, image 2 de 3 Sony Cyber-shot DSC-W800 LCD Screen Replacement, Button Board: étape 1, image 3 de 3
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 LCD Screen Replacement: étape 2, image 1 de 2 Sony Cyber-shot DSC-W800 LCD Screen Replacement: étape 2, image 2 de 2
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 LCD Screen Replacement: étape 3, image 1 de 3 Sony Cyber-shot DSC-W800 LCD Screen Replacement: étape 3, image 2 de 3 Sony Cyber-shot DSC-W800 LCD Screen Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
  4. Sony Cyber-shot DSC-W800 LCD Screen Replacement, LCD Screen: étape 4, image 1 de 1
    • Remove the four 3.75 mm Phillips #000 screws from the LCD back panel.
  5. Sony Cyber-shot DSC-W800 LCD Screen Replacement: étape 5, image 1 de 1
    • Lift the back panel and separate the LCD Screen by prying it up.
    • Remove the back panel.
  6. Sony Cyber-shot DSC-W800 LCD Screen Replacement: étape 6, image 1 de 2 Sony Cyber-shot DSC-W800 LCD Screen Replacement: étape 6, image 2 de 2
    • Gently pull on the ribbon wire disconnecting from the ZIF connector (connecting the LCD screen to the motherboard) with the tweezers.
    • Ribbon wires can be easily damaged.
3 autres ont terminé cette réparation.
Thomas Campo
Membre depuis le 02/09/16
827 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 17-5, Blackwell Winter 2016 Membre de l'équipe USF Tampa, Team 17-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G5
5 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 53
Total : 2,940
