Aller au contenu principal
Sony NEX-7 LCD Assembly Replacement
Jay Miley
Jay Miley et 7 autres contributeurs
Dernière mise à jour le May 7, 2024
5 - 10 minutes
Modérée
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Sony NEX-7 LCD Assembly Replacement, LCD Assembly: étape 1, image 1 de 1
    • Remove the two 3/32" #00 screws located next to the viewfinder using the Phillips #00 screwdriver.
  2. Sony NEX-7 LCD Assembly Replacement: étape 2, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the two screws from the right side of the camera below the D ring:
    • The 5/32" upper screw
    • The 3/32" lower screw
  3. Sony NEX-7 LCD Assembly Replacement: étape 3, image 1 de 1
    • Remove two more 3/32" #00 screws from the bottom of the camera using the Phillips #00 screwdriver.
  4. Sony NEX-7 LCD Assembly Replacement: étape 4, image 1 de 1
    • Remove two more 3/32" #00 screws from the metal bracket on the left side of the camera using the Phillips #00 screwdriver.
  5. Sony NEX-7 LCD Assembly Replacement: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    • Unplug the orange ribbon cable on the top right of the camera next to the metal bracket by applying tweezers to the tabs on either side of the plug.
  6. Sony NEX-7 LCD Assembly Replacement: étape 6, image 1 de 1
    • Before pulling off the assembly, fold the rightmost tab of the flexible circuit board away from the metal bracket.
  7. Sony NEX-7 LCD Assembly Replacement: étape 7, image 1 de 2 Sony NEX-7 LCD Assembly Replacement: étape 7, image 2 de 2
    • The LCD assembly is attached with a concealed ribbon cable, so be gentle when you remove it.
    • The D ring brackets on either side are not attached, only held in mechanically. Once the LCD assembly starts to come out, they will detach.
    • Pull on the D rings on either side of the camera to start removing the assembly.
    • Once the brackets are cleared from black shell, take them off and set them aside.
    • Continue to remove the screen assembly.
  8. Sony NEX-7 LCD Assembly Replacement: étape 8, image 1 de 1
    • With the camera face down, move the assembly away from you to get a clear view of the wide ribbon cable.
    • Unplug the cable by applying tweezers to the tabs on either side of the plug.
    • Set the LCD assembly aside.
Jay Miley
Membre depuis le 04/22/14
5 230 Réputation
13 tutoriels rédigés
Équipe
Cal Poly, Team 10-55, Amido Spring 2014 Membre de l'équipe Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 membres
36 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 16
Total : 93
