Aller au contenu principal
Sony Handycam FDR-AX33 Speaker Replacement
Lee Conway
Lee Conway et 5 autres contributeurs
Dernière mise à jour le May 7, 2024
15 - 45 minutes
Modérée
Tutoriel étudiant vedette
This guide will help you replace the speaker if it isn't working right. This will require you to dismantle quite a bit, so make sure to place your screws in proper order so you can put it together again.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Sony Handycam FDR-AX33 Speaker Replacement, Panel: étape 1, image 1 de 2 Sony Handycam FDR-AX33 Speaker Replacement, Panel: étape 1, image 2 de 2
    • Remove the battery by pushing the latch towards the body of the camera. Push the battery down and pull it out.
    • Remove the six black 4 mm Phillips #00 screws from the bottom panel of the camera.
    • Pull off the bottom panel. It may be difficult, but tugging on it shouldn't cause harm to yourself or the device.
    • Be sure to un-velcro the handle strap.
  2. Sony Handycam FDR-AX33 Speaker Replacement: étape 2, image 1 de 3 Sony Handycam FDR-AX33 Speaker Replacement: étape 2, image 2 de 3 Sony Handycam FDR-AX33 Speaker Replacement: étape 2, image 3 de 3
    • Remove the 3 mm Phillips #00 screw from the bottom of the camera.
    • Remove the 4 mm Phillips #00 screw from the right panel.
    • Pull the right panel off. Again, it might be difficult, but pulling hard shouldn't harm you or the camera.
    • You may have to use the opening tool to remove this panel.
  3. Sony Handycam FDR-AX33 Speaker Replacement: étape 3, image 1 de 2 Sony Handycam FDR-AX33 Speaker Replacement: étape 3, image 2 de 2
    • Remove the two 4 mm Phillips #00 screws from the top right corner of the camera.
    • Remove the 4 mm Phillips #00 screw from in front of the flash mount.
  4. Sony Handycam FDR-AX33 Speaker Replacement: étape 4, image 1 de 2 Sony Handycam FDR-AX33 Speaker Replacement: étape 4, image 2 de 2
    • Remove the 3 mm Phillips #00 screw from below the right side of the battery slot.
    • Remove the black 5 mm Phillips #00 screw from the top of the battery slot.
  5. Sony Handycam FDR-AX33 Speaker Replacement: étape 5, image 1 de 3 Sony Handycam FDR-AX33 Speaker Replacement: étape 5, image 2 de 3 Sony Handycam FDR-AX33 Speaker Replacement: étape 5, image 3 de 3
    • Remove the three 4 mm Phillips #00 screws from the left panel underneath the display screen.
    • You’ll need to extend the eyepiece by pulling it out from the body of the camera.
    • Pull the top panel off of the device with the iFixit opening tool.
  6. Sony Handycam FDR-AX33 Speaker Replacement: étape 6, image 1 de 3 Sony Handycam FDR-AX33 Speaker Replacement: étape 6, image 2 de 3 Sony Handycam FDR-AX33 Speaker Replacement: étape 6, image 3 de 3
    • Remove the top and bottom 4 mm Phillips #00 screws from the display screen hinge.
    • Use the iFixit opening tool to remove the screen hinge.
  7. Sony Handycam FDR-AX33 Speaker Replacement: étape 7, image 1 de 2 Sony Handycam FDR-AX33 Speaker Replacement: étape 7, image 2 de 2
    • Remove the 3 mm Phillips #00 screw from between the eyepiece and the panel directly to the right of the battery slot.
    • Angle the eyepiece up to reach the screw with the screwdriver.
    • Take the panel directly to the right of the battery slot off of the camera.
  8. Sony Handycam FDR-AX33 Speaker Replacement: étape 8, image 1 de 3 Sony Handycam FDR-AX33 Speaker Replacement: étape 8, image 2 de 3 Sony Handycam FDR-AX33 Speaker Replacement: étape 8, image 3 de 3
    • Remove the 4 mm Phillips #00 screw above and to the right of the battery slot.
    • Pry the left panel out at an angle by pushing the plastic slat between the battery slot and the eyepiece.
    • Wiggle the left panel and pull it out gently.
    • The left panel can be hard to remove so make sure to apply a good amount of force, but be cautious to not harm yourself or the device.
  9. Sony Handycam FDR-AX33 Speaker Replacement, Speaker: étape 9, image 1 de 2 Sony Handycam FDR-AX33 Speaker Replacement, Speaker: étape 9, image 2 de 2
    • Remove the two 4 mm Phillips #00 screws from the inside of the screen hinge.
    • Remove the black plastic from the back of the screen.
  10. Sony Handycam FDR-AX33 Speaker Replacement: étape 10, image 1 de 3 Sony Handycam FDR-AX33 Speaker Replacement: étape 10, image 2 de 3 Sony Handycam FDR-AX33 Speaker Replacement: étape 10, image 3 de 3
    Outil utilisé dans cette étape :
    • Using the tweezers, unplug the speaker. The connector should be a white piece of plastic attached to a red wire and a black wire.
    • Remove the speaker with the black nylon spudger. The speaker is attached by adhesive.
Lee Conway
Membre depuis le 01/24/19
184 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S18-G2, White Winter 2019 Membre de l'équipe Cal Poly, Team S18-G2, White Winter 2019
CPSU-WHITE-W19S18G2
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 636
