Aller au contenu principal
Sony Handycam HDR-CX580V Recording Button Replacement
Derek Fritz
Derek Fritz et 3 autres contributeurs
Dernière mise à jour le May 7, 2024
20 - 30 minutes
Modérée
In this guide, you will go through the process of removing the camera's recording button, as well as its wiring. This involves removing a portion of the camera's shell, but can be accessed relatively easily.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Sony Handycam HDR-CX580V Recording Button Replacement, Battery: étape 1, image 1 de 1
    • Locate the slider labeled "BATT" and pull it back from the battery with your thumb.
  2. Sony Handycam HDR-CX580V Recording Button Replacement: étape 2, image 1 de 1
    • At this point, you should be able to remove the battery by simply lifting it from the camera.
    • The camera provided for guide-creation did not include a battery. However, the battery position should be the same.
  3. Sony Handycam HDR-CX580V Recording Button Replacement, Recording Button: étape 3, image 1 de 3 Sony Handycam HDR-CX580V Recording Button Replacement, Recording Button: étape 3, image 2 de 3 Sony Handycam HDR-CX580V Recording Button Replacement, Recording Button: étape 3, image 3 de 3
    • Use the Phillips #00 head to remove the following 5.5mm screws on the left-hand side.
  4. Sony Handycam HDR-CX580V Recording Button Replacement: étape 4, image 1 de 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the empty battery socket.
  5. Sony Handycam HDR-CX580V Recording Button Replacement: étape 5, image 1 de 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the bottom.
  6. Sony Handycam HDR-CX580V Recording Button Replacement: étape 6, image 1 de 1
    • Fold back the hinging panel on the top of the camera located near the lens.
    • Use the Phillips #00 head to remove the following 5.5mm screws on the top under the hinging panel.
  7. Sony Handycam HDR-CX580V Recording Button Replacement: étape 7, image 1 de 2 Sony Handycam HDR-CX580V Recording Button Replacement: étape 7, image 2 de 2
    • Slide back the cover for the DC and A/V ports on the right-hand side.
    • Use the Phillips #00 head to remove the following 5.5mm screws underneath the cover and on the right-hand side.
  8. Sony Handycam HDR-CX580V Recording Button Replacement: étape 8, image 1 de 1
    • Use the plastic opener tool to loosen the casing on the bottom and the right-hand side.
    • At this point, the right-hand side should simply come off, although it will still be connected with internal wiring.
    • Be delicate with the wiring still attached to the side casing until you have access to removing them later.
  9. Sony Handycam HDR-CX580V Recording Button Replacement: étape 9, image 1 de 3 Sony Handycam HDR-CX580V Recording Button Replacement: étape 9, image 2 de 3 Sony Handycam HDR-CX580V Recording Button Replacement: étape 9, image 3 de 3
    • Carefully remove the bottom casing with your fingers.
    • Be careful not to loose the small metal stand-mount pieces that lay underneath the casing.
  10. Sony Handycam HDR-CX580V Recording Button Replacement: étape 10, image 1 de 1
    • Look at the right side of the camera (the side with the recording button) while holding back the detached casing.
    • Use the Phillips #00 head to remove the following 5.5mm screws near the recording button.
  11. Sony Handycam HDR-CX580V Recording Button Replacement: étape 11, image 1 de 1
    Outil utilisé dans cette étape :
    • Use the curved tweezers to carefully detach the blue ribbon cable connector from the body of the camera.
    • The recording button and its blue ribbon cable connector should become detached from the body, but remain connected to the top casing.
  12. Sony Handycam HDR-CX580V Recording Button Replacement: étape 12, image 1 de 2 Sony Handycam HDR-CX580V Recording Button Replacement: étape 12, image 2 de 2
    • Pull off the top casing by lightly grabbing either side and pulling towards the back of the camera.
  13. Sony Handycam HDR-CX580V Recording Button Replacement: étape 13, image 1 de 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the inside of the top casing.
  14. Sony Handycam HDR-CX580V Recording Button Replacement: étape 14, image 1 de 1
    • Carefully remove the metal frame from the top casing.
  15. Sony Handycam HDR-CX580V Recording Button Replacement: étape 15, image 1 de 1
    • You are now free to remove the recording button, as well as its connection strip.
Derek Fritz
Membre depuis le 03/21/17
378 Réputation
3 tutoriels rédigés
Équipe
Texas Tech, Team S46-G5, Bennett Spring 2017 Membre de l'équipe Texas Tech, Team S46-G5, Bennett Spring 2017
TTU-BENNETT-S17S46G5
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 16
Total : 517
