Aller au contenu principal
Sony SRS-XE200 Charging Port Replacement
Vishant Savaliya
Vishant Savaliya et 3 autres contributeurs
Dernière mise à jour le June 12, 2023
20 minutes
Modérée
The Sony SRS-XE200 is a popular Bluetooth speaker known for its compact design and impressive audio performance. However, like any electronic device, the charging port of the Sony SRS-XE200 may experience wear and tear, physical damage, or other issues over time, leading to difficulties in charging the speaker. If you're facing problems with the charging port on your Sony SRS-XE200, such as a loose connection, broken pins, or the inability to charge the battery, you may need to consider replacing the charging port.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Sony SRS-XE200 Charging Port Replacement, Speaker Assembly: étape 1, image 1 de 2 Sony SRS-XE200 Charging Port Replacement, Speaker Assembly: étape 1, image 2 de 2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Charging Port Replacement: étape 2, image 1 de 1
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Charging Port Replacement: étape 3, image 1 de 2 Sony SRS-XE200 Charging Port Replacement: étape 3, image 2 de 2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Charging Port Replacement: étape 4, image 1 de 2 Sony SRS-XE200 Charging Port Replacement: étape 4, image 2 de 2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Charging Port Replacement, Battery: étape 5, image 1 de 3 Sony SRS-XE200 Charging Port Replacement, Battery: étape 5, image 2 de 3 Sony SRS-XE200 Charging Port Replacement, Battery: étape 5, image 3 de 3
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Charging Port Replacement: étape 6, image 1 de 3 Sony SRS-XE200 Charging Port Replacement: étape 6, image 2 de 3 Sony SRS-XE200 Charging Port Replacement: étape 6, image 3 de 3
    • Remove the battery from the battery holder with a nylon spudger.
    • Unplug the battery from the motherboard.
  7. Sony SRS-XE200 Charging Port Replacement, Charging Port: étape 7, image 1 de 2 Sony SRS-XE200 Charging Port Replacement, Charging Port: étape 7, image 2 de 2
    • Remove the charging port.
Vishant Savaliya
Membre depuis le 02/09/23
376 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 17
Total : 657
